DIY Snuffer hoop and bag
7 Users
(@Anonymous 37844)
[#12775]
Has anyone tried to make their own Snuffer setup?
Any leads/tips on how to make one?
What materials are best?
Thanks in advance.
Posted : October 27, 2003 9:50 pm
Jake Kohl
(@jake)
Yeah....see the following link. I have some updates and photos that I'll probably post this weekend. I learned that the pelican striker on a Nacra 6.0NA bridle foil presents some unique problems to a mid pole snuffer.. hmmm. ("load torpedo bay number TWO!").
The Sailing Shack Snuffer Ring
Posted : October 27, 2003 11:24 pm
(@Anonymous 13274)
There're some guys running around the Gulf Coast with a Randy-designed contraption using (no joke) a tennis racquet. Don't have construction details - looks funny (ha ha AND strange) but it seems to be working pretty well.
Any of you other PSTs have any details of how to build that thing?
Posted : October 28, 2003 12:16 am
VIcatman
(@vicatman)
heres a pic of the racket set up
Posted : October 28, 2003 12:43 am
Jake Kohl
(@jake)
I am pretty sure that only works on a uni-rig. but it allows you to set and douse from either side.
Posted : October 28, 2003 9:01 am
(@_removed-account)
Four Star Admiral Registered
What problems are you running into with the mid pole snuffer on the 6.0 foil?
Thank for the info.
Posted : October 28, 2003 11:51 am
Jake Kohl
(@jake)
The chute catches on the pelican striker as I'm trying to snuff it and literally gets wrapped around it. I've tried snuffing dead downwind, reaching, and upwind and it always blows back and catches. I'm considering moving the snuffer hoop out farther from the bridle but would be interested to hear if anyone else has tried a mid-pole snuffer on a 6.0NA. As you can see in this picture, there is quite a bit of stuff behind and above the ring.
[Linked Image]
Posted : October 28, 2003 11:56 am
(@teamteets)
Jake, what about using your pelican striker as the snuffer? Instead of making it round, make a triangular feeder with rounded edges that fits inside/around one side of the striker. That would get the bunch of sail in front of the foil.
Posted : October 28, 2003 1:14 pm
Jake Kohl
(@jake)
Oooooooo! I never even came close to considering that....I'm off to the drawing board! The jib tack might lend a clearance issue but I might be able to work around that. Thanks Mike!
Posted : October 28, 2003 1:33 pm
Jake Kohl
(@jake)
I've got another question too....why is it that most snuffer rigs are setup for a port tack takedown yet the hoops are on the port side (the side opposite the spinnaker on a port tack)?
After looking at photos like this, now I'm wondering why I had so much trouble to begin with. The relationship of these bridle wires to the hoop is worse than that of my pelican striker. I wonder what I'm doing wrong?
[Linked Image]
Posted : October 28, 2003 1:36 pm
MaryAWells
(@maryawells)
Quote
You mean instead of using a tennis racket, use a pool ball rack?
Posted : October 28, 2003 3:10 pm
VIcatman
(@vicatman)
check this one out....
Posted : October 28, 2003 3:22 pm
(@tcatman)
How big is the chute you are trying to snuff?
The T chute is 25 sq m.... the NE N6.0 is 28 sq meter (i think).... its a huge difference when going into the snuffer and sock.
Posted : October 28, 2003 3:50 pm
Jake Kohl
(@jake)
I've got an Ulman chute that is probably much closer to the NE chute size than the Tornado (it totally eclipses the I20 chute). Can it be done?
Posted : October 28, 2003 4:33 pm
(@Anonymous 37844)
Thanks to all for the tips and further discussions.
Next problem!!
What diameter should the head/hoop be?
[color]
Posted : October 29, 2003 10:27 pm
