F18 question
I'm in need of a set of daggerboards and rudders for a project I'm working on. Can someone measure the transoms (height&width) and the daggerboard wells (depth, sticking a ruler down the trunk) on either a Capricorn or an Infusion for me?
Bill
thingy
that retains your spin halyard; up near the hounds?
Alright, alright....that will be all we need to hear about wanting to see pictures of JW's
thingy
<img src=
/> <img src=
/> : <img src=
/> <img src=
No reason to get excited, fellas. I'm not afraid to show people my thingy. Here it is:
The technical name, according to the owner's manual (available free on the AHPC site) is the
anti-fouling loop.
Simple piece of plastic tubing that keeps slackened spin halyards from getting behind the spreader arms. AHPC didn't come up with this idea - I first saw them on Hobie Tigers quite a while ago. The Hobie guys were using a simple piece of line tied in a loop. I've seen a lot of Nacra 20 guys use this as well. The Cap was the first boat that I saw with the tubing (stiffer than line) as a stock part, with holes drilled in the spreader arms for attaching the tubing with a tiny stainless bolt and lock-nut.
Don't you still get friction there during your hoists? If that is a pinch-point since it is not in a direct line from the cleat at the bottom and the turning block at the top, then you are expending extra Newtons at a critical time during your race...
If there's no friction there, however, then it's a good place to run it - It seems like I remember the double spreader arms on the 6.0 were handy that way when rigging a 'chute.
thingy
and couldn't figure out how that would help. Chalk it up to being a newbie. <img src=
/> Thanks, I will have to suggest we put on our boat.
Same noobiness here...until I pondered it a bit, I thought it odd to run it outside the ring.
thingy
All right guys!!!! Don't even start!
You know guys-I was serious-I have only been crewing for a year now so I'm still a little slow at figuring out things. I think the bungee cord is a great idea too. Any thing to make my job pulling that halyard easier is greatly appreciated.-(If you ever meet me in person you will know what I am talking about)
Paul
I've been using the bunji tied from the tip of the spreader to the shroud - it works great, but it's a bit of a pain to rig. I think I'm going to go with a loop setup like John's
thingy
- 1,750 Online
