roller furlers not being used
2 Users
(@binga)
[#19579]
I have a f16 taipan and I am looking for a roller furler for it. Is it true that f18 are no longer using furlers if so would it work on a taipan 4.9. Thanks Andrew
Posted : March 21, 2007 9:49 am
(@Dan_DeLave)
It is not that they are not being used. It is that the rules will not require them to be used. The problem is that if we have a jib that is set up for a roller furler we will probably keep the furler until we replace the jib. I am sure there is someone that is itching to be the first on the block to change. That is usually me, but I have a new jib that works on the furler. I need a spinnaker and main but those would not help you much.
Later,
Dan
Posted : March 21, 2007 10:36 am
(@binga)
Thanks for the reply. Would you or anyone suggest a specific furler to use on a taipan 4.9? Andrew
Posted : March 21, 2007 12:14 pm
(@Dan_DeLave)
Any of them are fine, all of them work. I feel the one on the Hobie Tiger works a bit better than the one on the Nacra F18, but it is a bit larger.
Posted : March 22, 2007 11:49 am
