Looking for information on McGregor 36s
Though I've never owned one....I've sailed on them and have kept my eye on them for some time before I finally opted for a Stiletto 27.
Some of the great points are that you get lots of boat for the money, they are quite stable and carry a load pretty well and they go quite well.
The down side (for me) was availability of replacement parts such as rudders, boards, etc. and though they are trailerable...there's a lot of work and time involved in setting them up for sea nad more for setting them up for trailering.
Here are some sites you may find of interest:
http:/
http:/
http:/
Here Are A Few Tips For Racing and Saillng A MacGregor Catamaran
WeightControl
Nothing is more important to performance And safety than keeping weight down. In a 12 knot wind, The addition of 100 pounds will cut speed by 1 1/2%. In a 100 mile race, it makes a 1 1/2 mile difference. Considering how close most races end up, this is a big penalty.
If you are really serious about getting weight down for an important race,
here are some things you can remove:
Cushions, replace with air mattresses 65 lbs.*
Carpet 40 lbs.*
Trim Panels 35 lbs.
Galley 25 lbs.
20 HP outboard, replaced with a 10 40 lbs.
Sail Covers 10 lbs.
Battery, replace with an aircraft battery 25 lbs.
Head, use a bucket 15 lbs.
All this comes to about 255 lbs. *worse when wet
With careful crew selection, light provisioning, and by keeping personal gear weight down, another 200 to 300 pound weight saving is possible. This gets up around 500 pounds, which can make one hell of a difference in the boat's speed.
Remember to bail the bilge, nose and stern compartments. They can pick up a lot of weight.
As weight increases, rig loads increase, cross tube loads go up, and the boat is less likely to slide away from breaking seas. If it is capsized, or flooded, it is much more vulnerable and harder to right.
Don't build in a lot of stuff. An overweight multihull has no reason for existence.
Weight Position
As a general guideline, try to keep the weight as near to the fore and aft center as possible to reduce pitching motion.
In light air, position the crew and gear far enough forward to get the transoms out of the water. This cuts wetted surface and substantially reduces transom drag. In winds up to 12 knots, keep the weight off the sterns
As the wind increases, move the crew aft. As speed increases, the water will flow cleanly off the transoms even if the weight is aft. When running downwind in heavy winds or steep seas, the weight near the stern will help keep the nose from digging in.
Obviously, keep the crew to windward to improve stability. In really light air, however, some weight on the downwind side will help.
Underwater Surfaces
The bottom must be smooth -- 600 grit sandpaper smooth. At 12 knots or more, a polished underbelly is essential. Any growth or roughness will turn the boat into a real turkey. Scrub the bottom before each race. The rudders and centerboard are a major percentage of the drag, so really work on them. A slightly fouled bottom can cut speed by 20%.
Capsize Prevention
When the windward hull starts to feel light, when you find yourself luffing sails to get thru gusts, when a bow gets low, or when things seem like they might get a bit out of hand - reef, change headsails, or otherwise reduce power. The time to reef or change headsails is when you first think about it.
When oversailed, the cat is an ultra powerful, ultra fast rocket. With a small sail plan set, it is quite tame. Be conservative, and concentrate on developing the judgement to know when to ease off. We have learned this with cars. Now it is almost instinctive. Cars are not driven wide open all the time. The cat shouldn't be either. You won't win many races if you have to spend time righting the boat, or worse.
Never take more than three wraps on a winch. Four or more may not slip when you want them to. Line can seize up on a winch. It is important to let it slip and pull it in occasionally when it is blowing hard, so you know that it will run free in an emergency. Make sure the tails are free to run, and that nothing can jam any block.
When it is blowing hard, don't cleat down any sheet. Hold them in your hand for instant release.
Watch for overrides on winches. This occurs when the loaded line comes up and over the next wrap on the winch. They are almost impossible to get loose, and dangerous. The most common cause is having a crew member lift up on the line between the fairlead block and the winch while another crew member cranks the winch. The line should always lead to the winch from below the winch, not from above.
A wrap sometimes occurs when the winch is cranked while the line is loose and flapping around. Don't even start to wrap a sheet on a winch until all the slack is out of it.
Make sure the mainsheet tail is near the helmsman. Lay it on the deck so that it can be released from either side of the boat. The Genoa or jib should always be cleated near the helmsman so it can be released instantly.
If a hull lifts, it is quite possible for the crew to slide down to the low side. If the sheets are cleated on the high side, and the crew is not manning each sheet, you may just have to sit there helplessly as the boat goes over. Wherever you go, or slide, on the boat take the sheet tails with you .
I have always made a practice (on big cats and big monohulls) to have a good sharp knife in a sheath taped within easy reach. If a crewman gets tangled up in a loaded line, or if a winch gets a tight overwrap in an awkward situation -- cut the line! On the cat, it's a good idea to tape a sheath on each tiller.
