Who has built an F Boat?
Folks,
Many people build Farrier Tris and some even build more than one. This says a lot about the designer and his plans that he has to offer.
Just wondering if there are many people on this forum that have built their own Farrier Tri or do all the home builders generally just stick to the F boat egroup.
So if you don't mind admitting it , it would be interesting to hear from those who have.
Phill
Teamvmg,
Thank you for letting me know.
I only want to know the F boat builders in case I have questions downstream.
I'm really glad to hear that you are enjoying the process.
That is very encouraging.
The detail in the Farrier plans is really very good.
Phill
I know that he has the wider version of the larger designs (F9RX) and F32RX) but i had no idea he had a wider version on the F82? If so this would be a really good option im my opinion especially if it dosent make the folded width overall much wider hindering easy trailering and parking ect. I will have to ask Ian about this option if and when i do sell my current boat and i am crazy enough to built another, as im not sure exactly what boat i will choose to build F22 or another simpler/lighter version of the F82R(I.E. very basic interior and no aft cabin).
Yes the wider version allows other benefits as well as a fatter rear hull ( seems where most big tri's have gone over to ) in particular if you offset the dagger board by about 150mm you can get a fitted loo in the larger space Well on paper it looks like you can, practically ???? ). Ian is openly questioning whether the wider boats are slower as first thought. There was quite a discussion on this on SA a few months back
I've also thought that the Amas may just have not been big enough but with the extra width and leverage it gets back to being about right. Pity they were not slightly more foward of the main hull than they are now, but hey that was the design of the time and it has been a very successful design.
There are loads of benefits of the 82 in my mind, principally its small enough to fit in most marinas corner spaces. At 32 feet you are suddenly a big boat and in a crowded marina the shoreman will just say we have no berths. Also here in Europe its better to have a much cheaper boat build wise and spend the money saved on taking the wife to nice hotels along the way, afew nights on board followed by a nice night in a hotel to spruce up.
Sam,
I, too, am very interested in learning more about the F22 and potentially building one. What attracts you to the smaller boat after building your F28? For me, I just want a daysailer that will put a smile on my face when the wind picks up. Unlikely that I'll ever sail outside of the Turks and Caicos Islands where we live. I would love to learn more about your experiences building the F28 and if you are going forward with the F22. I have read everything on the Farrier site and I am close to ordering plans and study book.
I tried emailing you directly but it was returned.
one thing to consider is that with the F22 and F32 you wont have to build the beams and beam modules, this would save a lot of time but would mean having to buy them from Farrier marine. Ive decided to keep my boat for now and not sell i am trying to find a better mast to go on my boat. I also just bought a new more reliable trailer.
Paul,
I hope that you are still enjoying your F32 build. I'm certainly having a great time working on the F85.
I recently got a really good buy on Harken winches and starting to thing about main sheet systems. I was just wondering if you have given this much thought for the F32 and if so what are you thinking of using?
Sam,
Did you use the two speed main sheet system specified in the plans on your F82R. I'm told even the 16:1 can be rather difficult when the breese is up.
Phill
the mainsheet will be a 7;1 straight foward purchase with a cleat on the traveller car, instead of tying off the other end of the sheet - run it inside the boom to a 4;1 purchase that exits the boom at a swivle cleat about mid way along.
this will give a 7;1 coarse trim for the helmsman and a 28;1 fine trim for the mainsheet man out on the float.
This is the system that have used on a seacart and it is great.Just keep the boom swivle cleat far enough foward that you dont hit your head on it exiting the main hatch!
It should also be fairly easy to add or remove purchases if required.
- 2,799 Online
