Is this true about our auto gas
Just got an email with the link below on ethanol in our gas. I know for Outboards you need to use Rec90, which is free of ethanol, but this sounds really bad.
http:/
I believe that E-15 is for those
Flex-Fuel
branded cars only.
Most marine manufacturers have said using any ethanol blended fuel will void their warranty on the motors and fuel systems.
Ethanol absorbs moisture (bad) causing phase separation.
Ethanol also removes some of the varnish and deposits in the cylinder heads/valves which then moves around and cruds up everything.
Most importantly (to a cheapskate like me), Ethanol does not contain the same amount of energy per gallon as gasoline, so I'm getting fewer miles/gallon using E10 fuel.
My outboard mechanic said E10 will corrode the aluminum carburetor in a short period of time, and it could eat some of the fuel hose, clogging the filter.
Ethanol should be used for cleaning and drinking
It's actually cars prior to 2001 that shouldn't use the E15 stuff (that fox report that said 2012 was wrong). I haven't seen the E15 in any gas stations but I suspect the public is at it's threshold with the 10% ethanol stuff and the blow back will make it go away soon enough.
Still being fought - article here
Unless you plan on burning all the fuel within a week or two, never use automotive pump gas as you can never be absolutely sure whether its an ethanol blend or not. Don't ask me how I know... <img src="<>/frown.gif" alt="frown" title="frown" height="15" width="15" />
We have E85 (85% ethanol/15% unleaded fuel) here in Australia
we even run our V8 race cars on it.... (think NASCAR engines)
http:/
I have 2 cars here that love the stuff and actually have better dyno figures with E85 than the usual pump stuff and indeed some of the not so usual pump fuels.... <img src="<>/wink.gif" alt="wink" title="wink" height="15" width="15" />
and before we all argue about it being an Australian thing....
ONE of the engines is from your beloved ole USA
<img src="<>/grin.gif" alt="grin" title="grin" height="15" width="15" />
Pricing is competitive too with the ethanol fuels on average 10-20% cheaper over traditional fuels.
yes we use more but not 10-20% more so it does actually save you $$$$$$
Older engines don't like it so much but, specifically re-built engines and tuned to run on ethanol fuels will give better power and economy over the original engine even when it was at its very best.
http:/
Oh.....
your fuel prices are dirt cheap too in comparision to ours
Here...... 1lit of premium unleaded ~$1:70
3.7854 lits = 1 us gallon
therefore.....
$1:70 x 3.7854= $6:43 a GALLON
<img src="<>/shocked.gif" alt="shocked" title="shocked" height="15" width="15" />
and your paying how much a gallon
<img src="<>/sick.gif" alt="sick" title="sick" height="15" width="15" />
E85 sells for around ~$1:50 a lit...
<img src="<>/cool.gif" alt="cool" title="cool" height="15" width="15" />
This, it's really bad in applications like outdoor power equipment.
Energy Density in Volume (MJ/L)
Hydrogen Gas = 0.01005
Methane = 0.0378
CNG = 9
LPG Propane = 25.3
Gasoline = 34.2
Diesel Fuel = 37.3
Jet A Fuel = 33.0
E10 Gas = 33.18
E85 Gas = 25.53
Biodiesel = 33
Ethanol = 24
ANFO (you make bombs with it) = Lots
Antimatter = 9.266 x10^104
I suspect that E15 and E85 contain other additives to increase the energy content per liter.
There's nothing against burning ethanol (or wood, or any other material), you just have to optimize the engine for that particular fuel.
In the case of E15 - E85, older cars just aren't optimized for those characteristics.
I'd prefer Antimatter, but maybe that's in next year's model cars...
I drive a 20 year old Z-car. In the past 18 months I've had to have the injectors replaced, the fuel lines replaced, and the tank dropped and drained. All ethanol related problems. I run premium fuel, keep the tank topped off, and use a fuel stabilizer, but that is not enough...
You can vote with your wallet, plenty of stations around here have started selling non-ethanol again.
Maybe you can, but the only stations on this list (http:/
Had the same issues with my 1990 jeep and the generator on the old RV. After spending almost $1000 in repairs on the gen I ran only non-ethanol and stabilizer......never had another problem. Same for the jeep, have not had any issue since keeping away from the ethanol.
Was also told that it is not good for my 05 durango.
1994 300 ZX TT, perhaps? Maybe black 2 seater? man, I loved that car. added bigger turbos, stronger waste gate springs, camshafts, tapered valves, 50 shot nitrous and a roll cage.
To be young, stupid, and spend all your money on go-fasts...
yeah we sort of have a bit of an addiction to them here....
<img src="<>/crazy.gif" alt="crazy" title="crazy" height="15" width="15" />
Mine.....
extensively modded <img src="<>/grin.gif" alt="grin" title="grin" height="15" width="15" />
Oldest sons
The Wifes
the trio <img src="<>/wink.gif" alt="wink" title="wink" height="15" width="15" />
Stephens red zed hadn't been into the shed at that stage
our for a play <img src="<>/wink.gif" alt="wink" title="wink" height="15" width="15" />
seriously jealous. But now I know why they're so hard to find (at least the un-mod ones).
Would have liked that anniversary edition ('97 I think?) Supra TT coupe as well.. but way out of my price range at the time.
I applaud you both for (1) the budget to mod/race those things and still have money for sailing, and (2) spouse/family that approves of such road monsters.
the only thing i DIDN'T like on the 300 TT was that HICAS setup . Got it tuned right but the OBDC kept throwing codes at me so I had to override it eventually. Must have had something to do with the torque loading in full boost, or the replacement differential I had on there after we destroyed the first one dyno testing.
I think they went to ridged tubing back then, but if not check the rubber lines and see if the used 30R9 from the regulator to the fuel rails. If not, not a problem, they probably used the 30R7... Just keep an eye on it them as the alcohol can cause premature deterioration.
- 1,933 Online
![[Linked Image]](http://imagizer.imageshack.us/v2/xq90/844/kgkk.jpg)
![[Linked Image]](http://imagizer.imageshack.us/v2/xq90/839/img3698k.jpg)
![[Linked Image]](http://imagizer.imageshack.us/v2/xq90/831/img3773k.jpg)
![[Linked Image]](http://imagizer.imageshack.us/v2/xq90/607/5s1q.jpg)
![[Linked Image]](http://imagizer.imageshack.us/v2/xq90/208/n4x8.jpg)
