30$ & 2 hours - snuffer
6 Users
(@Anonymous 12642)
BobG
 BobG
(@drayfisher)
nice but what did you do with tweety!
Posted : May 19, 2006 8:48 pm
(@Anonymous 13024)
Erez,
how did your snuffer work when you tested it? Did you weight it? What grit did you fair and sand it down to? Does it work equally well from both sides?
Lots of questions, but I find it interesting..
A note of warning. I noticed you used your shopvac to pull vacuum when bagging it. It is very probable that the motors uses the airflow for cooling, so when pulling a vacuum your motors run without cooling. They may burn and seize, or start a fire that way. A compressor from a discarded fridge or a air-conditioner would be much better (but take care if you fiddle with the wiring yourself, so you dont put current on the housing of the compressor).
Posted : May 27, 2006 2:01 am
Jake Kohl
(@jake)
I know some folks bleed some air through into the vacuum hose to allow the motor to breath a little. However, note that a vacuum cleaner doesn't pull nearly the amount of vacuum you need to do a true
vacuum bagging
. It will help you pull the fiberglass into complex corners but it will not pull the airbubbles and voids out of the layup. To start to get the advantages of vacuum bagging, a vacuum level of at least 10in-hg (I usually pull 18-20) is needed. You get maybe 1 or 2 (I'm guessing) with a vacuum cleaner.
Posted : May 27, 2006 8:02 am
(@Anonymous 39155)
No offense intended, just straight forward questions:
Why would I REALLY need to vacuum bag anything? I would think the cost of the pump would be prohibitive for the home user.
Also, that's a pretty wide range of vacuum pressure you recommend. If you over do it, isn't there a risk of
starving
the lamination?
btw- there is NO wind so I'm just killing time 'til the wind comes up! <img src=
Posted : May 27, 2006 8:25 am
(@Anonymous 13024)
Poor Pete, a brand new boat and no wind. I feel sorry for you!
If you are building a part you want to make as light as possible and of high quality, you use vacum bagging. Also, if you need to build a complex shape, laying up wet glass can be difficult.
With vacum bagging you get a better glass/resin ratio (if you use proper bleeder cloth to absorb the surplus resin, I dont think Erez did), you also remove the possibility of voids and air pockets in the laminate. If laminating to e.g. foam, you are also sure there is contact between the glass and foam all the way (no voids). Personally, I always vacum-bag parts if I can, becouse I find the process much cleaner. Just wet out the cloth, lay it up and put it in the bag. Instead of working out all the air bubbles by hand.
A pump dont need to be expensive. An old car air-conditioner compressor is perfectly good. I used an old compressor from a frigde for two years before I was donated a vacuum pump from a scientific institution. Other venues are old milking machines, dentists and wherever they use a compressor or vacuum pump.
I got a three cylinder air compressor from a dentist when they buildt a new clinic
I know of serveral projects that have been done with refridgerator compressors. Among them a 28foot hull and a 45foot carbon mast. Just make sure you have one in backup in case the compressor dies while you make an expensive part.
Posted : May 27, 2006 10:35 am
(@Anonymous 12642)
Rolf
Quote
That project was just an experiment, like Tikipete said:
Quote
I never finished the snuffer since I bought a pump in order to do it better.
It weights 1 kg.
It does not work equally well from both sides.
If I was to finish this project I would need a lot of time and material to fair and sand it down, and it will probably weight more.
It is what it is: a 30$ & 2 hours - snuffer
Jake is right.
Quote
vacuum bagging
By the way Jake your web site is great, just went thru your web site the night before and had to try it for my self
http://webpages.charter.net/jakekohl/howto/snuffer_ring.htm
Posted : May 27, 2006 11:29 am
(@Anonymous 13024)
Erez,
here is another cheap and easy to build snuffer. It's the one we still use on our Tornado.
http://www.tornado-norge.org/stockholm2005/_DSC3495.JPG
Just bend a pice of alu tube into the shape you want (make a template/mould to bend it round if you want it to look really nice) or fill half of it with sand and heat the area you bend. Sand the ends with 80grit, then wet-sand the ends with epoxy and wrap some glass around them to hold them together. When the epoxy has cured, build a bracket to mount it to your pole.
The sand fills the area you are bending and stops
kinking
of the tube, while the wet-sanding with epoxy stops the alu from reacting with oxygen in the air so you get a proper bond.
It works almost equally well from both sides (it's slightly better on starboard tack, but I think it would be better with some more sanding and a slightly different mounting angle).
The alu dont notice the friction from the retrieval line, and it's pretty smooth without sanding.
