multiple sails?
1 Users
(@Anonymous 37826)
[#10653]
Are multiple 3rd sails going to be allowed? IE: can I have 4 sails on the boat (2 spins) (only one up at a time guys)????
Posted : September 16, 2002 1:52 pm
(@Anonymous 31079)
hI Marc
The intent is one set of sails, per rules ,-main jib and spin be used for a regatta or distance race event unless damaged to a point it can not be repaired in time to continue ,-then it may be replaced per race instructions ,-generally notifying the R C or race official of the damage and change BEFORE making it .
This is done in the Worrell 1000 for example .
Many teams may have more than one spin jib or main of different sizes , but must use one set meaning {main jib spin} for the entire event with approved sizes and signature clearly displayed,-
Typically a team modifying an existing 20 with smaller main will still have the old mainsail available for use if desired .
A max 32 ft mast limits sails on them within that very similar size range .
Trying to limit the number of extra spins or jibs someone may have and somehow enforce that seems impossible .
Yes ,-some will try to buy added sails gear equipement etc in place of developing skill, but this occurs in all classes to some extent , -new boats and sails each year as some O D ,classes do , -. If it becomes a problem as occured in 18 skiffs in Austrailia we can limit it further in the future ,-but the solution there also was to limit mast height which we have done in O- F 20, -
Posted : September 16, 2002 2:34 pm
