a little help nacra 5.2
I am rebuilding my 83 nacra 5.2 and have a few questions. I have reviewed the last 5 years of posts for the nacra 5.2 and most of my questions have been answered,(yes there are over a thousand of them,a lot of answers from Jake). I have done a bottom job on the hulls and put new gelcoat on the entire hulls, fixed any bad spots on the rudders and daggerboards and gelcoated them as well, and bought a new tramp.
1.Does anyone know the correct alignment of the rudders to each other.
2.Should I buy the factory hiking stick
to the tiller bar or buy something else.
3.I have to rebuild the ends on the tiller tie bar, but I read in one of the posts to just use the hobie 20 setup. I have a lot of slop in the whole rudder system.
4.Does anyone know where I can find the
nacra
decal for the hulls?
5.Someone said in the posts, to use a smaller diameter line than what is recommended for the main sheet.
Thanks in advance for your time.
airborne
1. I am not sure on the alingment. Mine are straight to the naked eye but measurements might prove differently.
2. mine has the factory hiking stick, it is really nice just a twist and you can extend it out to almost 8 feet and then collapse it back in the same way. I have heard of guys using the aluminum pool cleaner handles. I have a friend with a H16 that does that. It works well and is only 20 bucks...but I don't know how long it will last.
3. You can order that whole kit to rebuilt the set up, it is cheap and works well. They pop up on ebay from time to time in the buy now section.
4. I want to know the same thing!!! I am having vinyl names made for the hulls and was going to see if I could get another Nacra sign made. If I do I will see if I can get a bunch made.
5. I think people suggest the smaller line for racing because it runs through the block easier. I have upgraded to a larger line because the one I had hurt my hands after a long day on the water. That is really up to you.
You are not to far from me, I am in Norman Ok.
The 5.2 is a blast and tough as nails. Glad to hear the other people sail them.
I also have the factory hiking stick and it is nice. I am in need of the attachment part to the tiller tie bar.
I am new to cat sailing but I have heard the 5.2 is an old boat, but anyone who has owned one really liked it.
I joined Fleet 23 club that sails out of lewisville lake.
You'll find some contrasting opinion regarding rudder alignment - some say to toe them in slightly, but I prefer to align them as straight as possible. First, obviously, you need to remove as much slop from the system as possible. Then with the sterns elevated and the rudders in the down position and pointing as straight forward as possible, measure the distance between the two leading edges and remember the measurement. Then come straight back at the same elevation and measure the trailing edges. Adjust until the measurements are the same.
Also note that some of the 5.2's have ackerman steering - the rudder arms are bent toward each other slightly. If this is your case, it is important that one rudder be pointed straight in line with the hull before you start aligning (because the arms are bent inward, the outside rudder in the turn will turn less sharply than the inside rudder to accomodate the outside hull making a larger radius.
After reading all of your posts its nice to talk to you.
The rudder arms are straight so I will just make them the same on the leading edge and the trailing edge. Also I think I read in one of your posts that you did not have much
rake
on the mast.
thanks airborne
I have and still am working on upgrading my 5.2 My tiller bar has no slop at all. I used tiller extension mounts that have cord running through them in case the rubber breaks. My rudders are measured straight no toe in or out. Works great, I have the carbon adjustable tiller extension. I have 10 to 1 main with a smaller diameter sheet, runs easier. Attached a couple photos.
Carl
Saylor Specialties
www.saylorspecialties.com
I have minimal rake on my 5.2 primarily because I sail it singlehanded or with my 40 pound son. Having the minimum rake allows me to depower easier in gusts. I tried to rake the mast back a little last summer but I couldn't get the main to trim properly. Also with the mast raked back it lowered the heck out of my boom so I was having some serious trouble getting under it during tacks. I just put my 5.2 back on the beach after doing some work on it (new standing rigging and bottom job). I'm looking forward to getting out on it within the next few weeks. Water temp is around 60F so you don't have to be hardcore to get out in January.
-Rob V.
Panama City, FL
BTW... that is a sweet looking boat, Carl.
that's the self tacker. The jib sheet is attached to a car on that curved traveler track so that when you tack back and forth, the jib automatically slides over to the correct side and you don't have to touch anything. It's become the standard for most new cat designs. The only drawback (well...that's debatable) is that you cannot have a jib that overlaps your mast and mainsail because it has to stop short of the traveler track to work properly.
If you go to www.performancecat.com you can down load a manual and parts list. They will still have or get any part for your nacra 5.2
Airborne,
I believe the tiller extension mounts are available from Layline or APS. I got mine from RWO, can't get anything from them now. If you search under my username you can find some more close up photos of the self tacker and bow foil. The Tacker came from a Tiger, and the foil I built. I sail single handed and the self-tacker works great for that. Spinnaker is in the process, building molds for the spin hoop now ( half is done) carbon pole is done. All standing and running rigging has been upgraded to new and sometimes old but good ideas. The standing rigging I did myself (it had to be custom). But you can buy OEM standing rigging from Layline or Murrays. The 5.2 is a great old boat (IMHO). Have fun with it.
Carl
Saylor Specialties
Like Carl, I built my own. I'm sure there are many who would not recommend it, but I have confidence in it. I know the guy at WestMarine told me I was crazy... something about quality of SS and such. I'd probably say the same thing if I were losing $200 in sales.
-Rob V.
Panama City
I have no problem building the rigging myself. I work at an airline and can get all the cable I need. We also have some great swegers. The problem is that our cable is more flexable than the oem and I read that might be bad because if you get some slack in the cable and it coils up a little you might get a toe or finger in the coil. When it tightens up you could loose them.
airborne
Airborne,
Just talked to Mike at Layline and their part number for the universal is R0842. They are out of stock but you can call them and see when they expect them in. <img src=
Carl
Saylor Specialties
If you are rebuilding the tiller bar ends, I might suggest using the NACRA TILLER TIE BAR UPGRADE KIT available from www.MURRAYS.COM part number 56-5516 cost is $32. If you go to the web site you can see a picture of the parts. It is on page 33 of the 05-06 cataloge
It should be about 12' long and tied to the mast post. I used to tie mine to the mast post just under the mast ball and store it on a pocket in the trampoline. If you find yourself capsized, get the line out of the pouch and throw it over the top hull so that it falls down the bottom side of the cat. Use it to lean out....
There are other nuances to righting the boat too....briefly; be sure to try and orient the bows so they are roughly pointing into the wind. Sometimes you have to stand out on, and submerge, the bows to get the boat to pivot properly.
Mine is about 15' long but that is too much. I tied a figure eight knot at the proper length so that I can slip it under the hook of my harness. This should allow me to hold the mast up a little while I get my bag ready to help me right it. This is all theoretical since I haven't capsized yet. I'm still waiting to build the nerve (and warmer water). I built the bag last winter and never really set it up on the boat, so now I find myself again waiting for warmer water to practice. I still carry it in case of an emergency but I still don't push the boat as much because I haven't proven it works. I'm pretty sure my mast is not perfectly sealed.
-Rob V.
Nacra 5.2
Panama City
Hi airbourne,
just writing to let you lnow that there is section on tunning notes at www.goosemarine.com.au I found it quite useful for our 5.8 it might help with your 5.2 they can't be that much different.
- 339 Online
