It looks really different!
11 Users
(@catfan)
[#17763]
Have a look a this photo:
http://www.bimare.net/fotox4/X-4-6-bis.jpg
The new BIMARE X-4 Formula 18 looks really different from the other F18s pictured (Cirrus, Hobie Tiger, Mattia Flash).
Posted : June 6, 2006 10:09 am
 robi
(@robi)
wow what a beautifull backdrop. That picture will make an excellent desktop background. HINT HINT!
Do all Cirrus boats have that paint scheme?
Posted : June 6, 2006 10:48 am
(@catfan)
I found some MORE X-4 pics at:
Posted : June 6, 2006 2:07 pm
TEAMVMG
(@TEAMVMG)
Looks like a half decent race going on, any results for the new boat
Paul
Inf GBR7
Posted : June 6, 2006 2:57 pm
(@Anonymous 38278)
Good looking boat. A class hull shape was predictable.
Interesting mainsail top treatment to transfer sheet loads to mast tip. Should go well.
Posted : June 6, 2006 5:27 pm
Jake Kohl
(@jake)
Quote
Are you talking about the triangular reinforcement patch? That is different.
Posted : June 6, 2006 5:41 pm
(@mauganh17)
looks like it needs more bow.
IMHO
Posted : June 6, 2006 5:58 pm
(@Anonymous 38278)
Yes the triangular patch. There is an inherent problem with big square tops. The last two battens need to be very stiff to hold the top corner out against the sheet load, which goes in a straight line to the mast head.
The A class has used that bow for some time now and if the other accompanying design features are included, and the boat is sailed to design, it works fine.
Posted : June 6, 2006 6:54 pm
(@_removed-account)
Four Star Admiral Registered
It seems like this boat may be at an advantage in waves. Looks like a lot of freeboard and not much bow (will limit pitching).
Posted : June 6, 2006 7:08 pm
Jake Kohl
(@jake)
Quote
In my opinion, I think you are right but to a point. Most F18s are already quite sensitive to driving in bows in the heavy stuff - those bows look like they could be very sensitive and the lack of rocker on the bottoms might make it difficult to trap far back and keep the bow high.
Posted : June 6, 2006 7:19 pm
(@_removed-account)
Lack of rocker? Maybe I don’t understand what rocker is. When I saw the first picture (6 months ago) of the prototype from the side, the first thing I thought was “wow that’s a lot of rocker.”
Posted : June 6, 2006 7:30 pm
PTP
 PTP
(@CaptainPP)
I ain't buying that this is a stable boat with spin up.
IMO
Posted : June 6, 2006 7:32 pm
Jake Kohl
(@jake)
Perhaps your thinking about the decks <img src=
/>...I don't know - it's kinda hard to see from the angles - but it looks pretty flat.
[Linked Image]
Posted : June 6, 2006 7:39 pm
(@mauganh17)
Quote
As many on here are fond of pointing out, an F18 ain't no Acat.
Not even the same ballpark.
Posted : June 6, 2006 8:04 pm
bvining
(@bvining)
I think it looks quite like the Jav2 18HT, except more freeboard and slightly larger throughout. The rear beam looks to be higher than the HT. Once the rear beam was raised on the HT it solved a bad habit the HT had of pitching forward when the rear beam slapped a wave. Hopefully this one is high enough. It looks fine in the pictures, but the only way to tell for sure is in a nice spicy blow.
I think the bows will be fine with the kite up. It will definetely be sensitive to weight placement, just like the HT.
I think its got lots of rocker, at least thats what it looks like to me.
The rudder castings look like the same Bimare treatment as the HT and the Bim ACats, which was locked down and didnt allow for kickup. A weak point in my opinion. Rudders and daggers are black, are the just painted or are they carbon? Does the class allow carbon foils?
Good looking boat, sails look great. I'm suspicious of the rudders.
Posted : June 6, 2006 8:28 pm
(@Anonymous 13976)
Make sure to sharpen your trailing edges really well so you need stitches in your forehead after they do that 180 degree thing while you are leaning over the back of the boat trying to get them unlocked.
Posted : June 6, 2006 9:13 pm
(@jalani)
Rocker = amount of curvature along the keel line in the vertical plane
Sheer = amount of curvature along the deck line in the vertical plane
Tumblehome = amount of curvature from the topsides towards the gunwhale/deck centreline
Posted : June 7, 2006 2:40 am
(@wouter)
Quote
Ain't that the truth !
