Construction of Garage Mahal has begun!
23 Users
68.8 K Views
hobie1616
(@hobie1616)
I saw on your site that you're looking for bucks to contract out the insulation. It's very well spent money. Insulation is a crappy job that will leave you with glass itch for a week. The insulation contractors can get the material for way less than you can because they buy in bulk. The price of material and installation was less than if I bought the material on our last house.
Posted : August 19, 2010 3:27 pm
(@beachsailor)
Stray it in. Much better than fiberglass.
Posted : August 19, 2010 3:56 pm
(@mhill)
I did all my basement renovation myself. However I did have a contractor hang and tape my drywall.
Suggestion to you if you have a contractor do your drywall. Count all of your outlets, windows, and heat vents in each room. My drywaller went over one outlet and one window. Funny until you are trying to figure out why you have 5 windows outside but only 4 inside?
I did the pink insulation myself. No big deal and saved some on what was bid. I got it on sale at a HD. It always pays to wait around and watch for sales. You would be surprised how much you can save by catching stuff on sale.
Good luck to you and we missed you at Nationals.
Posted : August 19, 2010 4:43 pm
 Karl
(@sogncab)
If orphan means spray it in, I agree 100%. Spray foam is the only way to go. Better R value, less worries with moisture, and it makes the structure stronger over all.
Posted : August 20, 2010 8:50 am
(@_removed-account)
Four Star Admiral Registered
i was very shocked at how cheap the bid was to spray in insulation in my house (attic). $300 for standard $500 for the highest R value
Posted : August 20, 2010 11:13 am
Jake Kohl
(@jake)
Really? I had understood that the spray-in stuff was roughly twice that of fiberglass. I don't think it pays to do the insulation myself. My brother most recently had a guy quote supplying and installing insulation that was less expensive than what he could buy it for at a box store. The sprayed stuff has about twice the R value but I'm still a little concerned about the long term affect of a water problem should one ever come up.
Posted : August 20, 2010 12:45 pm
hobie1616
(@hobie1616)
It probably doesn't matter what you use. A house up the hill had an o-ring go bad in a water filtration system. Slow leak which eventually covered the wood plank floor, soaked through the sheetrock and was wicked up to the ceiling by the glass insulation. What a mess.
Posted : August 20, 2010 2:32 pm
(@_removed-account)
pretty certain. 1000sq' was around 3-500 .
http://www.danielinsulation.com/products/batt-blow
i think that was the product i was quoted for. i never ended up doing it. i found out it already had updated insulation
Posted : August 20, 2010 4:35 pm
 Karl
(@sogncab)
Water should not be an issue with a closed cell foam over any other of the choices. I know up here you do not have to run a vapor barrier with the closed cell.
It does cost more, but there is a savings to be had in the long term with lower heating/cooling costs. Granted our extremes are a bit different than yours. Temps here can sway 140*F with the seasons, so I'm not sure if it is as critical.
Personally if I were to build a house today, (I know a garage is a slightly different story...), I wouldn't consider anything else.
[edit]- The noise suppression from the spray in is also very impressive.
Posted : August 20, 2010 5:17 pm
Jake Kohl
(@jake)
Most spray in foams are open cell - real closed cell is like 4x the price of open cell foam...or so I thought.
Posted : August 22, 2010 6:43 pm
 Karl
(@sogncab)
Yep, its significantly more. I don't know if its cost effective for you, but up here it has just about become the standard for both walls and ceilings.
Posted : August 22, 2010 8:21 pm
Jake Kohl
(@jake)
The Mahal is still under construction. I haven't done crap to the inside yet other than push a boat in there and do a little work on my truck. I have been using the space to building fencing and fabricate a couple of (overly) complex gates. Also been pushing dirt around. It's getting there. I'm still blown away at the amount of space and can't wait to get it finished to get started on something fun! That's my extended cab Silverado at 19+ feet long in there with the garage door closed.
To Nigel and Dave who gave me the sage advice:
people complain about it being too small or being too expensive - but nobody complains about it being too big
....thank you!
[Linked Image]
Posted : November 12, 2010 9:43 am
(@beachsailor)
Rule 1: build it bigger than you think you need.
Rule 2: no mater how big you will fill it with stuff and wish you had made it bigger.
Posted : November 12, 2010 11:24 am
(@themanshed)
How true I'm running out of room in The Man Shed 48' x 30' at first I thought man look at all this space ---- and now I have to move things around.
