Quick release shackle for mainsheet.
Thinking about getting one of these for ease of rigging and de rigging. What would be a good option? Or should I even consider one of these items if at all?
Boat in question is a capricorn. I am currently using the stock HOLT 9:1 mainsheet system.
S-hook - can purchase on Rick's store or at any West Marine. Can't take credit - Kevin Rejda's idea when we raced the 6.0 100 years ago. <img src=
DAmn! You are that old? How do you do it? <img src=
If I were you... I would take that S-hook and close up the hook in a vice. Over time the hook slow expands, then falls off during a race! From that picture you don't have long to go.
The snap shackle in the photo you posted should work OK. We got rid of the snap shackle and just use regular shackles to prevent 2 blocking at max rake (we use the Harken 75mm bottom unit). If you are using the 57mm units or equivalent you should be able to use the snap shackles.
The S hook looks nice - but I wouldn't trust it in a distance race - especially when Jesse has bust open a can of spinach...
Chris.
It will, now! Jeez, Dazz - why'd you go and put the whammy on me?? <img src=
I do keep an eye on it, but that thing is pretty heavy stainless from Holt. I don't see that the angle has changed much across two boats and about five years' use. Now I'm going to go sacrifice a chicken to ward off the bad mojo. <img src=
![[Linked Image]](http://marinestore.co.uk/Merchant2/graphics/00000001/ha4659.jpg)
ROFL!!!
Mine was about 5 years old, and I kept and eye on it too. What I thought was that when the hook bent out to 90 degrees it would then be ready to fall off. The truth is its about 70 degree's.
twice in one race it dropped off the main (nacra 5.8 clewboard). less than a minute in the vice and it never happend again!
There is no good reason why your hook could not be parallel with the shaft section.
I have had the S hook break on my Nacra 6.0 and then moved to the Quick release Shackle in your picture and really like it. I also had the S hook bend on my Nacra 5.5uni where the loads are much lower then the Nacra 6.0. S hooks are quick and simple but I no longer trust them. They will only let go when it is honking and then it is a clust F trying to jury rig the main blocks to a flailing mainsail.
Tipping the scales at about 180# these days, I'm afraid I'm probably too much for the 18! <img src=
I know you're still bitter that sweetness helped me stomp you at JPOR so long ago, but you'll have your chance to try and redeem yourself at Hiram's if Ksurfer still needs a string beyatch. <img src=
I put a Synchro 61 mm snap shackle on the top mainsheet block on my Hobie Tiger & am pleased so far. This particular shackle has no swivel, which appears to reduce the lenght by maybe 0.5 inch. The top block has a swivel, so the swivel on the snap shackle is redundant. Besides, I hear that some F18 sailors prefer to lock the swivel to prevent twisting.
Synchor Block Snap Shackle - 61mm
22mm Opening Dia.
2,431lbs. SWL
West Marine No. 3734415
Lewmar No. 29925040
Here's the URL for the West Marine catalog, copied from my web browser address window:
Counting on you to be there for Hiram's. In fact, broke the news to my regular crew last week. He's gonna bring his G-Cat 5.8 over for the race. Don't worry though, my 20 has a 2:1 traveler. <img src=
Got the hotel room already.
I guess I'll start training. I think 2 situps per day should do it, right? And I'm watching
Beerfest
to get ready for the dinner at Hirams on Sat. Night.
When i mentioned using s-hooks... i had all sorts of reports of problems, disasters, typhoons, earthquakes, solar flares and such, from the use of them. This led me to promptly do absolutely nothing in response... so far my plan is working (do i need to sacrifice a chicken now?).
I also use a snap shack on my lowers. i needed to modify it (grind it a little) on the sides so it would allow my shackle attachment point pivot.
http:/
- 3,063 Online
