trapeze set up
I had this great big all typed up and got distracted while I was in the preview and lost it all so here is the short of it with some quickie diagrams. Not sure if yours is exactly the same as mine is a P18 but it should be close. Also there is more than one way to do this this is just how mine is setup and I had to figure it out pretty much on my own.
I made a Diagram to help you.
edited by: Quarath, Apr 30, 2009 - 02:02 PM
Quarath wrote: First I have 2 Diagrams I put together for you. The first is the Top of the trap lines.
That is excellent work!
Please add these to the Beachcats Technical album with a name like Prindle 16 Trap Wires or something.
This is going to help a lot of newbies in the future. Did you do that drawing from scratch?
I did it from memory at work in Illustrator.
It helps that I am graphic designer by trade but really didn't take that long.
It is by no means proportionally or even scaled correctly
I actually wanted more details but I was at work and and needed to actually do some and didn't want it to detract from the actual point. Could easily be adjusted to show jib line set up as well.
Quarath wrote: Don't know what happened to the image when I tried to add to the technical gallery it kind changed and screwed up the image. It looks pretty crappy compared to the one I have posted here.
That's strange, in fact all I saw was a broken image, something went wrong. I just uploaded the one from this thread and it went ok.
Was it the same jpg file you uploaded to the technical album as the one you uploaded to your personal profile pictures?
- 1,402 Online