Use the "chicken" technique. Anytime any crewman feels like the boat is overpowered, he should ease his sheet without consulting with anyone and without getting a lot of lip from anyone. No sense sitting around in great debate while the boat goes over.
If the boat starts to go over, slide to the lower side. This beats taking a long fall later.
One weird problem. If you have a novice hold on to a sheet...be careful When a hull lifts, even experienced crews will clutch, panic, or sit there in stupid fascination, hold the line with desperation and simply watch the boat go over...without ever releasing it. Warn everyone and still be prepared to have to pry a line loose now and then.
Remember, it is possible to dump a boat in very strong winds by allowing the boat to head directly into the wind without releasing the jib or Genoa sheet. The sail can backwind, stop the boat, quickly spin it around and blow it over.
Don't fly a hull. It is dangerous and slows down the boat.~ Shorten sail
If a nose starts to bury, shorten sail.
Equipment
Here is a list of the items I usually carry for coastal cruising and racing .
Mainsail Spare Blocks
Working Jib Winch Handles (2)
Genoa Drifter Bridle
Spinnaker
Drifter
Spinnaker Pole Righting Bag
Spinnaker Sheets (2) Fire Extinguishers (2)
Vang Bilge Pump
Foreguys (2) Bucket (for bailing)
Centerboard Wedge Life Preserver (1 per person)
Centerboard Pin Horn
Jib Sheets Anchor, Chain & Rope (2)
Man Overboard Ring, Outboard Motor
With Pole, Dye Marker, Extra Fuses for VHF & Lights
Strobe Light & Whistle Dock Lines
Personal Strobe Light Sail Covers
For Each Crew Member Fuel
Raft & Paddles (Avon Redcrest) Water
Inflated,on Intermediate Net Boat Tape
Pump for Raft Alcohol Stove & Alcohol
Radar Reflector Sail Patching Equipment
First Aid Kit Flashlights Head
Flare Gun & 10 Rockets Extra 1/2" Clevis Pins
Fully charged battery Tools (include 2 pairs vice grips)
Knife Extra 1/2" Clevis Pins Extra Shackles & Cotter Pins
RDF Wet Suit ForEach Crew
Extra RDF Batteries (for cold weather)
Charts Wet Weather Gear
Chart Compass Bosun's Chair
Pencils Food
VHF, With Spare Antenna Ice Chest
EPIRB (beacon) Bedding
Extra Compass
Parallel Rule
Protest Flag
Stop Watch
Accurate Watch
Signet Knotmeter (O to 30 knots) with log
Windex Masthead Wind Pointer
Danforth Cl51 Compass mounted on seat
Where possible, get the absolute lightest of everything. Be ridiculous about it. All this stuff can add up to a lot of tonnage. -
Daggerboard Control
When sailing close into the wind, the dagger board should be down, with the top of the board 3 feet below the top of the deck...no lower ..or you may break the board or the trunk.
Tie the daggerboard line to the pad eye on the deck so the board cannot go more than 3 feet below the top of the deck. (If a hull lifts, the board may fall out or go below the 3 foot point if the rope is not tied securely.)
This line will also prevent the board from sliding out the top and mashing someone in the event of a capsize.
Important: when sailing over 10 knots, never have the top of the board below the level of the top_of_the deck. This will give you about 2 1/2 feet of board below the hull, which is all the area you need at these speeds. More board than this will cause unnecessary drag, create excessive loads on the hull and board, and greatly increase the risk of damage if the board hits something.
When running, no board is necessary. Pull it up and pin it. When the board starts clunking from side to side with wave action...it is no longer creating lift, because there is no significant sideways force on the sails pull it up.
In extreme conditions, Pull the board all the was up to let the boat slide away from breaking seas.
Looking down on the board, note that it positions itself at about a 3 degree angle to the centerline of the boat, with the leading edge pointing to the windward side of the boat. This allows the board to generate lift without the entire boat having to crab sideways to provide the neccessary angle (a centerboard provides no lift at all unless it has some angle relative to the flow of water.)
In light to medium winds, a wedge can be used to add another 2 or 3° I normally carry a mahogany 2"x2n, about 4' long, with a long taper at one end. This is used to push the board full down and to wedge the lead-ing edge to a greater angle of attack.
Rig Tuning
The dolphin striker wires should be tightened just enough to give an absolutely straight center cross tube in a 12 knot wind. Both wires should have the same tension.
No matter what you do, the leeward shrouds will be loose when sailing. There is no reason to pre-tension everything super tight.
To flatten out a full main in moderate to heavy winds, adjust the lower shrouds and lower forestay to bring the center of the mast about 4" forward of a straight line between masthead and deck.
The mast should rake slightly aft, and be absolutely straight sideways, when under load in a 12 knot breeze.
