fiberglass repair...again
Hey guys,
Noticed on the Prindle 19 I have another area that needs some work. I took the port hull inspection cover off and just forward of the hole on top i can feel some damaged fiberglass. This area is formed into some sort of shape, i.e it is not just a flat area. I need to get in there with a flash light and a mirror to see it better. There are no holes or crack that go to the outside but i'd like to fix it before that happens. Would i be good just to sand it down some and put some large heavy cloth down? Suggestions welcomed.
Pete
Pete
It's probably nothing and is likely just a sloppy finish job on an inside seam. Tip: put a digital camera inside the hull and take tons of pictures - they'll tell a pretty good story.
![[Linked Image]](http://farm1.static.flickr.com/210/440875980_d39d9ff2d5.jpg)
- 3,605 Online
