I 20 set up help
(@powergroove)
[#12411]
Just boat an I 20, need some basic help. What size/type/length line are you using for the snuffer halyard?
anyone have an upclose pic of your downhaul you are willing to share?
What about class/fleet membership or website.
David Mosley
Posted : August 14, 2003 10:34 am
(@stank)
One Star Admiral Registered
Sorry I don't have any pictures, Dave, but the halyard is the same size for both snuffer and pole applications. It comes with the boat, and I'm guessing it's in the 5/16" range.
And downhauls vary as much as sunglasses. I used to have double blocks attached to a hook on each side of the sail's grommet to achieve the rated downhaul purchase. I have since moved to a cascade system (same purchase ratio). Here's a brief description of setup.
I tied two blocks (about 29mm)to the main via a short stretch of spectra through the grommet, and these hang about 2" from the grommet's lower edge. I have another pair of smaller blocks (sized for your downhaul line) with short pieces of spectra that go on next. The line on the smaller block is routed through the larger blocks on the main, and then led to the front of the mast, where the two lines are tied together (it is best to pull the sail down a bit and tie securely to minimize slack). The downhaul line is then led through the system as follows (from one side to the other):
Downhaul line through pivot/cam block (backwards, of course). Next, run line up through smaller block and back down to center cheek block on the mast. Continue back up other side through smaller block and down through pivot/cam block (forward).
As you pull the downhaul, the line will pull the smaller block downward through the bigger block attached to the grommet. That's the cascade system. It sounds complicated, but if I have a picture of it in use, I'll try to attach it...
Posted : August 14, 2003 11:57 am
(@stank)
If that's Team Space Coast's old boat, it should be all ready to go with the halyard and downhaul. If I recall, that boat did sell to someone in SC...
In any case, congrats on your fine choice of boats.
Jay
I-20
USA 501
Posted : August 14, 2003 12:00 pm
(@powergroove)
Youre right, Team Space Coast' boat. The halyard just seems a little large, especially for the lake wind.
Hope to sail with you guys soon!
David
Posted : August 14, 2003 1:31 pm
(@Anonymous 335)
David,
Most sailors use 3/16 or smaller and taper it on both ends if using the snuffer (I think marlow is stock). The lengths of the haylards I used on my I 20 were different when using a snuffer vs. straigth pole but it depends on how you rig it. Most I20 sailors that use the snuffer run the halyard from the head of the spin up through the bail on the mast(some attach a small block on the bail) up through the cheek block on the mast down through the bail to a block on the front beam (some run the haylard through the spreaders and some have a bungee loop in front of the spreaders)then through a cleat or spinlock to a block attached to the rear beam with bungee and back to the front beam (some drill through the front beam and put a thru deck bushing on each side especially if you have a self tacker) into the snuffer bag through the patches in the spin and tie off to the last patch. Have fun
Posted : August 14, 2003 1:50 pm
(@powergroove)
I wasnt sure about the bungee above the spreaders, but thats how I ran it. Just dumb luck I guess. I did make the mistake of attaching the staight pole(non-snuffer) halyard and raising the mast, only to find the snuffer spin had its own halyard. I used the old paperclip and masking tape trick to run the snuffer halyard up.
Okay, now how do you sail this thing? JK
David, are you going to be racing for the Alter Cup quailfier with us?
David Mosley
www.seacats.org
Posted : August 14, 2003 3:42 pm
(@stank)
Two resources (well, actually three)
1. Rick's book - Cat sailing for the 90's. Good fundamental info
2. Rick Bethwaite's "High Performance Sailing" - sort of a "all hail the Aussie 18", but jam packed with moderately technical information
3. A amature website laden with tips and good ole' smack-talk www.1design.net Predominantly I-20 sailors, you'll get candid advice from national champs and wanna-be's like me!
And I think this site tells me where you live, so if we don't see that boat at next year's St. Augustine regatta, we'll all have to go up there and beat you!
Jay
Posted : August 14, 2003 4:19 pm
(@Anonymous 335)
David,
Yes I am planning on coming to the Outback Regatta and sailing on a Tiger or I 20 with Mike Krantz.
Posted : August 14, 2003 5:25 pm
(@powergroove)
waterbug,
Read Ricks book, took his class, sailed against some great sailors(Nigel Dave lennard, Rick Harper-My heroes) and now I am ready to step it up a notch and see what the I 20 class can do for me. I see that the portsmouth number is pretty low, maybe I can bring it up a little(HAHA)
David Mosley
www.seacats.org
Count me in for the St Augustine Regatta
Posted : August 14, 2003 9:31 pm
(@powergroove)
Can you make Rick buy an I 20? We might have a fleet of 20's if so. Rick, Are you listening? Do I need to call your insurance co. for you?
BTW 2 I 20's preregistered.
See you on the water soon,
David Mosley
Posted : August 14, 2003 9:33 pm
Jake Kohl
(@jake)
I still can't believe my club hung me out to dry. ...I buy a 6.0NA with chute last year and everyone buys I20s....geeeze. There's always portsmouth I guess.
Posted : August 15, 2003 8:07 am
(@powergroove)
Its Cary's fault. Jake , we had a good meeting last night and planned alot of stuff. I will update the website tonight(possibly) but the gist is..
Canoe/kayak down the Saluda river wed the 27th 3pm(then every 4th wednesday of the month)
Mountain biking every sat 7am, Harbison state park
One Lap of Lake Murray sept 14.
Hunting Island camping biking, canoeing October 17-19
We are traveling the group to Catfest sept 6,7th.
David
Posted : August 15, 2003 9:56 am
