Secret weapon
Dan, I see that you have both a reacher and a jib. On a previous thread, Bob discussed his sailplan.
Bob, I seem to remember that a few years back you cleaned up on the H-14 Turbo crowd by furling your jib upwind. Would you WANT to add the jib to your Maxi? Does the Blaster alone give you all of the headsail you need? Would the added jib be worth the extra complexity, hardware, weight, and cost?
The first version of the boat didn't have a jib, and it worked pretty well. The only reason I set it up like that was because I was planning on racing it Portsmouth. I would have taken a bigger hit racing it as a Turbo with Headsail than as a uni with headsail. I'm also planning on leaving the boat on the beach with a bunch of other 14s so we can do a weekly series thing. All the boats are going to be Turbos, so I needed to add the jib, anyway. I also just wanted to see if it helped or hurt any.
I looked into a self-tacking jib, but just didn't want to mess with it and didn't want to spend the money.
I have a feeling that Bob is being quiet about the jib thing because he thinks it is too much. Like I said, I'll be chasing him around, anyway.
Actually, those are the ultra-new, super-secret experimental, STEALTH rudders. You can't see them until you trip over them on the beach. They are a bitch to find if you drop them in the water! I'll be sporting the regular type at Hartwell and Hartsville--y'know, not to have too much of an advantage.
- 6,494 Online