There are indeed major differences in the design between these two boat types. There are things in either design that you simply won't do in the other for risk of ending up with a bad boat. An F18 needs to be designed as an F18 fully from
the ground
up.
Posted : June 7, 2006 5:42 am
(@catfan)
Bill,
you hit the nail on the head.
Evidently you have a deep knowledge of BIMARE catamarans.
I was told from Daniele Saragoni that the X-4 was designed to be the MOST sensitive to weight placement F18 on the market.
It departs quite a lot (much more than it looks at first sight) from the Capricorn, the Nacra Infusion, the Blade and the other so called wave piercing F18s.
Its hull has almost the same width and volume at the bottom (actually 3-5% less) than the above mentioned boats, but with a different allocation: quite the same at the bow and in the middle but less at the stern.
On the other hand X-4's hull has some 25% less volume in the upper part:
the bow is no less than 15 cm (or 6 inches) shorter than the one of its shortest competitor and the deck is on average 12 cm (5 inches) less wide.
While the other F18s have quite vertical sides the X-4 shows a distinctive elliptical shape.
As a consequence of its general design it features roughtly 20% less windage upwind.
Besides, due to the elliptical shape of the outer side of its hull, it has actually more rocker than its competitors when sailed heeled. In such circumstances (as the Javelin 2 does) the X-4 is expected
to rest on
its downwind stern and to lift the bow clearly out of water surface.
The X-4 does not feature canted hulls because, according to BIMARE, this solution does bot help heavy two crew 18 footer to go faster.
The foils are carbon since the F18 class rule allows carbon for rudders and daggerboards.
Posted : June 7, 2006 5:43 am
(@wouter)
F18 class allows carbon boards now. They have to otherwise they can't make their boards as long as they are now. The F18's are now using board that as over a meter long (as in the part that sticks out below the keel line) The stresses in these are pretty high. The newer F18's are running with aspect ratio's between 5 and 5.5 now. And that is very high.
Wouter
Posted : June 7, 2006 5:45 am
(@catfan)
Hi Paul
Finally I was able to find the results of the pictured regatta:
Trofeo Cisalpino F18
Results:
No Numero Nome Punti 1 2 3 4 5
1 400 Ferrari Ugo, Stella Maurizio, F18, 437-15-C VELA DERVIO butt DILET 6,0 2 2 1 1 (3)
2 33 Blancato Luigi, Pennino Gaetano, F18, 264-07-CIRC VELICO ORTIGIA butt 8,0 1 (4) 2 3 2
3 727 Sicouri Pierre, Forni Davide, F18, 431-15-GDV LNI MILANO 14,0 (11) 1 3 5 5
4 1400 Vettori Cristian, Lunz Andrea, F18, 412-14-GDV LNI RIVA DEL GARDA 20,0 (7) 5 5 6 4
5 29 Fumagalli Mauro, Boschini Matteo, F18, 637-15-butt. DILETTANT VELICA A 31,0 3 6 12 10 (dnc)
6 34 Fava Paolo, Giannatempo Francesco, F18, 449-15-VELA SURF C.D.PIEMONTE 35,0 12 7 10 (dnf) 6
7 912 Necchi Vincenzo, Bertani Luca, F18, 433-15-GDV LNI MANDELLODELLARI 38,0 5 8 (26) 13 12
8 777 Riches Pierluigi, Riches Lorenzo, F18, 437-15-C VELA DERVIO butt DILET 38,0 6 (13) 11 8 13
9 411 Saragoni Daniele, Pazzaglia Achille, F18, 339-11-C VELA CESENATICO butt S 39,0 8 10 14 7 (dnc)
10 999 Fantasia Giovanni, Formica Giovanni, F18, 437-15-C VELA DERVIO butt DILET 43,0 (17) 16 4 9 14