If the mast pumps (or moves fore and aft at the center) as the boat goes thou seas, tighten up the lower shrouds and lower forestay.
Do not try to get the same forestay tension that you would try for on an IOR monohull. You will simply bend the boat. The jib and Genoa are both cut with a substantial luff hollow curve, a rod straight forestay is not desirable.
Don't over tighten the lower forestay. You will just bend the forward cross tube.
Sail Trim
There are literally hundreds of books and articles on proper sail trim, so I won't go into detail here. Treat it as you would a standard IOR rig. The big differences are (1) sails should be flatter because of the high wind velocities the cat rig sees, and (2) apparent wind will shift radically from the true wind as the boat speed builds up.
Use the gang to take unwanted twist out of the main. Always vang to lee-ward... never to windward. You may not be able to release it in time to prevent capsize.
Concentrate primarily on the streamers on the Genoa. With the sail properly trimmed, the windward streamer should be just starting to float off of the sail, while still generally streaming aft. The leeward streamer should be flowing aft. If it isn't, the sail has stalled. Ease the sheet or head up.
Headsail Changes
Here is a really quick way to change headsails. While the boat is moving, disconnect the 2 lowest hanks on the sail that is driving the boat. Leave the tack connected. Snap all of the hanks of the new sail on the headstay between the tack and the 3rd hank. Connect the new sail tack to a second shackle on the bridle triangle.
Lower the old sail, unsnapping the lowest hanks first as the sail comes down. Quickly change the halyard from the old to the new sail and hoist the new sail. You should go bald for about 30 seconds. Then, when you are all set - disconnect the tack of the old sail.
Fairlead Positions
The jib and Genoa fairleads are unique. The strongest points on the boat to secure fairleads are the cross tubes. It takes a lot of heavy beefing under the fiberglass decks to take the severe loads of headsail fairleads, and the hulls are too far apart anyway to provide proper sheeting points. So we are stuck with locations on the tubes, which give infinite adjustment inboard and outboard, but none fore and aft. It is possible to give precise adjustment by carrying the headsails either higher or lower on the headstay. Moving the sail up the headstay a few inches has the effect of moving the fairleads forward by a much greater distance. As a starting point, a short pennant (about 9") between the jib tack and the attachment point on the bridle moves the jib up enough to give a good lead. (The jib fairleads attach to the forward cross tube and the Genoa leads attach to the rear tube.) The Genoa leads are generally about right with a 6" pennant between the bridle and the jib tack. The fairlead positions are good if the entire leading edge of the sail starts to luff uniformally from top to bottom as the boat heads up slowly into the wind.
For reaching, the Genoa is best sheeted as far outboard as possible. Try using a snatch block on the lifeline post base to pick up the sheet and carry it forward and outboard. The sheet goes thru the snatch block, thru the regular fairlead block, and then to the winch. Don't use this set up in heavy winds.
The jib fairleads can also be moved outboard about 8" for reaching. This involves another set of 1/2" holes drilled horizontally thru the center cross tube.
Spinnaker Handling
If the apparent wind is aft of the beam, and winds are moderate, use the chute. Keep the tack and clew level and always have the end of the pole as far aft as possible. Trim the sheet so that the leading edge is just on the verge of folding over.
Do not reach with the chute in winds over 10 knots. Never let the pole go forward of the windward bow. If you can't keep the chute open at this point, douse it and use the Genoa. You will go faster.
Remember, the spinnaker is a light air sail.
Always have the Genoa up before raising and lowering the chute. This causes it to be blanketed and prevents a wrap around the forestay. Try to head directly downwind to get the chute up and down.
Use the foreguy as shown in the assembly instructions.
Practice with the chute in really light air. These things are big, capricious and potentially dangerous. They require knowledge, skill and practice.
Steering for Speed
In light air, tack downwind. Never let the apparent wind too much aft of the beam. You will have to go farther, but the additional speed generated by reaching will more than make up for the extra distance.
For example, tacking 20 degrees above the straight downwind rhumb line adds only 6% to distance, but can add as much as 30% to speed. 30 degrees adds 15% to the distance and 45 degrees adds 40%.
In heavy wind, tacking downwind is of much less value. Square off and run with it unless heading up a bit produces a significant increase in speed.
When tacking downwind, bear off in the puffs.
When going to weather, don't pinch.
When you try to point up with monohulls, you will drop back to their speed. You can outpoint them, but it isn't worth it.
Generally, the slower a boat goes, the higher it can point, because the boat's speed through the air shifts the apparent wind to more on the nose.
As the cat picks up speed, the apparent wind shifts around and forces you to sail further off the true wind. As you fall off a few degrees, your speed will pick up as much as 40%, and you will more than make up for the extra distance that you will have to sail.
