Blade building project..
18 Users
111.2 K Views
(@Anonymous 13024)
I did some quick estimations today on building time in strip:
Planking 5 hours, when done alone.
Sanding the inside and outsite 2 - 3 hours.
Glassing inside and outside 3 + 3 hours
5 + 2 (3) + 3 + 3 = 14 hours for one half hull panel. Scary stuff!
Posted : December 17, 2008 3:59 am
ncik
 ncik
(@nickb)
That sounds in the ballpark for my build.
Posted : December 17, 2008 5:50 am
(@Anonymous 13024)
Add overhead in setting up the mould, ripping strips etc. and plywood begins to look good <img src="<>/wink.gif" alt="wink" title="wink" height="15" width="15" />
Posted : December 17, 2008 6:13 am
(@Anonymous 14038)
Rolf,
Just got back from Sydney with ply and cedar to build another boat. Just for the fun and interest of building using the same method as some CLC18 kayaks I built a couple years back.
If you keep tallying up the man hours we can compare notes when we are both finish.
Phill
Posted : December 17, 2008 9:09 pm
(@Anonymous 13024)
Will try to keep a tally on the hours. Speed and quality have improved a lot on the strip planking, but the sanding is the same old drugde. Funny thing that became very clear last night is that company dont help everytime. I planked panel #5 alone up til last night, and it is the best panel (planking wise) so far. Last night Frode and I chatted a bit while I put on a plank.. Lo and behold, a really ill fitting plank was the result! Strip planking is best done solo on small crafts like this if one wants the best results.
Posted : December 18, 2008 2:36 am
(@Anonymous 14038)
Rolf,
I planked a set of 32ft cat hulls myslef.
It is very relaxing work when not punching a time clock which is the way I feel when someone helps because I'm using up their time.
On the other hand the fairing was a real pain but the planking was great.
So you can probably do Ok on the bigger stuff too.
Phill
Posted : December 18, 2008 9:41 am
(@Anonymous 13024)
I have no experience with larger boats, but that is nice to know. I think the planking might be even easier on a larger hull? I have told you about my/our dream of doing a larger boat in the future..
Anyway, I can see how some get obsessed with strip plank and begin to build hulls without staples. Fitting just one plank each night etc. It is a bit like zen and quite relaxing. But one must use it as therapy I think, not to get a boat to sail/race if that approach is to be successful. Perhaps I should have as a goal to do one boat/kayak/strip plank project every winter, to shorten the winter and as therapy. Install enough lighting and I can use the time in the workshop as
light therapy
against winter depressions: http://en.wikipedia.org/wiki/Seasonal_affective_disorder
If only there were less sanding involved <img src="<>/wink.gif" alt="wink" title="wink" height="15" width="15" />
Posted : December 19, 2008 3:03 am
(@Anonymous 14038)
Rolf,
Yes it is the Zen concept that turns this into great therapy.
Wash the dishes for the sake of washing the dishes not for the sake of getting them clean.
Fit the plank for the sake of fitting the plank no for the sake of building a boat.
To this end, if you have the space, maybe build one large project may be better than a small project each winter.
I have got a lot better at fairing since I built the Alfresco 920 hulls. So much water has gone under the bridge in the last 15 yrs. I would love to build another cedar strip boat.
Each to his own.
Phill
Posted : December 19, 2008 3:58 am
(@Anonymous 13024)
I will get back to you on the
best practice
to do the fairing as painless as possible when we do the underwater hull or decides to paint our boats!
I dont have the space to do the large project just now, and I dont think the family is ready for me spending 2000 hours on a boatbuilding project over several years either. I know I will have to sell in that thoroughly so there is no hard feelings for me occupying the garage.