11 171 Manacorda Michele, Porretti Alessandro, F18, 431-15-GDV LNI MILANO 50,0 (dnf) 14 18 11 7
12 40 Manenti Davide, Tinti Gilberto, F18, 323-10-C V ARDIZIO butt SPOT DI 51,0 14 17 (20) 12 8
13 213 Vaccari Manuel, Introini Carlo Paolo, F18, 423-15-C V ORTA - butt SPORT DI 53,0 24 12 (27) 2 15
14 490 Chinotti Giampietro, Pagliarini Gianluca, F18, 420-15-ASSNAUTICA SEBINA - butt 59,0 9 3 7 (dnf) dnc
15 1586 Vitale Fabrizio, Favro Fabrizio, F18, 523-02-G VELA ASSONAUTICA butt 60,0 10 (dnf) 9 dnf 1
16 412 Monti Matteo, Brolli Andreas, F18, 339-11-C VELA CESENATICO butt S 63,0 19 (24) 22 4 18
17 910 Morini Giorgio, Marcassoli Mattia, F18, 437-15-C VELA DERVIO butt DILET 64,0 15 15 17 (dnf) 17
18 463 De Grenet Riccardo, Marzorati Claudio, F18, 690-15-ORZA MINORE S V butt SPO 69,0 22 21 16 (dnf) 10
19 775 Hartner Gianluca, Poli Walter, F18, 410-14-CIRCOLO VELA ARCO butt S 70,0 13 11 6 (dnf) dnc
20 69 Citterio Maurizio, Chiesa Cesare, F18, 437-15-C VELA DERVIO butt DILET 72,0 4 20 8 (dnf) dnc
21 90 Gattinoni Roberto, Caprioglio Fabio, F18, 411-14-VELA CLUB CAMP. GARDA A 75,0 25 18 23 (dnf) 9
22 835 Drei Luca, Baldazzi Giancarlo, F18, 341-11-ADRIATICO WIND CLUB butt 75,0 23 19 19 14 (dnc)
23 9 Zamorani Enrico, Drei Stefano, F18, 341-11-ADRIATICO WIND CLUB butt 78,0 16 9 13 (dnf) dnc
24 905 Faverio Michele, Tirrito Duccio Jacopo, F18, 690-15-ORZA MINORE S V butt SPO 83,0 18 28 21 (dnf) 16
25 85 Poggetti Pietro, Angusti Stefano, F18, 092-02-C.V.PIETRABIANCA butt SP 102,0 21 26 15 (dnf) dnc
26 497 Santini Giorgio, Barbieri Maura, F18, 091-02-GDV LNI FOLLONICA 105,0 30 (dnf) 24 dnf 11
27 586 Nocchi Federico, Biancani Matteo, F18, 092-02-C.V.PIETRABIANCA butt SP 108,0 20 23 25 (dnf) dnc
28 1013 Basta Palmiro, Basta Claudio, F18, 437-15-C VELA DERVIO butt DILET 122,0 28 22 32 (dnf) dnc
29 64 Sassoli Roberto, Marrubini Giorgio, F18, 437-15-C VELA DERVIO butt DILET 124,0 31 25 28 (dnf) dnc
30 495 Bortolato Giovanni, Vigano' Mauro, F18, 437-15-C VELA DERVIO butt DILET 125,0 26 30 29 (dnf) dnc
31 797 Calogero Marco, Pesenti Claudio, F18, 437-15-C VELA DERVIO butt DILET 127,0 29 27 31 (dnf) dnc
32 509 Lombardi Simona, Pennati Laura, F18, 420-15-ASSNAUTICA SEBINA - butt 139,0 (dnf) 29 30 dnf dnc
33 1398 Bastianon Matteo, Canepa Edward, F18, 411-14-VELA CLUB CAMP. GARDA A 147,0 27 (dnf) dnf dnf dnc
34 732 Bovo Fabio, Di Staso Daniele, F18, 437-15-C VELA DERVIO butt DILET 160,0 (dnf) dnf dnf dnf dnc
34 813 Bellotto Gianfranco, Chistè Sergio, F18, 412-14-GDV LNI RIVA DEL GARDA 160,0 (dnf) dnf dnf dnf dnc
34 1184 Rampi Alberto, Sivini Danilo Paolo, F18, 411-14-VELA CLUB CAMP. GARDA A 160,0 (dsq) dnf dnf dnf dnc
34 118 Mina Alberto, Senini Lucia, F18, 437-15-C VELA DERVIO butt DILET 160,0 (dns) dns dns dnf dnc
34 31 Pria emanuele, Orlando Simone, F18, 437-15-C VELA DERVIO butt DILET 160,0 (dnc) dnc dnc dnf dnc
34 836 Di Traglia Mariano, Bartesaghi Elio, F18, 437-15-C VELA DERVIO butt DILET 160,0 (dnc) dnc dnc dnf dnc
The first X-4 took the 9th place out of 39 competitors (it was a Italian National F18 event).
Apparently the boat is slowed down by its sails (expecially the jib).
This is not surprinsing since BIMARE has been making ONLY mainsails for the last 30 years!!!
Posted : June 8, 2006 9:39 am
