Will an H18 fit on an H16 trailer?
The rollers on most cat trailers are adjustable width wise. They have u bolts that can slid on the frame. One issue is the weight. The 18 is a bit heavier than the 16. Check the springs.. Not a bad time to install cradles in the rear insted of rollers.. Better for the hulls.. Most cat railers have a frame that is long enough for a boat 2 ft bigger as well.. Hal.
if you do go a H16 trailer with rollers for a H18
think about adding some kind up hull cradles
the H16 doesn't really need them as it had very strong, thick keels
but curved hulls are built lighter and will not take jolting or over-strapping as well with only the point contact of rollers
you can buy them or make your own
for my nacra 5.2 i made some cradles from off-cuts of 12' poly pipe from a local sewer-main project
added heavily painted wooden bases to slide on the trailer arms and glued some bits of carpet on the inside curve
Edited by erice on Apr 05, 2012 - 02:46 AM.
- 3,029 Online