A monohull will only pick up a small percentage of speed as it heads away from the wind, so it pays for them to pinch like crazy. You will soon get used to the idea of seeing a monohull pointing 10° higher, going 4 knots, with its jib on the edge of luffing, while you are going 7 or 8 knots, with your jib also starting to luff. And you will get there first. if you come up to their pointing angle, your speed will drop to 4 knots and your jib will still be on the edge of a luff.
Don't try to beat them at their game. The apparent wind angle will limit you to their speed if you do. Sail off and go for boat speed. Remember, a big percentage of the wind you are feeling is created by the speed of the boat.
Caution. This is seductive. As you point farther from the wind, boat speed will continue to increase, and the apparent wind, created by the boat speed, will shift with you and you will think you are close hauled even though the boat is on a broad reach with respect to the true wind.
The shifting of apparent wind is the reason that monohull sailors still sometimes think cats don't point well. No competent cat sailor will try to point with them if he wants to win.
Tacking
The boat sails nicely under main alone, but it is slow to tack without the jib. The reason is that the center of effort of the main is quite far aft of the center of hull resistance. The boat will tack thru the eye of the wind, but will be slow to start on its new course without the jib.
The boat will try to weathervane back into the wind. The jib will prevent this. When trying to get around fast and surely, let the jib backwind for a few seconds. If you get in irons, push the boom toward the side you wish to go, and also push the tiller toward the side you wish to go. The boat will back up and turn toward the new tack.
Practice sailing backwards..
When racing, have one of the crew pull the clew of the Genoa in as tight as possible, to get the boat started, while another crew member works the winch. If you can get it in before the boat takes off, you can save a lot of cranking.
Securing Hatches
In heavy weather, secure lifting hatches with the cabin lock or a line over the top. With high winds from the rear, they could slam open hard. With really high winds from the side, they could lift and let in a lot of Spray.
Radio
I strongly recommend having a VHF radio on board. The Horizon 25 is excellent, and reasonably priced. Use a masthead antenna, with the cable coming down the inside of the mast. Mount the radio to the front face of the galley (with the top of the radio pointing forward). Mount it far enough inboard so that the knobs don't stick too far out in the aisle, but not so far back that the antenna cable has to kink where it comes out of the back of the set.
The masthead antenna mount gives far better range than a deck mount. However, it is useless if you lose your mast. You can get a small antenna (for about $10) that plugs directly into the back of the set and gives good range. I always carry one in the event the regular antenna is disabled.
One of the most essential safety items is an emergency position indicat-ing radio beacon (EPIRB) that will send out a continuous locator signal on a frequency that is closely monitored.
Speed Indicator
Use a Signet knotmeter (0 to 30 knots) with a log incorporated in the unit. Mount the dial and the paddle wheel as shown below.
In this position, you can see it from both sides of the boat. Where you drill thru the hull for the paddle wheel, reinforce the area with 4 layers of 14 ounce fiberglass mat and resin, 6" x 6". Make sure you mount the paddle wheel flush with the outside of the hull. If the log runs improperly with the engine running, you may have to install resistor (non-static) spark plugs in the outboard.
Compass
Mount a Danforth C-151 "Lodestar" compass in either or both seats.
Don't cut into the vertical cabin back for a flush mounted compass. The area is heavily loaded and an important piece of the structure. In fact, the compass holes and speedometer hole are the only cuts I would make in the fiberglass structures.
Drifter
One of the most valuable sails on the boat is the drifter, a huge 1 oz. nylon sail that flys from the spinnaker halyard at the masthead and the end af the spinnaker pole (about 3' ahead of the boat). It sheets in with the spinnaker sheet near the rear of the boat. It looks like a huge Genoa flying from a bowsprit. It has a wire luff and no hanks.
The spinnaker pole attaches to the mast, and goes straight forward under the bridle.
To keep the pole from breaking, the forward end of the pole is held down with a secondary bridle.
This sail is perfect under the following conditions.
1. When the air is so light or the sea so lumpy that the spinnaker will not stay filled. This is a very common condition at night.
2. Reaching in light winds with the wind abeam or forward of the beam. In this circumstance, the Genoa is too small and the spinnaker will not allow the boat to point high enough. The drifter is a perfect airfoil and can be carried close into the wind.
Do not use this rig in apparent winds of more than 8 knots. The pole won't take it. The sail won't take it, and the bridle won't take it.
Haul Out
If you have to haul the boat, and you don't have a trailer, be sure that the hulls are supported under the bulkheads.
Maintenance
Here are a few things to keep an eye on as the boat ages.
1. Wear on the rudder shaft or hull bearing surface. Inspect these items at least once per year.
2. Cross tube clamps. Make sure they are tight but not so tight they damage the tubes. Check them every 6 months.
3. Chafe on trampoline ropes, halyards and sheets. Replace.
4. Turnbuckles. make sure clevis pins are cotter pinned. Inspect these each time you sail.
5. Block shackles. Keep them tight and make sure each clevis pin is properly cotter pinned securely.
6. Mast tune (See prior instructions.)
7. Winch position. Make sure all winches are mounted so that the line approaches the winch from below the plane of the base of each winch. This will help prevent dangerous winch wraps. Re-bend the Genoa winch plate as required and, if necessary, put thin wood angle blocks under the other winches to tilt them in the proper direction.
