Length side stay's at taipan 4.9?
2 Users
geert
(@geert)
[#9787]
Hello,
Does anyone know the length of the sidestay's for a Taipan 4.9, and how it this measured?
It appeared the stay's were gone where I left them in the winter, so I can't check the length by myself.
Btw, I use the regular pin/hole adjustment at the hull/side stay.
Thanks in advance,
Geert
Posted : April 14, 2002 3:45 pm
(@Anonymous 14038)
Geert,
When measuring stays the only reliable measurement is between bearing surfaces of thimble or holes of fitting at each end of stay.
According to my plans the side stays are 6120mm and the forestay is 5570mm.
Hope this gets you on the water.
Phill
Posted : April 16, 2002 6:33 am
geert
(@geert)
Phil,
Thanks for your answer, sure it will help
Geert
btw, I finished may trailer, according your setup, works nice!
Posted : April 16, 2002 3:46 pm
