Do you use leech telltales?
Do you use leech telltales on your sail? If so, during which points of sail are you using them? How do you adjust the sail or change the heading of the boat based on what you see the leech telltales doing? Do you want to see them flowing straight back or curling around the sail?
Posted : August 30, 2005 4:05 pm
I use them. They are great for fine tuning when going upwind. They should alternate between flowing aft and hooking to the backside. Flowing straight aft is undersheeted. Hooking all the time is over sheeted. There is a tell tail placement diagram on the Hobie website related to the 16, but generally would be the same on all boats. Some sailors stick them right to the edge of the leech.
Posted : August 30, 2005 5:14 pm
Forum Information
- 5,680 Online
Our newest member: Ejustes
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