Will have to practice our zen a bit careful for the next few years at least. <img src="<>/laugh.gif" alt="laugh" title="laugh" height="15" width="15" />
Posted : December 19, 2008 4:22 am
(@selfinficted)
Hi Phill
You now use the more practical way of fairing a belt sander and for those finer points a normal palm sander,So fairing a bigger boat will be a lot easier ( i told you you get better with practice). LOL.
Posted : December 19, 2008 2:21 pm
(@Anonymous 13024)
Hey, that is what we are doing as well (I am the only one in the group who dares to apply the belt sander): http://woodastic.blogspot.com/2008/03/repeat-until-done.html
I use an orbital sander afterwards with a soft foam pad. Then a quick run over the hull panel with a torture board. Thinking is that we will fair the underwater hull
the hard but proper way
with fairing compound and put on some graphite when time permits.
Posted : December 19, 2008 2:55 pm
Bob Hall
(@brghc)
It’s definitely not the Zen way to do it…but if you want to “gett’er done”…A low speed (under 1750 rpm) heavy duty sander/polisher with an 8” diskkit is much faster than a belt sander but it requires a very skilled operator…lack the skill, choose the wrong grit paper, or stop for in instant in one spot and you will have major problems...In the right hands it will cut your time to a fraction of what a belt sander will take. In the wrong hands it will destroy the fairness of a boat in minutes. You have to constantly stop, step back and LOOK at the work.
When I was building custom million dollar yachts (65’-105’) in the eighties the only thing we used belt sanders for was sharpening our wood chisels when it was too far to walk back to the shop to use the bench grinder…LOL. Sander/polisher> 6” DA> long board…The awl grip hulls of our boats were like a mirror.
Posted : December 19, 2008 3:06 pm
(@selfinficted)
Hi Rolf
When i was finishing off my first boat,Phil went into panic mode when i mentioned the belt sander,and as he said alot of water has gone under the bridge and with practice you do get better Ha Ha. But he still does cringe a bit when i mention the B word.And as for stripping paint(industrial 2 pak) you can't use anything else.
Posted : December 19, 2008 3:07 pm
(@Anonymous 38725)
Rolf, just sent you a Private Message, thanks. Tim
Posted : December 19, 2008 3:16 pm
(@Anonymous 13024)
The key to using the belt sander is to never ever stop moving it around, and run it paralell to the fibers, never across. That is my technique, and minimizing stops/starts, as they always seems to leave a mark.
How many watts would a
heavy duty polisher/sander
be? What is a 6" DA?
Posted : December 19, 2008 3:45 pm
(@Anonymous 14038)
Bob,
That method worked well on the inside of the 32ft cat hulls I built. Hell that was nearly 20 yrs ago.
I tried to upload a pic of the inside of the hulls but that has changed with the new upgrade. Looks like you already need the pic on a server ?
Posted : December 19, 2008 3:46 pm
(@Anonymous 39155)
Originally Posted by Rolf_Nilsen
. . . What is a 6
DA?
Dual action sander. Circular or random orbit. The 6
DA is a very powerful tool for working large areas. There is also an
inline file
; air driven version of the long board, for finer work.
Posted : December 19, 2008 4:07 pm
(@Anonymous 14038)
Rolf,
I used the belt sander on the outside of the Alfresco 920 @90 deg to the planks and it worked well. Although the fine cedar dust used to get into the sealed bearings and I went through two sets of bearings in the sander. Using 90 deg probably wouldn't be suitable on thin planks as it rips the wood back pretty quick.
The sander polisher, I used on the inside and it worked great, It had a foam disk of around 7 or 8 inch dia.
Richard,
The belt sander is all very well on cedar planks that are 11mm thick but when you pull out a belt sander to use it on ply hull where the first laminate in the ply is around 1mm thick. I can't help myself.
