Trailer Maintenance
8 Users
leeboweffect
(@leeboweffect)
[#5996]
In preparation for the new season I disassembled and inspected my trailer bearings. Unfortunately, after only one season (new and fully packed with premium marine grease last year) here is what I found (bad dog!!!). I found entire replacement hubs with bearings and seals on etrailer for $ 17.49:
https://www.etrailer.com/Trailer-Hubs-and-Drums/etrailer/AKIHUB-440-2-1K.html
The hubs were delivered in three days and installed without argument = VERY CHEAP insurance!
Posted : April 27, 2017 4:46 am
good call !
i just updated my entire axel and hubs this year too on my main trailer
sure beats losing a wheel while on the road
Posted : April 27, 2017 4:54 am
leeboweffect
(@leeboweffect)
MN3 wrote: sure beats losing a wheel while on the road
Nothing will buzz kill a weekend of sailing faster than a broken down trailer!!!
Posted : April 27, 2017 4:57 am
(@klozhald)
Have you considered Bearing Buddies?
Posted : April 27, 2017 10:34 am
leeboweffect
(@leeboweffect)
klozhald wrote: Have you considered Bearing Buddies?
Have run Bearing Buddies for years and they work quite well. I now use the knock off version from Harbor Freight as they are about a third the price and I can't tell the difference:
http://www.harborfreight.com/198-inch-wheel-bearing-protectors-1-pair-97166.html
The premature failure I experienced was a result of the seal leaking not lack of grease.
Posted : April 28, 2017 4:31 am
(@jgraham)
Newby Registered
Last fall I inspected my bearings and found them in the same trashed condition as yours - after installing not-cheap Timken bearings just two seasons ago.
I found a Westernprime complete kit with bearings & seals for $20 on Amazon. They're chinese (IIRC) but I decided for that amount I would just replace them once a season. Also using marine grease and the Reese "bearing buddies" which are very nice for $10 shipped on Amazon.
Posted : May 4, 2017 6:21 am
(@hullflyer)
Just another question
If you are running at 60 plus MPH
How fast do you think a 8 or 12 inch tire is traveling in comparison
I have seen sailors travel hundreds of miles and back down a boat ramp into the water to unload the boat without letting the bearing cool down.
Would that cause harm to the bearing
Posted : May 4, 2017 7:58 am
(@hullflyer)
It is appx 83%, that is if an 8" rim travels 100 revolutions, a 12" rim will travel only 83. This is based on a tire having a 4" sidewall.
These numbers vary somewhat, depending on the actual tire mounted on the rim. If 2 different tires are mounted on identical sized rims, the tire with a higher sidewall will result in a larger total diameter wheel, & a slower rate of rotation.
I have heard that immersing a warm bearing into relatively cool water results in the airspace in the hub cooling, which creates a slight bit of vacumn, which might then draw water into the hub. I'm not sure waiting gives much benefit. Good clean bearings don't really get hot, I have often stopped & felt the dust covers, they barely feel "warm", let alone "hot". If the air temp is in the 90's, & water only 80, you would still have a differential, even if you let them cool for an hour.
I think good seals, & servicing them every year is more effective.
Edited by Edchris177 on May 04, 2017 - 06:02 PM.
Posted : May 4, 2017 12:00 pm
tominpa
(@tominpa)
I love this place...
I always find more crap i gotta do, like tear down the bearings for a check and re-lube.
Posted : May 4, 2017 3:16 pm
(@windwardde)
Just my 2 cents
Both my motorboat and my cat trailer have bearing buddies. Cat has 8" rims and motorboat 12".
I check them and repack them every season.
I do not slow down much from normal driving when I tow. I drive 65 mph or more. I am good about checking them for heat, but haven't run into an issue in years. When I did run into an issue, it was because I hadn't maintained them, nor did I use bearing buddies. Thus, why I do maintain them every year, now.
I don't let them cool down when I launch and I am 95% in salt water.
I say, check them every season, put the bearing buddies on and every now and then check them for heat when traveling and you will be fine.
Just saying!
Posted : May 5, 2017 4:26 am
