Hobie 18 Plunger Assembly
I have broken three starboard plungers recently. It appears that when the rudder cam over rotates the plunger squirts out between the cam and the lower casting and breaks the shaft of the plunger off at the head. This is the newer style casting. I have had no trouble with the assembly on the port side. Any recommendations?
Posted : May 17, 2004 2:25 pm
Sounds like wear. Basically things have worn down and the holes have gotten bigger so the plunger can do something it was not intended to do.
1) Replace the Cam or if it's new swap side to side.
2) Look at the 2 rudders assemblies, something on the other side is keeping it from have having problems. Try and duplicate it.
Once you figure out what the problem is, post again and I will try to help.
Posted : May 18, 2004 10:31 am
Forum Information
- 2,944 Online
Our newest member: Ejustes
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
