a little help nacra 5.2
Both people hanging onto the same line. Usually (hopefully) when you capsize, there is wind. If there is wind in excess of 15 knots, you can probably right the boat single handed. If this is possible, have your crew sit on the low hull by the main beam while you right the boat. As the boat starts to come up, your crew should roll right over onto the deck of the boat and be in great shape to get things under control while you get on board.
If there is less than 12, you will definitely require both people leaning out on the boat to right the boat. I (usually being the lighter of the two) usually go out on the daggerboard to get additional righting leverage while my crew would stay on the hull leaning out.
Regardless, be prepared to grab the dolphin striker as the boat comes up, the boat will want to keep rotating and capsize in the opposite direction. It is important that you grab the dolphin striker and lift yourself up using your weight to convince the boat to remain
pointy-side-up
. If your crew was able to roll over the hull you probably don't need to worry about this so much.
You'll be surprised how slow they go over if you go on your side. Especially if you are actually trying to go over. You have a few seconds to think about not jumping or falling into the sail, boom, boards, or anything else that would be bad for you or the boat. Sometimes you don't even have to jump off, but can climb down from the top hull. Be careful if your are sailing 2-up, if the other person jumps or falls off, it will shift the balance of the boat and can throw you off.
I'm assuming a good exit strategy is don't break some part of you body on the boat and don't break the boat with some part of your body. I remember the one time I turned the mainsheet over to my brother-in-law while I was on the wire. He healed it over so hard I don't know how we didn't capsize. We had to be right at the
point of no return.
I was in the mental process of picking a landing spot when he finally eased the sheet and gave me a nice dunk on the wire.
-Rob V.
All can be tricky for the people if you don't plan your exit strategy early
. Can you give me the basic's to a good exit strategy.
airborne
It's just about realizing when to give up. Sometimes, if you wait too late, your options to find a nice landing spot are limited. During the '04 steeplechase, we pitchpoled my F18 pretty hard while I was skippering from the wire. If I had been able to keep my footing, we might have been able to save it. My crew had previously demonstrated a tendency to hang on a little to long so when I realized there was no way I was going to keep my footing, I grabbed his life vest pulling him with me as I went by...by that time, the boat was pretty much standing on it's nose anyway. We both landed cleanly in the water in front of the boat.
An example of a poor exit strategy is when I was crewing on a 29'er for the first time and for someone who hadn't yet fully grasped the concept of an asymetrical spinnaker. As we were getting overpowered by a gust, my skipper was expecting me to somehow do something to
depower the spinnaker
instead of him bearing away....anyway, the boat tipped over and a winglet grabbed the water and I was flung forward. I eyeballed a nice clean patch of water between the spinnaker and the jib and began to tuck for my dive. Then my trapeze line stopped me short and flung me head-first into the forestay. I took away two things from this experience: 1) make sure your skipper has a clue and 2) sail on boats that are fast enough that when things do go wrong, you'll be thrown clear <img src=
Pitchpoles can happen pretty quickly - capsizing sideways is actually quite gentle and slow.
my favorite type of capsize is the crash-gybe-death-roll type.
You know the kind where you've got a parasailor line about 15 feet in front of you and its either ge the mast in the water or lose it? Thats the best kind of exit-strategery.
He's young, he can take it.
pointy-side-up
Very interesting tips. I havn´t capsized my cat yet, mostly because I´m not confident about the hulls being watertight (some deck ports mounted on curved surface and not sealing properly). I am fixing that right now and my plans are to practice rightning the boat, for which I installed a rightning bar. My concerns are:
- Should I still grab the dolphin striker to keep the boat horizontal after rightning, or should I handle that with the rightning bar?
- I´m afraid of the boat hitting my head when coming down, what´s the technique to avoid that? Maybe just hang firmly to the rightning bar all the time?
- What is the safest place for the crew, in case the idea is to protect them rather to have them help with the rightning? (like my daughters?)Would it be an exageration to have them grab a rope attached near the bow or stern, to keep them out but still linked to the boat?
Thanks!
You will definitely need to get to the dolphin striker when the boat is leveling out. The momentum from the rotation and the wind will want to push it right back over the other way.
Getting out of the way of the hull really isn't that difficult - once the boat reaches about 45 degrees, your weight is really not a factor anymore and you can begin to position to reach the lowside dolphin striker. If you're righting pole puts you far away from the boat, you could possibly be in the path of the high hull as it comes down to the water - just be aware of this (and make sure the daggerboard doesn't wedge itself between you and your life jacket!).
Trailing a line off the rear beam sounds like an interesting idea for the kids - I would think that if they were 5 feet behind the boat they would be safe. However, the boat will tend to drift downwind with the mast trailing so they will be on the opposite side from you and possibly near the mainsheet and boom as such. Their presence in the water will also tend to spin the boat as they are pulled through the water - and that might impede your righting attempt. I would probably put them sitting comfortably on the hull in front of the main beam and instruct them to hang on to the dolphin striker, or the righting line that should be trailing behind the boat just after righting.
On righting a H16 my son (7 years old) would stand on the lower hull just in front of the main beam and when the boat would come back over, he would step up onto the trampoline. I suppose, theoretically, he could make it through the whole capsize without getting wet (I did this once on an Apollo 16). It was the middle of August so the whole reason we were sideways in the water was to take a break from the heat. I would never purposefully capsize my Nacra 5.2, mainly because I am afraid of breaking something, but also because I don't think my mast is sealed very well. I agree with Gree that capsizing and sailing in extreme conditions is much more enjoyable on someone else's boat.
-Rob V.
Panama City
- 776 Online