Posted : December 19, 2008 4:22 pm
(@selfinficted)
Phill, I just like to do it to get the horrified look on your face,and agreed Rolf if you stop you end up with an inspection hatch that you don't really need
Posted : December 19, 2008 4:41 pm
(@Anonymous 13024)
Sleeping less means more building done at late nights. Panel #5 (of 12) is now almost ready for sanding and glassing. Love christmas! http://woodastic.blogspot.com/
Posted : December 26, 2008 6:27 am
(@jalani)
Merry Christmas to you Rolf! <img src="<>/smile.gif" alt="smile" title="smile" height="15" width="15" />
I really enjoy reading about the progress you have made each couple of weeks. Glad too that it won't be long before you can start on the 'other half' of each hull. I think that once you've got even one pairofhalves joined and bulkheaded you'll start to feel so much better about the project. Great work! <img src="<>/cool.gif" alt="cool" title="cool" height="15" width="15" />
Posted : December 26, 2008 11:08 am
(@Anonymous 13024)
Quote
But I am having a great time now. It was harder last spring when I realised there would be no cat sailing that summer and not much building either (wifey projects). Cleaning up the workshop and investing in a proper vacuum cleaner also helped a lot on motivation to get down there at night.
Plan is to NOT assemble the halves into hulls before we have all parts. Only when we have the parts to go into the hulls will we do that. Assembled hulls take a lot of room vs. stacked panels, and we need to keep the drive on! Hope I get to pull panel 6 off the mould during christmas!
I sometimes tries to put the project into perspective. Building a strip plank kayak is a major project for many, we have done the equivalent of about five of those. On the other hand, compared to building a large boat or a house, this is peanuts..
Posted : December 26, 2008 1:02 pm
(@Anonymous 14038)
Richard,
Does this make you feel better.
Helps in finishing after planing scarf joints.
[Linked Image]
Posted : December 29, 2008 11:46 pm
(@Anonymous 13024)
Hm, the last time i scarfed plywood, I sanded the whole scarf for lack of a good plane.
Is that a small void I see in the scarf in the top sheet? Is that
real
BS1088 ply? Do you know if the middle layer is also gaboon/okume?
Posted : December 30, 2008 3:49 am
(@Anonymous 14038)
Rolf,
You seem to be able to see something in the photo that I didn't see in the workshop. Having said that the ply we get here now comes out of China and it is not as good as the stuff I used to get out of Holland.
Still, I'll see if I can make the silk purse from a sow's ear.
Phill
Posted : December 30, 2008 4:16 am
(@Anonymous 13024)
The fat from the christmas food might have gone to my eyes.. Good luck with the purse. Leather can be very nice if worked long enough.
Posted : December 30, 2008 5:16 am
(@Anonymous 14038)
Rollf,
I will work it as long as needed but with the backlog of projects I have I can't take too long.
Posted : December 30, 2008 6:15 am
(@selfinficted)
Originally Posted by phill
Richard,
[Linked Image]
Hi Phill
I think you are just stirring now
I don't think there is any sand paper on on it, just trying to get a good picture
Posted : December 30, 2008 2:50 pm
(@Anonymous 13024)
In three days, we have busted our DeWalt circular saw and our chineese beltsander. We are making good progress, but breaking equipment is a downer. Ref: http://woodastic.blogspot.com/
Posted : January 1, 2009 5:03 pm
(@Anonymous 13024)
Well Phill, if you thought the belt sander was bad, you will be interested to hear that I did parts of panel #5 with an angle grinder and a coarse cleaning pad <img src="<>/grin.gif" alt="grin" title="grin" height="15" width="15" />
I used it to remove most of the epoxy on the panel left after gluing the strips. Quick and easy, and not too risky either in my opinion. Sanding with the beltsander and the foam pad was much quicker and I got down to the stage where I can begin using a fairing board pretty quick compared to earlier. Not for the faint of heart or the Zen builder though <img src="<>/grin.gif" alt="grin" title="grin" height="15" width="15" /> <img src="<>/grin.gif" alt="grin" title="grin" height="15" width="15" />
Posted : January 3, 2009 5:48 pm
Page 3 / 4
