Steers of Prindle 18
F18 Forum
3
Posts
2
Users
0
Reactions
4,741
Views
Steers = Rudders ?
I'll bet your rudders springs are old and can't hold your rudders down anymore. Buy a spool of Stainless steel wire like the stuff used for aircraft. Cinch together a couple of loops of your springs and you should be good as new.
Good Luck,
Mike Hill
H20 #791
Posted : June 11, 2002 9:10 am
At times the cross bolt that the brass hook in the leading edge of the rudder becomes bent and stays in that position never letting the rudderblade catch. Try to swap out the bolts from top to bottom. Remember that the bolts are aluminium for a reason do not put stainless bolts in thinking they will last longer. Also check the catch hook itself for wear. Bob Grubb N5.2
Posted : June 12, 2002 7:14 pm
Forum Information
- 1,318 Online
Our newest member: Ejustes
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
