Delamination on the side of a Hobie Hull
I have heard it is not necessary to repair delamination to the side of the hull. Does anyone have more information on this? I bought some laminating resin this morning that I plan on injecting into the sides between the foam sandwich that seems to have rotted. Does this sound like a bad idea. I don't want soft sides, but I don't want to cause more problems than i already have. Thanks for any help.
One other thing about injecting resin. Hobie suggested using a plastic bottle to inject resin. I would use a large syringe. Drill the holes the same size as the syringe tip. This way when you stick the tip of the syringe into the hole it will seal somewhat allowing you to pump the resin into the hull and not back out at you.
Mike
Allright, one more thing. Thankfully this place is not far from me. If you are looking for syringes or anything for boat building or repair, check this place out. www.fgci.com
Mike
don't forget these guys - they've got a good selection and usually ship the same day:
- 5,102 Online
