Tornado and Mystere added to table
Some fun with numbers...
Look at the sheet again. I added a
percentage of best
column to the length, beam, mast, sail, and weight. The biggest is considered best except in weight. I excluded spinnaker since all do not carry them. I also added an average of those numbers for each boat.
I am not really sure what it means, but interesting to look at. Presumably, the highest percentage average is
better
Mike Teets
Dublin, Ohio
I20 #246
M4.3 #59
I would however split up sailarea into jib area and mainsail area, because both sails act differently. Example when a catrigged and sloop designs have equal sailarea's than teh catrigged boat will do slightly better upwind but the sloop will do much better downwind to such a magnitude that it more than compensates for it's loss uwind. Only exception to this is really light air where the possibly higher rig of the catrigged boat is much favored.
Wouter
I can give you the EU numbers,I think FOX is same
Best is when you look at www.texelrating.knwv.nl
for data on sail sizes.
Wouter
Better get the correct numbers first
The Mystere 6.0 is exactly 8 feet 9 inches BOA and about 19 feet 9 inches LOA when measured properly. The boat weight is all over the place with the latest boats reported under 400 pounds. So much for one design or fair racing.
The last time I measured a Tornado mast it was 32 feet with a boat weight of 350 pounds. I think these are some of the B-class rules which the Tornado(old) is.
The iF20 rules state a max LOA of 6.12m not 6.10m. This is just under 20 feet 1 inch. Since many boats have been built under that rule, it should also stand for NA - F20. Since the Fox and I20 hulls are iF20 class legal, they may also measure nearer to 20 feet 1 inch LOA. Factory specs are not to be trusted for the purpose of comparing makes and models.
Marc
Mark,
I couldn't agree more. We need to throw the Manufactures specs in the trash as our first item. I don't know where they measured my H20 but It is no where near their measurement. We need to independently measure all boats and sails.
Texel info is probably a fair source.
Mike Hill
H20 #791
- 5,526 Online