Posted : December 29, 2010 12:10 pm
lesburn1
(@lesburn1)
I have a friend with a
shed
that is 40' X 80" and it is so full with sh** that you can barely move around. Between two Cessna 185s, Piper Cub and a John Deere and 50 years of crap...
Posted : December 29, 2010 5:51 pm
Jake Kohl
(@jake)
The garage is slowly coming around...I'm finally ready for electrical and plumbing rough-in inspections.
BUT! projets like this keep getting in the way. We're getting our F18 infusion ready for the fall regatta season and sprucing her up.
www.teamseacats.com
Posted : August 29, 2011 9:40 pm
(@stank)
One Star Admiral Registered
that's quite a crack, and lots of good detail for us amature repair folk. It bears repeating that the elbow grease is what makes it work....
Posted : August 30, 2011 9:54 am
(@Anonymous 37750)
AMEN!
Posted : August 30, 2011 7:53 pm
Jake Kohl
(@jake)
Originally Posted by TheManShed
My shop is open on the ends. I have mixed feelings about doors in a large shop in South Florida ventilation is important. It would cost an arm and a leg to cool a building like mine, then you would have to deal with the dust and chemicals so you don't blow yourself up.
Mike,
I sifted back through this thread and saw your comment. I have to say, that is one of the most sage pieces of advice I have heard. I have a 16' door in one gable end and a 12' door in the opposing gable end of my garage. I did that so, in the odd chance I needed to, I would have options to pull something large in and drive out the other side. What I've discovered, however, is that having the two doors is incredible for airflow and comfort when doing the things we do with fiberglass, grinding, welding, and other stuff. Fresh air comes easy when you have a door on either end. It really is quite nice.
Posted : August 30, 2011 10:10 pm
 Karl
(@sogncab)
If you epoxy the floors yourself, get the solvent based kits, plan on doing two coats, and put a clear coat over the top. I did my garage at my old house and the only thing I would've done differently is I should've sand blasted the floor to give it some texture for the paint to adhere to.
Posted : August 31, 2011 9:07 am
 samc
(@samc)
Top notch repair work! I'm in the process of similar things to get my TheMightyHobie18 race-ready for the NCC 100, some of these tips will come in handy. Looks like my top competition will be Krantz on the F20c, somehow I doubt my asym'd TheMightyHobie18 will keep up...
Your discovery of the void in the daggerboard area, along with some recently acquired information (lack of Nacra parts availability) is making me lean towards Hobie or AHPC for my F18 buying needs. Granted, this same thing could happen on any of the platforms if the builder isn't checking quality very well.
Posted : September 1, 2011 7:14 am
Jake Kohl
(@jake)
I don't know a whole lot about it - but apparently part of the motivation behind the last iteration of the Infusion was to change how they join the hulls and daggerboard trunk....making it more like Hobie and AHPC were assembling their boats and removing the need to do so much cosmetic refinishing after bonding the hull halves. I'm sure the way the daggerboard trunk is bonded is made better.
Still, though, this kind of thing is frustrating to have to do to a boat that's not yet 2 years old. Although I did more than just repair that trunk, we've probably got 35-40 hours in the work so far and the trunk was at least 2/3 of that.
Posted : September 1, 2011 7:52 am
 samc
(@samc)
That really sucks Jake, a lot of time that should have been spent sailing!
I heard through the grapevine that the 2010 boats had a lot of problems: http://forums.sailinganarchy.com/index.php?showtopic=121613
If I can find a used Capricorn I'll likely go that route as the AHPC build quality is better. I'm sure the MKII Infusions are up to par but I can't afford one of those...the C1 I've driven goes upwind like its on rails, it needed a new spinnaker to keep speed and angle downwind against the Infusion but was just generally a fast, well built machine.
Posted : September 1, 2011 7:24 pm
Jake Kohl
(@jake)
well...frack me. There was sikaflex bonding the daggerboard trunk to the hull. I couldn't figure out why the bonding goo was a little gummy. I thought maybe they didn't get a full cure on it...nice. So, not only did they use the wrong goo to glue the trunk in, they didn't use enough of it. I wonder how long it will be before I have to do this all over again on the starboard hull.
My avatar now looks very appropriate.
Posted : September 1, 2011 10:35 pm
(@_removed-account)
Call Jill and Robbie, they are always happy to help peeople buy and sell ahpc gear . Jill at redgearracing dot com
Posted : September 2, 2011 9:43 am
Page 3 / 3
