Main Outhaul
Baltic
(@6202)
[#27178]
How do you determine the correct position of the main outhaul? I've heard that there could be a fixed position and it then varies alongside the main downhaul. How do I find this position?
Posted : August 12, 2010 2:50 am
F-18 5150
(@hobie18rich)
I set mine with the main sheeted tight and the down haul fully on. then I pull the out haul till the sail had about 1/2 inch deflection.
Posted : August 12, 2010 9:44 am
TEAMVMG
(@TEAMVMG)
what he said
Posted : August 13, 2010 11:51 am
Baltic
(@6202)
That is what I've been told from others. However, when I sheet in as much as possible, the outhaul can't be moved anymore. So I assume an adjustment and check if I end up with 0,5 inch?
Posted : August 13, 2010 1:52 pm