8. Electrolysis on metal parts. The stainless to aluminum contact may cause problems, depending on the electrical systems carried on board. Keep an eye on the cross tubes where the shroud rings, mast hinge and clamps attach. If you see any sign of electrolysis, isolate the clamps from the tubes with a l/16th thick sheet of rubber.
9. Rigging - check for broken wire strands and replace rigging as necessary.
10. Fasteners - do a periodic tightening of all nuts and bolts.
Hose the boat down regularly and flush your outboard with fresh water. Use WD-40 on all fittings that move. Leave your hatches open as much as possible to preclude mildew.
The forward face of the cabin is slippery. It would be a good idea to apply self adhesive non skid tape on this area as a safeguard. Generally you are best off staying on the trampoline when you go forward. The further you are from the edge of the boat, the better... especially in rough weather.
Topping Lift
This is a real convenience. Fasten a 3/16 stainless cable permanently to a pad eye bolted to the masthead. The lower end of the wire should have a strong snap shackle, permanently attached. This shackle can snap into one of the outhaul eyes on the boom. The wire should be just long enough to hold up the boom and take all of the load off the sail.
Wind Indicator
Use a Windex masthead fly. They are better than any of the electronic goodies.
Bosun's Chair
If you have to go up the mast, always clip 2 halyards to the chair, and have them both manned by competent crew members. Don't trust your life to one halyard and its fittings.
Rudders
Make sure the rudders are parallel when centered--If the cross tube gets bent, it is possible for the rudders to toe in. The effect on speed will be major. With the rudders set along the centerline, the dimension between the leading edges at the top of the rudders and between the trailing edges (also at the top of the ruddersJ should be identical. If not, drill new holes in the tiller and relocate the tiller crossbar to position the rudders to a perfectly parallel position.
Pat McGrath Test Sails The MacGregor 36 Catamaran
Multihulls, Spring 76
When my wife, Jill and I were invited by Roger MacGregor to visit his plant and go for a sail on his new production cruising catamaran, we were understandably pleased. We have kept a file on the MacGregor 36 since it was first announced almost two years ago. We routinely do this with all proposed production multihulls that come to our attention, since we have known for some years now that the day would inevi-tably come when John Q. Public could buy an all fiberglass production multihull "off the shelf."
Our tour of the MacGregor Yacht production facilities, where the "Venture" trailer-sailers are made, was a real eye-opener to us. Before going into business for himself, 10 years ago, Roger MacGregor-was an administration manager for Ford, and has carried his knowledge of mass production line techniques Into his concepts of boat building and marketing . Every stage of the manufacturing is refined down to its simplest common denominator. All operations follow a flow-through pattern. Large use is madeofopensided buildings or outdoor areas, where the California climate is utilized to maximum advantage. Each part of every boat is reduced to its simplest engineering function to provide effective fabrication at the lowest cost. As a result, MacGregor has experienced the largest sales of manufactured sailboats in North America, and has survived the recent boating industry recession in good shape when many of his competitors have gone to the wall.
Down at the dockside we saw the MacGregor 36 for the very first time, and first impressions are lasting ones. We had seen many photographs and drawings of the craft, but indeed she is far more attractive to the naked human eye, than she is in any photographs, which we had seen of her. This is one of those rare boats that do not have a single ugly line, and her functional proportions make her look fast even tied to the dock.
The following day we were back again for an afternoon sail, and the M36 slipped effortlessly away from the dock under mainsail alone, and into the middle of Balboa Harbour, before the Genoa was raised for a reach out into the Pacific. Although the boat is equipped with a 10 h.p. motor, Roger does not believe in using it when there is wind, and as a result we were not able to check its effectiveness that day. The cat slipped through the water so easily and quietly that it belied the speed with which we moved out of the harbour.
This prototype was not equipped with a speedometer, and so we were not aware of how quickly we departed the harour into the open Pacific, until it became time to return later on that afternoon, and we saw how far we had come. Out in the open ocean winds were lighter and we took the helm to feel how this boat behaves. I was suitably impressed by the way she could move to windward and overtake other boats sailing in the area, but since this was a typical Californian after-noon, we generally enjoyed lazying around the boat, pointing her in different directions, tacking, and generally getting the feel of her.