Posted : May 27, 2006 11:47 am
(@Anonymous 14038)
Erez,
Another variation is to buy a wheel barrow inner tube.
They come in a variatey of sizes. Inflate it so it is just firm enough to hold its shape. Apply mould release to the rubber. Then wrap in glass and/or carbon. The wrap in packing tape that does not stretch. Increase the air pessure in the tube and this expands compressing the layup and expells excess resin. (I always prefer to use pressure over vacuum when it can be applied.)
When cured cut a slot in the side which has two benefits.
First it allows you to remove the wheel barrow tube and second is it allows you to fit a tube (for spi pole) into the edge of the ring making a more compact snuffer.
It does not take long to fair and paint in poly urethane.
All up weight around 300 grams. (0.3 kg)
Posted : May 27, 2006 12:34 pm
(@Anonymous 12642)
Phill
That is interesting, I will try it
How did you connect the bag to the ring? It is not clear from the picture.
One more thing I want to make is a carbon spi pole
And all though I purchased a complete system for vacuum bagging and vacuum infusion I was told that to make a tube it is better to use heat shrink tape
http://www.privatedata.com/byb/rocketry/composites/glassing_tubes.html
Do you have any experience with this process?
As for my blade project, It is impossible to find marine ply wood in Israel, to import is way too expensive, so I'm trying to find an alternative.
My idea is to build the hulls from very light thin ply just to make the shape, then wrap it with glass and/or carbon and use vacuum infusion.
Can you comment on that?
Posted : May 27, 2006 3:46 pm
(@Anonymous 39155)
You engineering types amaze me! <img src=
/> Refrigerator compressors!? How in the world would I use it?? Inner tube molds?!!
I have a much better idea, order one from the factory! <img src=
Posted : May 27, 2006 4:35 pm
hobie1616
(@hobie1616)
Quote
Aw come on Pete. Half the fun is resolving a need or problem and developing a workable solution. If it's cool enough there might even be some money to be made. <img src=
Posted : May 27, 2006 9:12 pm
(@Anonymous 14038)
Erez,
I have a vacuum pump made from a car compressor and industrial sewing machine. Just take the machine head off and drive the compressor with the machine motor. Still where possible I use pressure instead of vacuum. This is the same with the spi pole. I've never used heat shrink.
Basically I cut an aluminium tube lengthways to make a mould. Surface the inside with shiny packing tape. Coat this in PVA as a release. Make ends up. Make a bag from plastic and packing tape. Lay carbon layup in tube half. Place bag inside. Fold layup over the bag. Put top on. Do up hose clamps every 150mm to hold together and then inflate to around 35lbs. I have gove a high as 50 lbs but that does tend to push a little too much resin out.
The end result is a shiny black carbon tube. I may have a proper right up somewhere with more detailed instructions if you are interested I'll see if I can find it and mail it to you.
As far as building the Blade the Okume ply really is the trick.
I don't think you will get the weight and strength with very thin ply and glass. But let me look into it and get back to you.
Phill
Posted : May 28, 2006 12:21 am
(@Anonymous 14038)
Pete,
For some people the journey is more important than the destination.
Phill
Posted : May 28, 2006 12:27 am
(@wouter)
AdditionallI can tell everybody that a well made alu ring snuffer will weight about 1 kg. Mine is. I think that to be quite good actually. Furthermore I second all of Rolfs comments to the extend that I favour alu rings over glass or carbon ones.
Wouter
Posted : May 28, 2006 3:37 am
(@Anonymous 39155)
If you're the engineering type! For the rest of us, think: monkey Vs football! <img src=
/> <img src=
/> <img src=
Posted : May 28, 2006 4:05 am
(@Anonymous 13024)
Phill,
if you find that tube building write-up, I am also interested.
How does your
donought
lookalike snuffer work? Does it work equally well on both sides?
Nice detail, letting the snuffer encapsulate parts of the spi-pole!
Any toughts on how much better a integrated snuffer/pole works, and how the windage is compared to the solutions discussed here?
Pete: Monkey vs. football????
Posted : May 28, 2006 9:52 am
(@Anonymous 39155)
Read that PM in private first! <img src=
Posted : May 28, 2006 7:01 pm
Jake Kohl
(@jake)
Quote
Pete,
Phill
I second that.
A refridgerator pump works as a good vacuum source. Just connect to the suction side of it and plug it in. I use a venturi pump that uses air from my air compressor shooting through a tiny orifice. A small port on the backside of the orifice pulls a vacuum as the air shoots through. A good one of these is only about $70...but requires a pretty healthy compressor to feed it.
