big boy sails - polling is now open
https:/
Extra large sails for the fuller (over 165kg/365 pounds) sailor. probably a fair thing.
To be clear, the google poll is for informational purposes only- IT IS NOT A VOTE. The international class is considering looking into a larger sail set, and wanted to know if there is interest. I made the poll for the US Fleet, and it has spread worldwide. I have almost 100 responses so far, should give good information on how to proceed.
Best,
Jeff
Current discussion is to keep the same main and increase size of the jib and spinnaker. The world council is trying to act very cautiously on this issue, and is seeking input from the technical committee, builders, sailmakers, and class membership through the poll. If anyone has additional comments they can also pass them along to Mike or I. This issue could also be a topic of discussion at the US class meeting in Sarasota.
So far, I am very impressed with the diligence the class is putting into even considering such a large change.
The only way to improve the spin performance is to increase the luff length which creates issues in carrying it. The next issue and is the big one for me is that it's another opportunity for abuse. I don't want to see teams carrying the larger spin when they don't meet the weight for the sail plan. You and I both know this will be abused. If you can tell me every light team in the fleet is carrying the proper corrector weight at all regatta's then I might be able to get onboard otherwise it's just another option that won't attract new teams and carries more hassle than it's worth. Don't forget the Frenchies lobbied hard and won for light teams to carry the larger sail plan and carry the corrector weight and their argument was all the development was on the large sail plan won't this create the same perceived disparity?
If this does go through will smaller teams be allowed to carry corrector weight so they can run the larger sail plan? It all gets so complicated for how much gain in participation?
All this is coming from a guy that has sailed 380 for the entire time he has been sailing F18's. So, in my opinion it aint broke so don't try and fix it.
Which country is sponsoring this change? I can't see the French or the Dutchies being in favor.
I agree with Dave on this issue and have stated so elsewhere. We sail at 310 lbs naked bone dry naked, but have been carrying 17 lbs of lead at all events (yes, 7 lbs more, its easier to loose lead than find it), to carry the larger sail plan. I have evaluated switching to the smaller sail plan, but every sail maker we've spoken with says it isn't as refined as the large sail plan. This is somewhat ironic, because the smaller sail plan is very close in area to the Nacra 17, a boat that is ideal for our crew weight, but is 100 lbs lighter. I guess I don't follow how the smaller jib and spinnaker are less refined, given they are just smaller versions of the large sail plan...what I do know is I can go to the gym some more and we can hold down the large spinnaker and be quick. If a 2013 small jib had equal refinement to the large jib, we might loose some drag upwind in over 12kts and hence be faster round the course even carrying lead+large spinnaker. Unfortunately no one is 100% accurate about the weather for a 5 day event. I am sure someone has tried switching sail plans at an event before...how are we going to police a third sail plan, when we aren't even strictly policing weight due to lack of resources and effort?
KISS. Big boy teams here aren't switching because of boat cost. A used N20 is about $5-6K, new sails add $3K, you've got an $8K platform that is faster than a F18 in under 5kts of breeze (typical Chesapeake summer sailing condition). We've done enough this season to show we are fast in all other conditions and can hold on in the light. Adding the XL sail plan probably won't convince the two teams at 380+ lbs to switch to the F18.
looks like its going to happen.
Item No: 13.
Development of XL sails. There was a suggestion from USA, and then supported by Holland, that there ought to be “larger sails for larger sailors”. We have done considerable number of emails and surveys in US on this subject and the Council needs to consider the development for final decision.
The final summary is that :
Crews 175 kg and over can sail with standard mainsail, a jib of 4.5 sqm OR 4.6 sqm, and a spinnaker of 23 sqm.
IT was thought better not to have rules on jib or spinnaker cuts but to leave that to individual sail makers.
The XL sails cannot be used in any National or International regatta for a trial period of TWO years.
The serious message must go out that this is NOT a rule change, but an addition to the weight category and does not effect the rules in any way.
There was concern that some sailors under 175 kg would buy these sails for long distance and handicap racing, therefore breaking one of the Guiding Principles for F18 sailors, that we don’t have different handicaps for F18 boats.
We are still awaiting final technical information, concerning the sailing characteristics and likely performance data, which will be forwarded shortly.
For me, that is not a good idea and I'm à big boy. Every time you make a change and create a difference you split the fleet. More the boat are similar , more you have boat to play
http://www.catamag.fr/?p=5893
I've got to get on this forum more often...
I sail right around 385 lbs and am not in favor of the larger sails. I feel like I can tune most of my (small) weight disadvantage out of the rig. Only in an exceptionally narrow range of wind (7-8 knots) do I feel like we have a speed issue that isn't sailor generated. If I REALLY wanted to deal with it I have the option of having a different shape made into the sails. I don't think an allowance for more sail area is needed.
From the International Council meeting minutes in December:
The Council was split on this matter, some definitely against others more supportive, a narrow vote resulted in a compromise decision was that:
The US be invited to test jibs up to 4.6sqm and spinnakers up to 23sqm only for crews weighing 175 kg and over. Every sail made must be registered and clearly marked “XL”, so it is known how many are made, where and when.
The XL sails cannot be used in National or International events for two years until further information is available.
However this subject led to further discussion and a paper presented by the Netherlands thought that the problem of varying weight might be one of perception more than reality. The meeting requested a detailed examination of the current weights of crews and sail areas. The Chief Measurer agreed to do some evaluation of the crew weight effect on performance. F18 have substantial statistics due to care in recording at Worlds from 2007 to 2013. The matter to be investigated and is ongoing.
Frankly I am a little-bit concerned that an unintended consequence of this may be a shifting of the ideal weight rather than just expanding to a larger demographic (the latter I'm all for).
- 3,984 Online
