Cross cut Mylar vs radial cut mylar. GO!
I spoke to Landy quite a bit about this before ordering my new main and again at a resent coaching day he conducted here in Melbourne. Generally speaking he was more than happy to make me a sail out of any of Radial, Cross cut or string (which is still cross cut). For the Taipan his first offer was a radial sail as this is what he had most recently been building (one of his radials was used by Chris Boag to win the 2012 Nationals). However at the time I was leaning towards a cross cut as I blieved there would be a small weight saving and maybe a longer life and he was more than happy to build one (he has since won the A Class Euros with a cross cut sail) My understanding is that the labor cost in building the simpler cross cut sail is more than offset by the additional cost of the material. So if you buy a radial sail the extra cost goes towards your sail maker's wages or if you go cross cut Contender or Dimension make more money, for you the consumer, there is no real difference.
The third option and the one I went with as buying a fixer upper left me some space in the boat budget was a string sail. From a construction point of view this is almost identical to a cross cut but your sail maker gets to specify the fibre types and directions. These are becoming very popular in A classes but reports have been that some of the sails (mainly the ones using Carbon Fibres) are too stiff and basically don't respond to adjusting cunningham etc. Landy makes his quite a bit softer and to date I have been very happy with my ability to change gears with the sail (although I'm still on a learning curve being new to Taipans).
Hello Scarecrow,
was there a major price difference between radial and string?
What will the sailmaker actually do with his hands when building a sail like this? Design and fiber layout and perhaps finishing with batten pockets and fittings, edge tape etc?
Is there now one big manufacturer building string sails at a large facility or is this also done in the workshop of local sailmakers?
I had no idea that string sails now are becoming accessible by catsailors with normal budgets.
For me the big thing about crosscut and modern laminates is that I can quite easily assemble sail myself.
String sail was about 10% more. This isn't a moulded sail so the sail maker still has to do exactly the same on the loft floor as with any cross cut sail to get the desired shape.
I'm not sure how many manufactures of the custom cloth there are (which is all this is) but most big lofts can either do it in house or like the smaler ones smaller ones can order from I believe at least two suppliers.
Hi again,
are you saying that the sail in your picture does not have continous fibers? I understand that mylar panels recieve broadseaming and is assembled. But are the fibers then applied to the cloth, or are the fibers applied before the panels are assembled?
UK Sailmakers had a system where they assembled the panels before applying the fibers with a tool made of 5 tape dispensers. A down to earth solution and all sailmakers with a license could do it.
Dam, just typed a reply then lost it. Here comes the short version:
Sail cloth is made on a machine like this to a layout as designed by your sailmaker, then sent to them to broad seam and detail. So yes despite the apparence in the photo, the threads are broken at the seams.
Given my main was made in Landy's German loft, it is probably safe to say the material was made by Dimension-Polyant, but I thought he mentioned something being done in Italy.
Sounds like a win-win-win situation!
Cloth
manufacturer wins, sailmaker wins and sailor wins.
Of course it would be
better
with continous fibers but hey, the stiffness of the seams is probably more than adequate and sail is lighter and perhaps easier to trim?
When will this be transferred to spis.. <img src="<>/wink.gif" alt="wink" title="wink" height="15" width="15" />
Good luck with that!
I haven't sailed for 4-5 years, have no Taipan experiance but have only been totally destroyed in one race out of the five I've done (this weekend in 0-3 knots) so the sail obviously isn't slow. Now if I could get race fit by calling someone and sending them a cheque, I might do ok this season.
I would say it very often isn't the sail to blame for being
slow
... unless you're REALLY good at everything else involved (course, transitions, weight placement, rudder, hull trim, rig & mast setting, etc)
Who was your sailmaker?
Thanks, TG
Sloop - modeled from an f18 sail (mkII) with 3" added to the leach (edit: i sail a Mystere 5.5, usually solo. i will furl the jib if very overpowered)
sailed it 7 times now, love it. seems faster downwind with same effort (compared to my f18 sails, but seems more sensitive to tuning upwind).
I sailed very fast this past weekend (against my usual friends). Either i was tuning my boat and sails better, or my friends were slower
Doyle made it, i am very happy with their product... will report back after 300 days of Florida sun (2 years)
The Continuous fibre story is basically a sales pitch used mostly by the Norths and UK lofts.
It really does not make a difference in reality. The Norths and UK continuous fibre sails have been
continuously
smoked in big boat racing like the TP 52s, STP65s and even the AC 45s. Proving the continuous fibre story is a load of BS. You actually find Norths are cutting and joining some their string sails now to get a decent shape.
Cloth
better
slow
That's my point, if I can still be competitive while working out how to do all this in a new class at a new location the sail must be a goer.
Looking for advice ,,, I have read the sail reviews here , and also will order a new set of sails , for my 18 sq ,which i am going to upgrade to run a jib and spin ,,However im told the F i8 main sail will fit the 18 sq 30 ft mast ,Can any one confirm this ,,or help me find ,Where can i get the sail plans for the F 18 ??
Hi Tom ,,
yes im fabricating a spreader bar that will span between the hulls .this will then fit the two stay fastening points on the hull ,,the spreader will also have a centre point for the jib /fore stay , the spinaker pole will also travel under this and bolt to it for support ..
- 1,653 Online