Vacuum bagging produces much stronger laminates than laying things up under atmospheric pressure. It squeezes out a good bit of resin resulting in a much higher fiber density (which is where the strength is). Also, when using a core material (foam, balsa, etc.) it really promotes excellent bonding to the core which exponentially increases the strength of the layup. If you pull just -10 psi (20in-hg) to a 1 sq foot object, it's applying 1440lbs of pressure to the outside of the object perfectly perpendiular to all the surfaces. That's a lot of pressure!
Posted : May 28, 2006 9:59 pm
(@Anonymous 12642)
This is a very good source of information
Vacuum Bagging Equipment & Techniques
http://www.fibreglast.com/contentpages-V...ations-230.html
Vacuum Infusion - The Equipment and Process of
Resin Infusion
http://www.fibreglast.com/documents/361.pdf
Posted : May 29, 2006 2:12 am
(@Anonymous 39155)
Quote
Pete,
Phill
I agree, but prefer to do most of my
tinkering
in the garden. Some of us, myself for example, just don't have much talent with things mechanical.
Growing things have a
mind
of their own, so unless you REALLY screw it up there is always a good result.
Posted : May 29, 2006 2:54 am
(@Anonymous 14038)
Pete,
I would love to be good in the garden but I just don't have the patience. When I do some work I want to see the results of my labour. In the garden you do the work and then have to wait for the results and I can't stand that wait.
I still have ambitions of having a nice garden but for me it would be a major project.
Regars,
Phill
Posted : May 29, 2006 3:43 am
(@Anonymous 38278)
Patience! I grow bonsai <img src=
/> How's that for patience. And it probably explains why I don't mind racing when it's very light. Like a game of chess to me,.....but then I don't play a lot of chess.
Posted : May 29, 2006 5:30 am
(@Anonymous 14038)
Bern,
I also like sailing when it is light, real light and shifty.
It is great fun and just another aspect of the sport.
However I'd draw the line at Bonsai- That is way beyond me.
Phill
Posted : May 29, 2006 5:56 am
(@Anonymous 39155)
You guys don't understand! Maintaining a lawn in Southwest Florida is an action sport! <img src=
/> It's amazing how quickly things grow here.
Chess and light air sailing allow me to slow down a bit! <img src=
btw- Should we invent a chess style board game to demonstrate rules and tactics or has it been done?
Posted : May 29, 2006 7:21 am
(@Dan_DeLave)
Quote
There are several board games for sailing. The term
Puff Card
came from the board game Regatta designed in 1967.
There is a really nice Computer Sailing Game called Virtual Skipper, but this thread is about patience and this game is pretty active.
Posted : May 29, 2006 11:30 am
(@Anonymous 37755)
I found 2 new ways for making carbon tubes or poles this winter.
First, use a paper tube as a mold. I found some mailing tubes that are made by spiral warping paper tape. Pull on the end of the tape on the inside of the tube and it just unwraps from the inside. Some tubes used by carpet and fabric companies are made the same way. You have to be real careful to protect the paper tube from epoxy. I double wrap it in wax paper.
The second method is to use a florescent tube protector as a mold and just leave it in place. The tube protector is a thin light plastic tube used to protect florescent tubes in industrial environments. Do not vacuum bag the first layer, the plastic tube will collapse. Apply the first layer of carbon by hand using a light touch. Use peel ply to soak up the excess epoxy.You can vacuum bag all layers after that.
I have tried the heat shrink tape. It's ok for small tubes (1" dia x 2 ft long) and a lot of work for anything bigger.
I use 4 inch wide nylon tape for peel ply. I spiral wrap the tube pulling the tape very tight. Then apply the breather cloth and vacuum bag it. I found the nylon tape with finished edges to give the smoothest finish. It is also really cheap at the discount fabric stores.
Just for reference I bought my vacuum pump of eBay for $75. It has a tank, gauge and adjustable pressure switch. Best investment I ever made.
Posted : May 30, 2006 1:30 pm
(@Anonymous 14038)
Carl,
That is excellent value on the vacuum pump.
I like the paper tube method, I didn't realise you could unravel them from the inside.
Another variation of your method could be to cut a slot down a length of plastic conduit. Insert a strip of material like aluminium into the slot with some spacers between in and the inside wall to hold its edge flush with the perimeter of the tube.
Put a layer of packing tape over the packed slot to seal.
When the layup cures pull out the spacers and the strip of aluminium which will allow the plastic tube to reduce dia and come out. There is a bit of setup but may pay off if you are likely to use it again.
Just another way of skinning the same cat.
Phill
Posted : May 30, 2006 6:49 pm