The prototype boat we were sailing had standard tiller helm and we found this completely neutral with no tendency to develop either weather or lee helm under the light conditions response was immediate when the helm was moved, and there was never any doubt about the boat's ability to tack. In fact her tacking ability was as good or better than any catamaran that I have ever sailed and all her movements were smooth, purposeful and positive. Fore-and-aft trim was particularly good and she appeared to have no sensitivity in this regard. The crew were able to lounge around any-where on the boat they pleased. Even a critical helmsman would not feel the need to tell crew members to move to any particular part of the boat to Improve trim.
A spinnaker of about 1000 sq. ft. had been borrowed for this afternoon's jaunt. Setting this and reaching back towards the entrance to Balboa Harbour occupied some time. At this point we sighted a Tornado heading in the same direction. Well, as you know, when two sailboats are heading in the same direction they are considered to be racing. So from here on in it was a challenge who was going to reach the other end of Balboa Harbour first. The Tornado was about 400 yds. ahead entering the harbour, and as we turned to enter ourselves the wind came dead aft. The Tornado immediately started tacking downwind as this Is the "hot cats" favorite technique of moving fast off the wind, but Roger felt that as a cruising catamaran we would have no advantage doing likewise. Soon we had to turn a corner and were reaching with a rather full spinnaker. Another corner required a spinnaker jibe and further spinnaker reaching. We were gradually gaining on the Tornado until finally we reached the moorings at the northern end of the harbour. Yours truly was on the helm and found himself threading between moorings and boats with literally feet and inches to spare on either side. Here was a situation where any boat, if it has any weaknesses of steering or control would show up to catastrophic disadvantage, but the MacGregor 36 indeed came through with fingertip precision as we threaded our way through this mass of boats. We also passed the Tornado a couple of hundred yards before the head of the bay.
To say I was impressed would be an understatement. The spinnaker was dropped, the Genoa was re-hoisted, and we sailed back up to windward to Roger MacGregor's home dock. Here we were treated to an experience which I had never encountered before in twenty years of sailing. As we approached the dock, Roger at the helm headed the boat up into the wind and the Genoa was dropped. From perhaps 50 yds. out Roger then proceeded to sail the M 36 backwards, under perfect control, directly into his boat slip. A better display of helm and rig balance I could not imagine.
Jill and I were leaving for Australia to see the "Little America's Cup" races, but we promised to be back in two weekends' time to sail with Roger in the Mid-Winters Multihull Regatta on Santa Monica Bay in order to give the boat a proper shakedown. Accordingly we rejoined the M 36 and her skipper at the Playa del Ray Marina, in Los Angeles, one Saturday morning two weeks later, and motored out to the starting line in the company of such illustrious "ocean greyhounds" as Allez Cat, Hiolani, Polyne-sian Concept, Seasmoke, Imi Loa, Imua and half a dozen others. The MacGregor 36 moved out smoothly under the power of her 10 h.p. motor, and I cannot imagine why anyone would need a larger engine than this. The motor was mounted on a standard lifting bracket, attached at the Inboard side of the starboard hull. Apart from a larger than normal cavitation plate affixed to the lower unit, no special, or abnormal mounting arrangements were employed.
Coming out of the mouth of the harbour into the Pacific there was only a light wind, but large Pacific swells. Under these conditions the M 36 moved easily and smoothly with minimum of splashing. At this stage there was no water on deck or the trampoline, the moulded in splash rails on the sides of the hulls prevented this. Later on when the rising wind turned the swells into hard edged waves, spray did come up through the forward netting and occasionally up through the center lacing of the trampoline. MacGregor says the production version has a flap under the lacing to prevent this. Water did not collect on the-tramp deck, however, and the airflow over the boat rapidly dried the trampoline. Even when the spray was flying it was comfortable and dry to sit up against the windward cabin side, or to lie in the tramp, facing the helmsman, with head and neck on the main crossbeam. A lot of people who sail on boats with **** seats and hard decks cannot appreciate the comfort of lounging on a soft trampoline, and of the effect of spacious security which it gives.
On this prototype the daggerboards were arranged in such a way that the port board would rotate about 8ø in its slot. On either tack the board would have a positive angle of attack, relative to the centerline of the hull of about 4ø. The starboard dagger was a normal installation. A lot of time was spent trying first one board and then the other on windward legs, to see if there was any obvious difference in leeway or performance. If there was any, we were not able to discern it, and not surprisingly, we found the cat went to weather best with both boards fully down. In the production version the boards will be accurately formed to the most effective profile. They will be non-tacking, and will extend through the bottom of the hull in a massively reinforced area. The slots will be profiled closely to the shape of the board in order to reduce turbulence to a minimum where the board protrudes through the hull. In the light of current foil technology this would appear to be the best decision, being simple, effective and most important, less expensive!
