How to reef the main of a Nacra 20
6 Users
(@paulo)
[#27062]
Hello, I live in Brazil and own a Nacra 20. Sometimes I sail alone and I was wondering if there is a
system
to reef the main?! Thanks
Posted : July 10, 2010 6:20 pm
TEAMVMG
(@TEAMVMG)
Get a sailmaker to put second tack and clew eyes/d-rings where you want the reef, and some across the new foot so that you can tidy the sail with elastic. just like a Hobie 16 mainsail has got
Make up a wire strop the right length to add in between the headboard and the halyard shackle so that it still hooks over the lock at the masthead. You may need to capsize the boat to get it to hook up.
Don't use the spinnaker if you are reefed
Don't singlehand a 2-hander if you can't right the boat after a capsize
Posted : July 11, 2010 8:47 am
(@biggie)
If you have the carbon mast,do not increase the load on the carbon luff track.
Posted : July 15, 2010 12:26 pm
(@Anonymous 39709)
I'm puzzled by what you mean by this. How would reefing the main increase the load on the luff track...not to mention the fact that the carbon one is probably stronger than the aluminum one.
Posted : July 23, 2010 1:18 pm
(@biggie)
Quote
In this arrangement the maisheet load will not be on the halyard hook. But on the luff track, sheet in & the first thing will be OOPS.
Quote
Yes, if lay up was a little thicker.
Posted : July 24, 2010 12:32 pm
(@sail7seas)
One could loop a line around the mast and through the grommet in the head of the sail, to prevent pulling out of the track?
Posted : December 21, 2010 7:23 pm
daniel
(@danielattrill)
the A class cats use a carbon sleeve around the mast with a 2nd halyard shackle clip on it and a wire strop from this to the top of the mast. they cant reef on water with this system, they have a smaller heavy weather main to use it with.
Posted : January 7, 2011 6:42 am
(@Anonymous 39832)
get a recut main that has the top two panels cut off but still attaches to the hook.
Posted : January 18, 2011 10:31 am
