Help rigging a Nacra 5.8......!!!
Quote
Here are some photos of my set up, I would like to know how to attatch the forestay to the tang. My problme is that my roller furling connection will not fit onto the shackle....any input would be appreciated ...Thanks!
It looks like you have 2 different swivels and only need one. Get rid of the old style swivel and use the Nacra plate that Philip gave you the part number to. You can also make your own plate at a different length if you need to.
Posted : May 18, 2008 11:21 am
That appears to be a Harken swivel, it is not 2 seperate swivels. Turn it over (end for end) and the attach it. It should work just fine. The bow shackel will attach the swivel to the forestay and the other end should connect to the shackel on the mast tang by using the clevis pin in that end.
Posted : May 18, 2008 2:47 pm
Quote
The lower one is a Harken swivel and should be turned around. The swivel he is holding in his fingers old style should be removed. He can use a pig tail or plate like the nacra style to finish hooking up the top.
Posted : May 18, 2008 7:14 pm
Forum Information
- 1,760 Online
Our newest member: Ejustes
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
