What type of rivets...
What type of rivets to use?
[#2917]
I noticed this spring that some of the rivets holding the tramp track to the hulls (Nacra5.7) have popped loose. About 5 more seem to have pulled partially loose, probably during the harsh pitchpole last fall. I wanted to install hatches anyway, & this will give access to the inside of the hull.
I plan on placing a stainless washer on each rivet, on the inside, as th eholes are probably a little loose now.
My question is what type of rivets to use? The tramp tracks are only aluminum, can you use aluminum rivets, or are they something else, monel maybe? They don't appear to be SS rivets.
Posted : May 13, 2012 1:55 pm
Could you get aluminum washers? That way with aluminum rivets you wouldn't have a steel/aluminum electrolysis situation. Aluminum rivets should be plenty strong with the washers considering the original factory build just riveted directly to the fiberglass and aluminum should be stronger than glass. I'm assuming the track is also aluminum.
Posted : May 13, 2012 2:46 pm
(@wolfman)
Chris, you could probably get away with blind rivetting using stainless rivets inside those stainless rivet casing's Murray's sells. That way they are sealed and the casings make up for any ovalling that the rivets popping out may have caused. I'm not sure that electrolysis is a big concern for you considering you only sail in fresh water. Add salt to the mix and that type of corrosion becomes much more of a problem.
If you are putting in a port anyway and can reach all the rivets your idea sound like the best course of action.
Posted : May 13, 2012 4:38 pm
Good point. I can get aluminum washers, & yes the tracks are aluminum.
I wanted a port Dave mostly for ease of draining. The skeg hull boats have quite a rise along the bottom of the hull in the last 3 feet. My lawn/shoreline is very flat, I have to get the boat on nearly a 45* angle to drain all the water, which is a pain. Originally I though I could insert a small tube through those 1" pressure relief ports that are near the inside top rear of each hull, but I can't feed the tubing though the bulkhead that is built just around the rear beam area. There is a drain hole in the bottom of the bulkhead, but without access I can't get the tubing to do the contortions required.
With a small port I can use a small float pump ,(a hand operated pump we used to pump water out of compartments on floatplanes) to suck the water out, or a sponge.
Posted : May 13, 2012 11:52 pm
I'm waiting for Andrew to jump on me for that faux pas:-D
I ended up using aluminum rivets, as that is what the originals were. They drilled out REALLY easy.
I held the track down with a piece of 2x4, & pulled the first rivet. It seemed to hold fast, so I drilled & pulled the rest. It all seems solid after pulling the tramp tight, so we are sailing tomorrow.
Didn't bother with the hatches yet, as I could not get ones with the curved surface.
Posted : May 23, 2012 2:13 pm
As an update,Damon, I found aluminum washers are easy to come by, & cheap. They are sold in blister packs of 30, by Arrow, the same people who make all the staples for those heavy duty staple guns.
Posted : May 25, 2012 5:53 am