One of the problems of designing a production catamaran is that it cannot be assumed that all the new owners will be experienced hotcat' sailors. The last thing a manufacturer wants is for his beautiful creation to become labelled as a "killer boat" in the hands of inexperienced yachtsmen. The M 36 started out with a 50-ft. rotating mast carrying a high aspect ratio, fully battened mainsail, with a small roller furling jib: like a giant "Tornado" rig. It was the most exciting thing I had ever seen, but it also made my hair stand on end when I tried to imagine handling that monster in rough water and heavy, gusty conditions. Since that first design, Roger MacGregor's boat has gone through six rigging changes, four different sail plans--and a lot of fingernails. The result, not unexpectedly for a cruising boat, has ended up as a perfectly conventional sail plan in the best I.O.R. tradition. A smaller main, little roach, short battens and large overlapping Genoa; all held op on a 43-foot non-rotating mast. The result is pleasing to the eye, easy to handle, efficient and, once again, economical. The mainsheet is on multiple blocks, attached to the non-rotating boom, and the roller bearing car runs on a traveler track extending to the full width of the boat on the aft cross-tube. The boom gooseneck is bolted directly to the mast, so luff tensioning is taken care of by a Cunningham downhaul. "Slab" or "Jiffy" reefing is done in the normal way by easing the hal-yard. Two-speed Barient sheeting winches are standard. Spinnaker gear is optional, and if the Mac-Gregor 36 is to be used for racing, it is an essential option. Until now we may as well have been sailing on a big and heavier "D" class daysailer. But after lifting up the cabin tops, all this changes.
The after bunks are just that. Places to sleep. They are wide, long, and have just enough headroom to enable a crewmember to sit up, sort of. They are real bunks. Thirty-seven inches wide and eight feet long, they have plenty of room for personal kit storage, and are the quietest place on the boat. The forward bunks are something else again. Thirty-nine inches is considered the proper width for a double bunk in a seagoing boat. Anything wider is untenable in a seaway. Four foot wide beds only exist in houses and floating gin palaces, and are only usable when tied up in a slip or on a quiet mooring. The MacGregor 36's forward bunks taper gently from 3'3" toward the bow, and are nearly 10 feet long. There is stowage space behind the daggerboard case which is on the inboard side of the hull, and aft of this will be a complete galley in one hull, and a navigation area in the other. The bows and sterns, the volume under the bunks, the cross tubes and the spars are filled with foam, which makes the boat unsinkable. Should the boat be completely flooded, the hulls are self bailing to the level of the bunk bottoms, merely by unscrewing removable plugs. The remaining water in the main cabin would be about calf deep and would have to be pumped or bailed out in the usual way.
A cleverly designed toilet is concealed under the companionway step of one hull, and a cooler under the other. Interior finish is bright in the Macgregor "Venture" tradition, with a complete fiberglass liner, striped cushions, shag carpet - the lot. You either like it or you don't. Personally I would like to see more light in the cabin, and particularly in the forward bunk. With the "lid" closed, the one small window might make some people feel a bit claustrophobic, and a little more light further forward would enhance the usefulness of the gorgeous great bunk, and make a wonderful place to hide away and quietly read a book when solitude is required. The MacGregor 36's lack of pitching, due I believe to Its more full ends than most contemporary catamarans, and its quietness, due to the massive use of foam flotation, truly makes this forward bunk area a comfortable place to be. Finally, the great asset of this type of catamaran is on lazy summer afternoons, with the pop top open, the optional canopy rigged over the boom to keep off the hot sun, but let in the cool sea breezes. Gunk-holing, quiet cruising or gung ho racing are all possible and compatible with this new catamaran. I, for one, think that Roger MacGregor has got himself another winner!!!!!
Thouse- thanks for the excellent information on the boats. I've saved it to the little research folder I've made.
As for what consitutes a "cheap" Mac36: $4000
Hulls (interior stripped bare), standing rigging, mast, boom, x-beams, trampoline all in good shape. New rudders, but no dagger boards or sails. Comes with a trailer that is a bad fit but in good shape.
Gotta sell my truck and go across the country to get a good look at it
(selling the truck anyhow)
Come to think of it, this sounds suspiciously like the boat you were looking at a while ago for $3000. The company that has it says they took it in trade.
That does sound like a boat I traveled from Utah to Marina del Ray, California to look at last summer....but there are probably a number of Mac 36's like that scattered around, here and there. I've seen some costing as much as $47,000 (or more).
Great boats..!
I've seen a number of them still in use, lookin good and sailing fine, in southern California, in Mexico's Yucatan and one guy is running sailing/whale watching tours in Rocky Point, Mexico.... (great guy)
I don't know if you've found these other sites...if so, great, if not, here they are:
http:/
http:/
Also, if you have the interest or need, I've found an original Mac 36 owner's and assembly manual. Though I've misplaced the web address I do have the manual copied as an Adobe file that's emailable.
If you want it, give me an email address and I'll send all 27 pages or so...and if you don't have Adobe, it's available on the web for free....
