Hobie 18 jib sheet
1 Users
(@Anonymous 38017)
[#11796]
Just wondering how many use just one sheet in a loop or two separate sheets.? Is there a right or wrong way?
Posted : April 18, 2003 11:07 pm
(@Anonymous 2522)
It is a single line from becket on one side , trough the jib block, back through the cam, over to the other side, through the cam, then the jib block, then to the other becket. I think the Hobie parts catalog has a diagram and may also be available online. The set-up is similar to the H16 / H17 but to the side tracks instead of the front beam.
Posted : April 18, 2003 11:13 pm
(@Anonymous 1134)
Seperate sheets seem to always get tangled up with something important or wind up in the drink dragging along side the boat. One sheet is best! Especially for roller furling. If you use roller furling be sure to have enough slack in the sheet so it will extend out to the forestay when the jib is rolled up.
AJ
Express 6.0
Posted : April 19, 2003 8:53 am
