Linking up teams with boat makes
11 Users
15.9 K Views
(@wouter)
[#28775]
Dear all,
I finally had a few hours to myself in a very long time and decided to pick up my old hobbie.
With the various reports and pictures I was able to compile this listing that connects teams with makes but I'm still missing a few combo's. Can anyone help me out with the last few white spaces ?
The names in red are first 3 youth teams
[Linked Image]
Posted : February 4, 2012 3:20 pm
(@_removed-account)
Four Star Admiral Registered
Couple of data points... I can confirm Reiss and Chu on the Viper - photo here . And from this video it looks like Bello and Brown were on a Falcon, not a Viper.
Lots more photos here and here that you can probably mine for further details.
Posted : February 4, 2012 8:10 pm
(@Anonymous 40937)
Sarah and Matt were on a viper as well.
Posted : February 4, 2012 8:24 pm
 Karl
(@sogncab)
Knox, and Enrique were both Vipers.
Posted : February 4, 2012 8:39 pm
(@_removed-account)
Actually now that I look at that video again I think Bello and Brown probably were on a Viper. My mistake.
Posted : February 4, 2012 8:40 pm
(@infusion753)
David Hein on a Viper
Posted : February 4, 2012 10:37 pm
(@wouter)
In the fotos there is also a male-female (Blade ?) team that I can't identify, see this picture
http://www.photoboatgallery.net/p385679448/h119c4259#h119c4259
Additionally there is at least one Taipan on the course that remains illusive
Wouter
Posted : February 5, 2012 4:04 am
(@wouter)
I also looked over the second series of pics and this is what I have so far. The purple and blank still need to be confirmed.
Looks like a fine mix of boats, indeed !
I'll allow myself one non-impartial remark. 6 non-Vipers in the top 10 with with 2 Falcons in top 3. Seems that the fleet is balancing out a bit after the last 18 months of Vipers dominating the top places. I'm sure that is also to some degree due to Falcon marine setting up their coaching program (as Vipers did a while back). Well done Matt and John !
[Linked Image]
Posted : February 5, 2012 4:38 am
(@Anonymous 38725)
Wouter, Seth and Tina were indeed on a Falcon, that's one of your purple people on the list.
And JC on day two was 2, 2, 1, 2 on day two. His crew was the one who got a dog bone in the eye on day 1 so they came in early and missed most of day 1 racing. The guys at the bottom with all the DNS's were no-shows at the regatta.
Posted : February 5, 2012 10:44 am
Matt M
(@matt-m)
Wouter
2 Taipans
Andrew Sebastian and Will Lints are very new and a bit overwhelmed with the conditions.
Brian Karr and THE Chuck bought Chucks old Taipan back and were only going to sail 1 day but had gudgeon fail so missed even that.
Posted : February 6, 2012 8:09 am
danielt1263
(@danielt1263)
I found entries for
Team Yahwahnnah
in several races all associated with Chris Stater. Some say it's a Falcon, others say it's a
Vectorworks F16
See this for examples:
http://www.google.com/search?client=safari&rls=en&q=Yahwahnnah+site:www.regattanetwork.com&ie=UTF-8&oe=UTF-8
Posted : February 6, 2012 11:33 am
(@Anonymous 38725)
I've seen it up close. It's a Vectorworks Blade, same as mine.
To be clear, Both the Falcons and Blades came from Matt. He is now 'Falcon Marine.' The Blades also came from Matt, back when he was at Vectorworks.
Same guy, two different boats, Falcons being the 'newer version'.
Posted : February 6, 2012 11:42 am
(@sail7seas)
Its a Vectorworks Blade F16
I have know for a while the boat was slow, but at Tradewinds got real dose of reality. I was fighting weather helm pulling the stick with my clenched hand to keep it going straight. I called Matt and discovered my rudder rake was over two inches off. I fixed the rudder rake for latest CABB race and was first to finish, but corrected 4th, the fleet was according apart and then together at the finish. Anyway still a bit to much helm and will correct it a bit more.
Posted : February 6, 2012 12:19 pm
ewindsail
(@ewindsail)
Which picture is the correct rake
Posted : February 6, 2012 12:52 pm
(@sail7seas)
Raked forward (Rake Port+35mm.jpg ) +35mm in front of line from transom,
but I will be going a bit more forward, for a bit less tug, now using a clenched two fingers.
Posted : February 6, 2012 1:05 pm
pgp
 pgp
(@pgp48)
You're just re-drilling the pivot hole?
Posted : February 6, 2012 2:52 pm
(@sail7seas)
Correct, fill and re-drill.
Posted : February 6, 2012 3:02 pm
pgp
 pgp
(@pgp48)
Awhile back there was some talk about bedding the rudder blade into the rudder housing, have you done that?
Posted : February 6, 2012 3:08 pm
(@sail7seas)
No.
I am thinking about re-routing pull-down line to exit the housing instead of around the through-bolt, (remove through-bolt)
in-order to more move the entire rudder forward 1/2" in the housing to lessen the amount needed to tip forward the rudder.
Posted : February 6, 2012 3:25 pm
Gilo
 Gilo
(@Gilo)
Before you starting playing with rudder rake, definately check cunningham while sailing. On the F16 you easily have not enough cunningham when the wind picks up. Then the boat becomes a bit heavier on the rudder. Really easy to know if you're trim is more or less in the ballpark.
Gill
Posted : February 7, 2012 4:29 pm
(@sail7seas)
These are replacement rudders & housings thus the incorrect rake as specified by Matt above, the originals did NOT have this problem.
The original system did NOT have this problem, and do mind playing with the rake, or moving the rudder forward.
BTW, try putting a temporary tape shim in bottom your rudder housings and rake your rudder 55mm back, I would be interested in hearing how it goes.
Posted : February 7, 2012 4:45 pm
