Kiwi F12 Build Pics
Hi all,
sorry for being quiet for a while, as stuff crawls to a stop around Xmas, but things are picking up now.
The attached pic's are from Billy & Grahame's project in the North of NZ and they are building 4 boats, 2 for each of their kids. Pictures should be pretty self explanatory and are in sequence. The first boat should hit the water in about 6 weeks....we hope ?
For those not familiar with the project, we elected to make foam/e-glass panels that will then be tabbed together in the jig rather than make it from plywood.
Cheers
RG
Another Update:
Roughly speaking, it has taken 1 day to cut the foam templates, cut the foam cores and join them and get 4 panels laid up (3 people). It took another 2 nights of 2-3 hours for 2 people to lay up another 4 panels per night. To separate and trim the panels took 2 people 1 day and get them ready to be tabbed in the jig. In total it took 4.6 sheets of foam to do all twelve hull panels for 2 hulls.
First pic is adding the cleats to the frames, these are hard wood so we can staple the hull panels in place. Do not staple into the MDF frames as after 2-3 boats the frames will start to fall apart.
Cheers
RG
The slits in the bottom panel are so the panel can be curved into shape in the jig. After its in place and tabbed to the other panels, you fill the slits and glass over it. A grinder disk on edge was used to make the slits.
Thats it for now, with luck we will be able to show the finished half shells by next week sometime.
Very interesting. I had never heard of the guy, yet he lives just 30 minutes up the road from my parents.
http://www.kelsall.com/methods.html
Update:
Billy & Grahame now have 4 half shells done (1 boat) and perhaps 1/3rd of the panels laid up for the other 3 boats they are doing. There are 12 panels plus bulkheads per boat, so when you can only layup 4 at a time, it tends to slow things down a bit.
With luck, Billy will post a pic of them holding a couple of hull halves together, thats about as close as you'll get to a finished hull pic.
Gato, apart from the Class fee of $50, the plans are free.
Cheers
RG
![[Linked Image]](http://www.catsailor.com/bb_files/136063-05.jpg)
- 1,337 Online
