Diamond wire settings for '02 Bimare 18HT
Seriously Dave, would you really keep settings like this secret?
I would treat it like any other boat, start off with a base with the spreaders around 50mm behind the mast and 38 on a loose gauge then adjust rake and tension until the mast matched the sail and enough power for the crew weight your carrying.
ultimately no setting anyone will give you will be accurate because there are too many variables in play.
Posted : June 14, 2015 7:22 pm
Forum Information
- 901 Online
Our newest member: Ejustes
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
