exs. 20 ft designs basic specs -
20 FOOT CAT DESIGNS CURRENTLY ACTIVE IN N A that fit into Formula 20 racing ,
Idealy we will have articles with photos of modifications and chute with snuffer set ups of each type -as the year progresses .
Listed are the-- H-Fox --Inter 20 --H-Miracle 20 ---N-6/0 NA --
Tornado ,---P-19 -
The Mystere 20 specs are needed ,-and all other 20 ft -8.5 beam cats are all welcome .
SPECIFICATIONS -HOBIE FOX-
Length: 6.10 m
Beam: 2.60 m
Mast: 9.50 m
Total displacement with spinnaker: 190 kg
Mylar mainsail: 18 m2
Jib: 4.85 m2
Spinnaker: 25 m2
Construction: Polyester sandwich
Crew: 2-3
inter 20 specs
5 Year Limited Warranty
Molded White Hulls
4 Degrees Canted Symmetrical Hulls
High Aspect Carbon Daggerboards (4.75:1)
High Aspect Carbon CHC Rudders (3.1:1)
Double Trapeze
Exclusive Rudder Rake System
Mylar Main and Dacron Race Jib
Foam Battens
Equipped with Newly Developed Harken and Garhauer Gear Throughout
Complete Asymmetric Spinnaker Package
Mesh Trampoline with Integrated Spinnaker Bag
Outboard Led Rotation and Downhaul Controls
Inter 20 specs -
Length: 20' (6.10m)
Width: 8' 6" (2.59m)
Mast Length: 32' (8.13m)
Weight: 390 lbs. (177kg)
Mainsail with Mast: 193 sq. ft.-sail only --208 with mast area (18m2)
Jib: 53 sq. ft. (4.15m2)
Spinnaker: 270 sq. ft. (23m2)
Construction: vinylester foam, sandwich hulls
HOBIE MIRICLE 20 -
H-20 Miracle specs
Presented by
Hobie Cat Co. (USA)
Builder
Hobie Cat Co. (USA)
Designer
Jack Groeneveld
Specifications
Length: 19 ft. 6 in. / 5.95 m
Beam: 8 ft. 6 in. / 2.60 m
Draft, board up: 0 ft. 5 in. / 0.13 m
Draft, board down: 2 ft. 9 in. / 0.84 m
Displacement: 420 lbs. / 190 kg
Builder's Remarks
Meet the cat of choice for racers around the world. Specially engineered to set a rapid new pace for the 90s, the Hobie Miracle 20 is designed with every "go fast" feature imaginable, virtually all as standard equipment that would be costly options on other boats. The Harken 8:1 downhaul and prebent Comptip mast enable power at the top of the sail to be controlled, even while trapezing. And, with Harken equipment throughout, quality is guaranteed. For even more control, all jib sheet, jib lead, downhaul and mast rotation adjustments can be made from the trapeze.
NACRA 6-0 na SPECS
Nacra 6/0 specs
For the ultimate in performance, nothing compares with the NACRA 6.0na.
This twenty foot pure performance machine boasts:
The number one racing catamaran in the 20 foot range
High-tech bow foil system
Utilizes features of the successful Nacra 5.8na
Over 250 square feet of sail area
An 8'6" beam
If you want the biggest, fastest, the ultimate, the NACRA 6.0na is just what you've been looking for.
All the speed of the 6.0na is made manageable through innovative control systems and quality Harken fittings throughout.
The fully battened mylar mainsail features a boomless sailplan with a unique clew traveler system providing a powerful yet controllable boat.
No other manufacturer offers anything like it.
Length: 20' (6.10m)
Width: 8'6" (2.59m)
Drafts:
Boards Up: 5" (12.7cm)
Boards Down: 38" (96.5 cm)
Sail Area: 264 sq. ft. (24.5m2)
Weight: 420 lbs. (191 kg)
Mast Length: 31'7" (9.63m)
TORNADO SPECS -
-note;8.5 FT BEAM VERSION would be N A F-20 class compliant
-Tornado specs --used as benchmark in ratings Edit Reply
-Length-6,10m
Beam 3,05m
mast 9,20m
weight-169kg
main17m2
jib7m2
spin25m2
P-19 SPECS
Length: 19'2.5" (5.85m)
Width: 8'6" (2.59m)
Drafts:
Boards Up: 5" (12.5cm)
Boards Down: 25" (63.5cm)
Sail Area: 247 sq. ft. (22.95m2)
Weight: 385 lbs. (174kg)
Mast Length: 30'3" (9.22m)
please add others if available --thanks
- 5,538 Online
