Problem with my Stealth. Need help
Hi All,
I have a problem with a thread on a hull of my Stealth (used to put together the hull and the beam).
It has been damaged certainly because of a too hard tightening.
So now I need to repair it and I see 2 solutions :
Drill to put a M12 screw (currently M10). But I'm not sure if it is feasable as I don't know how is the block of the thread.
Repair with a HELICOIL system :
http:/
Did somebody have this kind of experience on a Stealth. What would you recommend ?
Many thanks for your help
Bertrand
Stealth 539
You will be fine with either a larger bolt or helicoil, the early Stealths had an Ali block imbedded in the back of the layup and the later ones had a Delron ( or something similar ). Most people forget to put some sort of grease on bolts and eventually corrosion between dis-similar metals locks the threads.
John Pierce the maker of the Stealths is still about, have you tried contacting him ?
Davefarmer id really like to see those pics. Previous owner had used brass screws to fix in the gudgeons and I sheared off all 6 heads trying to take them out. Trying to figure out best solution now.
Also does anyone have John Pierces email/contact details? Tried emailing the stealthmarine email address for replacement parts and have had no reply. Maybe just because its Christmas?
John_nohj
All stealth moulds (hull, foils and mast) now with Pete Jary (Zest Racing) who is in Southampton with production starting very soon. Please pm me for more details (carl@nacra.co.uk )....
- 3,692 Online