The manual is pretty interesting reading and goes through the assembly and disassembly process (sep-by-step), rigging, tuning, self recovery from a capsize, etc.
Have you looked at any of the other demountable and trailerable larger cats...like Viva 27s, Stiletto 27s, etc.
They are not Mac 36s but every now and again, there are some "killer" deals that come up and some "deals" are in sail-away shape, with road-worthy trailer....if you keep your eyes open, have some patience and are ready to make it all work before someone else shows up.....
What caused me to not go for the Mac 36 I found...and got the guy to go down to $2,000 cash.... was my wife....!
But, she had some valid points....
Fixing up the trailer or buying another would add another $1,000 or two ....adding or finding this or that would add more $$$$ and so on.... plus she wanted to sail sooner than I would be able to actually refurb the boat and make it seaworthy...
(Don't ya just hate a wife that wants to buy a cat and go sailing...and right now...???)
When all was said and done...we found a boat (Stiletto 27) in sail-away condition, road worthy trailer, large sail inventory, and bunches of this and that boat stuff -hardaware- furler- etc.... for around $10K.... (which I thought was much less than I would have spent in time and $$$ to find, make or repair things for the Mac 36) ...but we had to drive $3,000 miles to get there and back.... and not counting the other trips we took looking at boats.... before we finally bought the one we now have...
But all were good trips as was is was the fun trip we took to Mexico, even if we hadn't decided to grab that Stiletto....
Best of luck and I'd be interested in hearing how your search progresses and what you finally end up doing...
Tom, your wife sounded like mine, I almost bought a fixer-upper but did much better finding a deal. Cleaned the bottom, put new anti-fouling paint and put it in the water. Ya don't do much better than that. Oh I drove only 1800 miles round trip to get it, nah, nah
later,
Clayton
BTW hows the roller furling? I would like to put that on mine at some point.
Clayton, nice to hear from you ...
As for the furler, well that was a bonus I didn't know about.
After I bought the boat and towed it back to Utah from Mexico, I took it on a trip to southern California and a sail to Catalina Island. The wind was light and we decided to hoist some of the sails that were stuffed in one bow and see what they looked like. One of those was a mast head (sc)reacher and to my delightful surprise, at the bottom of the sail bag was a new furler, minus the 1/4 inch line that wraps around it. When I got back in from the day sail I made straight for West Marine and bought the furler line and had to smile when my wife protested the $40 cost of the 1/4 line. Obviously she hasn't spent much time looking at catalogs and the cost of a furler system. On the other hand, the next day of sailing in the same light wind conditions, but flying the reacher, produced much more boat speed and gybing is a breeze, when we furled the sail and then reset it on the other side.
The reacher (by the way) performed very well going to weather and helped increase boat speed, if we didn't pinch too hard.... if we did, the boat went better under main and jib alone.... but once again, it was simple to experiment, when one only had to pull a line and the reacher just vanishes as it furls.
We didn't push the reacher very hard because I still have to buy a fitting or two to install the running backstays... and without them, I opted not to see about flying the masthead spinnaker, to see how that goes....
Well, back to work for me... and after another weekend or so.... I should be finished with repairs on the Stiletto's trailer, installation of new hatches and getting it all registered for the year. Then we'll put it back in some water and see how those back stays and the spinnaker look.
Have you begun sailing your boat this season?? …or do you sail year ‘round in south Louisiana ???
Thanks thouse, I hadn't noticed the pictures on that first page before. I have noticed, however, that there is extremely little information on Mac Cats on the internet. I'm hoping to repair and sell my '74 Seafarer 24 (with it's never-seen-water trailer) this summer, to pay for new sails and gear for the MacGregor (and the G-Cat!) if I get it.
I'm not really interested in the Stilettos as I'm looking for something a bit bigger and more off-shore capable. My dream-cat is the G-Force 36 Sport-Cruiser, of which I know only one in existence (and they're not selling)! I also don't mind taking a year or so to fix and outfit a boat.
I had a Mac and loved it. We raced it in the Biscayne Bay area and won almost everything we entered. It was an early model with just one daggerboard.., and a pretty short one at that.
Our closest competitor was a Condor 40. We would take them downwind, but they would beat us upwind. That was until I replaced the daggerboard with a Formula 40 board, and then it was all Mac.
The first thing we did was redo the gelcoat bottom with epoxy.
They are a bit heavy but it always felt solid, so no gripes there.
Good luck,
Rick
I believe the pre 1980 boats had one board, the 1980 or maybe it was the 1981 had two, was MUCH lighter, and sold with Spinnaker, motor, trailer and Main, Jib, Genoa, cushions, and spinnaker gear for $27,000.00 give or take a few thousand. We had to have close to 20 knots of wind to get a hull up on the older boat, and it was a dog, relatively speaking. The newer lighter one would get a hull up in about 12-14 knots and felt much better balanced.
- 5,799 Online
