Formula 1.04 catamaran class
The Challenge National Formula 1.04 took place at the weekend in Lorrient Brittany France. 30 teams took part and five manufacturers were represented. Mattia, Nacra, Cirrus, Hobiecat, Spitfire. The competition was close with Spitfires coming first and second in this new class. May be the Spitfire is not as dated as some of the french press believe. Will Formula 1.04 offer a challenge to F16?
As I wrote on the F16 forum where you posted approximately the same message:
This have been discussed at length earlier. The 1.04 and the F16 are two distinctly different concepts so the 1.04 is no more a threat than the F18, H16 or the 49er for that sake. We are all promoting catamaran sailing and racing, so talking about a threat is a bit strong.
Who are you by the way? A small introduction would be nice.
F104 is a disperate collection of boats that rate 1.035 to 1.045 under SCHRS.
These boats are sailed 2 up with main, Jib and Spi.
I believe there are some other rules, but the basis of the group is the rating falls between 1.035 and 1.045 on SCHRS.
CPS, who are you, where are you based?
Yeah, in order to prevent too much tweaking they'd have to put a box rule around it as well. Otherwise people might figure out that they can get ahead by sacrificing some weight for sail area, or width or whatever the formula says is balanced but isn't in real life.
If they have a length limit, they've already started down that road. Seems better to just have a box rule from the get-go.
I guess the other way to go about it would be to require all boats in a one-design class legal configuration, and hope the manufacturers don't start doing the tweaking themselves.
Does anybody know what those SCHRS ratings would be in terms of comparable Portsmouth ratings?
I believe the classes are based on two quite different ideals.
F104 is getting as many popular current french boats together and racing them without using the handicap system.
F16 tring to get a boat which is a fast as a f18 or A class for the price of under a f18.
It's a benerfit to cat sailing if both classes work well.
The spitfire is a competitor to both classes, even thought both claim it's in their own class, but spitfire sailors seem quite content sailing within just there own class.
When I bought my own f16, I would have gone for spitfire if it was just for the racing, f104 if i wanted a cheap second hand cat to race.
But I like the ideal of one/two hander boat,light weight, and high spec boat.(plus with it been new it was at lower price then the new f104 I was looking at.)
I mean, what is 1.035 in terms of a Portsmouth rating; and what is 1.045 in terms of a Portsmouth rating? Is there any valid way to equate them?
Based on 1hr you have a 36 second range for 1.035 - 1.045. Some clubs use a conversion factor from SCHRS to Portsmouth Yardstick to score with monos, but I personally am not convinced by this method. Don't forget the conversions will be to UK portsmouth yardstick. I haven't seen one for the US ratings. You could work from 104 range to the F18 rating to get an approximation against the US yardstick.
Cheshirecatman
Mary F104 is a class much like the days when you had Prinde 16's and Hobie 16's...
Nacra 5.2's and Hobie 18's.
Prindle 19's and Nacra 5.8's and Supercat 19's.
The boats were level rated in US Portsmouth and state of the art in their day.
Your mileage might vary as to how even you beleieve the boats actually are.... leading to the old
horses for courses debate
Level rated races were never popular in the US as sailors felt the pressure to support their one design class schedule and not a level racing schedule. I would imagine that the only way it works is if the French YC's and Sailing authorities only support F104 and don't allow a local majority of boats to split off and race one design by not hosting OD races.
It is my view that the F104 class will have trouble growing and sustaining herself with the current very simple rule-structure of adhering to a 104 handicap number.
The F16 class didn't start out much different from that but we quickly encountered the need to converge to a more tightly controlled class in order to grow and be garanteed survival.
Basically, at this time the F104 class has less and less stringent rules then even the A-cat class and I see that as a problem.
Personally I applaud the F104 creation from the viewpoint that it is a good action to reverse the fragmentation of the catamaran sailing scene while not hurting some owner investments by declaring a given class as unviable. But I don't see it as much of a competition (c.q. challenge) to the F16 class, the A-cat class or the F18 class as these are much more organised (internationally) and much more tightly controlled then the F104.
Wouter
Mary, the conversion factors would vary each year as do the Portsmouth ratings, not a good thing for a conversion factor. Also you could only do a conversion for those cats that hasve a rating in both tables. You'll probably find two cats with almost the same SCHRS rating but different Portsmouth numbers, which is not desireable either. But, you probably could find a reasonable Portmouth range which would encompass similar cat types as the ones in 104.
If I'm correct, Portsmouth takes the resulst of cats into account. So you have a theoretical rating, adjusted with actual racing results.
SCHRS is purely theoretical.
In fact a comparison between the ratings Portsmouth and SCHRS could reveal if formula class cats perform more or less within the same range on the water, while boats gathered by rating would have to have a bigger difference?
Correct?
Gill
Simply put....
SCHRS provids a rating based on the boat, sail area, length, width, crew number, number of trapeses, daggers or not etc.
PY (US or UK) provides a rating based on the performance of the boat and the sailors who sail it.
consider a really difficult boat to sail. It will have one SCHRS rating.
Every year, as people get better at sailing it, the PY rating will change; this reflects the ability of the people sailing the boat, to sail the boat at it's petential.
Consider an old boat that is not sailed much. It will have one SCHRS rating, the PY tating will slowly get easier (slower) as less people sail it and so less people win stuff (the good guys usually sail in big fleets where the competition is).
So, after a while, the PY rating will become
easy
making the boat a bit of a bandit and as soon as a decent sailor
borrows
one, they clean up as the PY does not reflect the speed of the boat, it reflets the speed of the boat, and ALSO the speed of the people who sail the boat.
PY also does not allow rapid developemnt of classes as returns (Results) need to be gathered to create a rating.
SCHRS (or TEXEL), you just plug the data points into the rating engine and a rating pops out.
Due to a lack of PY data for cats. Original UK conversions used the original classic tornado rating (1.00), took its PY rating (691 I think at the time) and used the SCHRS difference to give a PY to use for the cats. Not ideal I know but some clubs were happy using it. Now I think they use the F18 as the datum point for calculation purposes. You can calculate the same using your US portsmouth rating for the F18 as datum.
Cheshirecatman
easy
borrows
True but only because of the way the PN rating is being implemented!
The solution is to make a new rule for this circumstance consistent with the basic PN assumptions.... eg the boat is actively raced in its class.
so... I propose... when a class does not hold a nationals with 10 boats for two years. the PN rating is frozen at the rating when the class last managed a nationals.
Cheshirecatman
There is a fiddle factor to convert SCHRS to PY of
multiply SCHRS by 686
; BUT remember you are not rating like with like.
PY rates the sailor too; I would thus suggest (as the RYA do) that you then convert the resultant PY to something meaningfull for your club and conditions.
Cheshirecatman
Over here, we used the PY numbers from the 2 largest classes, the Hurricane 5.9 (691) and the Dart 18 (798) to get a good balance when we needed to convert other classes from SCHRS to PY.
- 1,135 Online
