Planning the F14- Step 1-b: Mainsail design
(@gcat18)
[#13458]
I want to start getting some prices from various lofts on the cost of sails- especially the mainsail, as this will be the most similar sail on every boat.
First- Boom or Boomless? Most racing boats go with booms for the added tuning ability. The Mysteres are running boomless and don't seem to mind at all. I personally prefer a boomless sail, with a stiff lower batten and an inhaul from the tack to the clew to adjust the flatness/fullness of the sail.
Second (because it is dependant on the condition above)-with a 24' mast, how long can the luff of the sail be?
Third- how long should the foot of the sail be? Mostly, this depends on the location of the mast beam- but with a boom, the sail could extend past the aft beam.
Posted : March 21, 2004 9:12 pm
(@Anonymous 37755)
First, after trying both systems, I am going with a boom. It gives much better sail control and reduces sheeting loads.
The big advantage of a boomless boat is it sets itself going upwind but it is never sets itself quite right. Also, booms are expensive figure $500 retail or $150 if you build it yourself.
For foot lenght, the practical limit is about a foot aft of the traveler.
For efficency the foot of the sail angles upward (~30 deg). With long booms you get into diminishing returns plus it starts looking a little odd
As you sheet ou the CF moves aft. The CF runs from ~1/3 - 3/4 the boom lenght from the mast. Don't let the CF get too close to the rudder. I have only sailed one boat whose boom extended significantly past the rudders and as the owner warned me "don't sheet out too much in a puff, it gets strange"
Long booms are just awkward.
Posted : March 24, 2004 9:26 am
(@Anonymous 13274)
Take a look at this shot from a race here in P'cola last month. I was amazed how long the boom is on Bob's creation - for comparison, look at Sue Korz's 16 in the background... both appear to extend aft past the rudders...
Posted : March 24, 2004 9:44 am
(@Anonymous 13274)
here's a shot of Rod Waterhouse in the same race - notice the Nacra 20's boom is barely aft of the traveler, but the sail is well inside even that. Hobie 14/16 = long boom aft of traveler, Nacra = shorter boom, even shorter foot... I suppose there is some physics in there relating to hull shape and some other stuff too, eh?
Posted : March 24, 2004 9:59 am
(@gcat18)
OK, I can settle with a boom. I think H14 booms would be fine to use, as you don't have to have a sail that slides inside the boom along it's foot.
What else, besides old H14 mast sections, would make good booms? Surely there is a cheap way to cobble together an effective piece of equipment.
Posted : March 24, 2004 12:21 pm
(@_removed-account)
Four Star Admiral Registered
I wouldn't use a mast section, that would be way too big. A regular H14 or H16 boom would be easy to find and should work. If you are looking for a stock extrusion, the H17 boom is nice and small. They are pretty hard to find used, though.
If you look at the A-cats, they have a really small aluminum, fiberglass or carbon boom. The blocks attach where the leech attaches to the boom, so the boom is really only there to hold the sail out where it should be and to give you some foot adjustment. They also have a semi-circular or elliptical traveler, so the force is always pretty much straight up and down compared to the angle you get on boats like the 14 and 16.
The Hobie 14 Mylar square top sail I ordered from Sabre came loose footed. I expected it to be footed like Bob's, but it wasn't and I'm pretty happy with it. I can get a really nice shape out if it after a little boom modification. I took the outhaul adjustment from a Prindle 16 and installed it on the 14 boom. Works great and is easy to adjust. Just another idea.
Posted : March 24, 2004 1:25 pm
(@Anonymous 672)
Quote
The boom on a Taipan is simply some aluminium tube with fittings attached. These are lightweight and would be very easy to make at home. There is very little load on a Taipan boom as the mainsheet blocks are attached to the clew of the sail rather than the boom. The boom is used to adjust the location of the clew so the only loads are basically compression. There are blocks and a cleat attached to the boom to enable outhaul adjustment and a sort of universal joint where the boom attaches to the mast. The sail is loose footed of course. Depending on the set-up there is also attachments to the boom for over-rotation control.
The first photo below shows the rotation control and the 'universal joint'. The universal joint is simply an aluminium block with two holes in at right angles to each other and at opposite ends of the block. A bolt runs through the boom and through the block at one end and the other end of the aluminium block is attached to a bracket on the mast with a pin. The block is able to move up and down within the boom. There may be some spacers and bushes inside the boom - I've never looked.
The second photo shows the outhaul. There is a pulley attached to the clew which is a little difficult to see in the photo. This setup gives a 3:1 purchase on the outhaul. The outhaul line goes through the inside of the boom and exits about halfway along where there is a cleat. Not shown in either photo.
I hope this is of some assistance.
Rob.
Photos courtesy of F16 website: http://www.geocities.com/F16HPclass/
[Linked Image]
[Linked Image]
Posted : March 24, 2004 9:41 pm
(@gcat18)
I'm afriad the photos didn't work, but the description was very precise. I think I could build one from your description and my imagination- thanks a ton
Posted : March 25, 2004 9:07 am
(@mystere50xl)
The photos come up if you wait a bit. However, the complete link to the page with those photos is
Taipan 4.9 Rigging Info
Posted : March 25, 2004 9:17 am
