Hobie 18 mast on F16?
Heavy and not a wing mast. I'd think you would have trouble getting a proper sail shape without having sails made to that mast as well. I don't know about length, if it's too long that's easily remedied.
I'm assuming by your name it'd be a euro mast, so there wouldn't be the comp-tip.
Just my opinion, but I think you'd be creating more work than you would save.
If you are scrounging and building to save money, go for the TheMightyHobie18 mast and upgrade to a carbon mast later on as an option.
If you want to purchase used sails later on, you should aim for a APHC wingmast.
If you are going to build your own sails as well and are extremely into saving money, go for the TheMightyHobie18 mast or any rotating beachcat mast you can scrounge. Should still be some alu Tornado masts lying around after the switch to carbon masts in the T-class (I have two in my garden and one at the club).
Depends on your wants and needs <img src="<>/smile.gif" alt="smile" title="smile" height="15" width="15" />
Kofi,
from what I remember there was a constraint in the rules on how much curvature the beams could have. You are indeed correct that the class rules available on the ISAF website there is no constraint on this. Must have been changed as the F-16 class went through the ISAFication process.
woa dont put an TheMightyHobie18 stick on f16 , sacralidge !!!!!!!
I got just what you need , an alluminium piet saarburg taper top A class mast , I asked Piet if it would take a spin and he reckoned ok . It would need cut down a wee bit , but its a proper wing section ,
Its off an A Class I built that got trashed so hardly been used
got A class beams too for ultra narrow f16 <img src="<>/wink.gif" alt="wink" title="wink" height="15" width="15" /> straight , with radiused main sheet track , other kit too , rudders , tiller bar , hot stick (off hurricane 5.9) , tornado main cut to H5.9 size , could be cut again to f16 ???
even got a couple of tomcat hulls you could cut skegs off and turn into f16 , or leave on for a schrs bandit , you can have them free with mast .
Tomcat was john pierces version of a training cat , he put skegs on stealth hulls .
aint it strange how someone starts a thread like this , someone offers exactly what they NEED , mast that is , and its a keeper not a stop gap , low price and available in same country whilst being rarer than hens teeth ,
an all goes quiete. <img src="<>/smile.gif" alt="smile" title="smile" height="15" width="15" />
the rest i have is a bonus !
- 3,738 Online
