H20 rigging question
2 Users
(@Anonymous 37811)
[#9185]
New to Cat sailing.... and new to these forums....
Please be patient as I might ask some stupid/simple questions in the days to come.
First question -- Where (fore/aft) do you place your barber-hauler car in relation to the tramp cover on your H20?
-JeffT
Posted : October 7, 2001 10:47 pm
(@hobie541)
First of all, there's no such thing as a stupid question! Post as much as you want!
Most of the people in our Hobie 20 fleet have those cars as far forward in the pocket as they can so that the jib breaks evenly. I forget which book has a really good explanation of where to put those things. It's either in Catamaran Racing for the 90's, or the Catamaran Tuning Guide. Both are available on this web site along with a whole host of awesome videos!! (Not that I'm at all biased).
Fair winds,
Tim Johnson
Hobie 20 #541
Bald Eagle Yacht Club, Fleet 52
White Bear Lake, MN
Posted : October 7, 2001 11:42 pm
(@Anonymous 37748)
Jeff,
Let me clarify a few things first. The standard barber hauler on a Hobie 20 constists of a pivot block fixed to the outboard ends of the forward cross beam (you knew that) The jibe blocks attach to a cable, the cable runs accoss the tramp under what I think you refered to as the tramp cover. That cable is secured to the hull via a car the runs in the same track the hold the tramp itself. You are asking where those two cars should be located fore and aft. The answer really depends on a number of variables, but your goal is to get the jibe telltales to
break
evenly. When sailing the weather pinch the boat up a bit, if the top inside tale luffs first the cars should move forward, if the bottom inside tale luffs first the car should move backward.
If you wish to set your boat up relative to other boats you should pay attention to you mast rake. More mast rake requires the jibe blocks and cars to be moved forward. Also pay attention to the age/type of tramp you have compared to others. The cover on newer tramps is further forward then older tramps.
My suggestion if you are new to sailing. If the boat is used chances are the previous owner set them where they need to be. If the boat is new your dealer should have been able to set the boat up reasonably well. So leave them where they are and just go sailing. If you season is over like it is for so many of us I guess you will just have to read aboat it.
Posted : October 8, 2001 6:41 am
