checking hulls
General Sailing Forum
2
Posts
2
Users
0
Reactions
565
Views
BE VERY CAREFUL IF YOU DO THAT. You can easily over pressurize the hulls and possibly cause failure. Probably the easiest way is to thump the hulls and listen for the sound it makes. If the hulls are soft, the sound will not resonate clearly. It will be more of a dull thud rather than thump. Also just pressing on the hulls in different locations along the deck will show signs of softness. If you're not sure check a newer boat and compare the sights and sounds. This should be easier than trying to air up the hull. BTW airing it up will only show if it leaks and not if the hulls are sound.
Good luck
Clayton
Posted : November 2, 2001 12:46 pm
Forum Information
- 1,411 Online
Our newest member: Ejustes
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
