Lohmayer and Livingston Tracking Live
Jamie Livingston and Steve Lohmayer are doing the Everglades Challenge Race this weekend. They did it last year on the Tornado and won. Jamie writes:
Steve Lohmayer and I are doing the Everglades Challenge this Sat March 7th. It starts
at 7am we will have a tracking device and the link is enclosed. The race web
site is http:/
below link if you would like.
http:/
From the Race Board:
Though we do not know the whole story yet, SewSew turned over off of Naples and was unable to recover. He was calm, had on life jacket with VHF in hand and was able to give the Coast Guard his exact position. He is safely at the Ft. Myers Coast Guard station and his shore crew is on the way to pick him up. We'll let Randy fill in the story later.
Jrock and Lrock is Larry - Cat in the Hat and his Tybee crew, sorry I can't think of his name right now.
This looks like such a blast except for the dropping the mast part.
Here's another tracking link, but I can't find Jamie;
Link
I think if you know you are going to have to drop it quickly, and then raise it again, you could rig up a quick disconect pin and use the spinnaker halyard, tied off to the bridle to lower it slowly and hold it back up too. Of course the bridal, spin pole and snuffer are all going to drop into the water as you loosen it all up, but you might be able to keep the crew up on the bow to hold it up until you get under the bridge, then raise it again.
I would love to see some video of this being done however!
You could also put the spin pole bridles and the forestay bridles inside some tubing (plastic, carbon, aluminum) that would go from the tang to the connection point on the pole. With the mast down, the pole would still be supported by the tubing.
I have to ask. Why drop the mast? Capsize the boat and then either walk it under the bridge or sit on the bottom hull and paddle if it is too deep to walk. There is a race around an island in the UK every year and they do exactly that to go under the bridge linking the island to the mainland (which being the UK is also an island, but I digress <img src="<>/smile.gif" alt="smile" title="smile" height="15" width="15" />
This seems so obvious I must be missing some key information there. Why do they have to remove the whole mast?
[Later edit: Video clips showing how it's done]
It's a tornado and the beam is greater than the bridge height. I talked with jamie about this at the Tybee because we were thinking of doing it, and with the size of the bridge spans it was the only option, even for an I-20, I think.
Jerry ,
That's awesome, I didn't realize it was Larry. They aren't keeping track of them very well on the site or they have a problem,one or the other. Do you know if he has a spot locator website?
Also sounds like Alan's Mom (what a cool lady)is doing it AGAIN, but no Alan.
Todd
There was a comment on SA that Jamie had a special head sail to go upwind in the light...and it was red, white & blue. Sounds like the mythical Chupacabra (Lovell & Ogletree's secret weapon from failed Olympic bid)has made its return and (finally) found some glory!
Dropping the mast on the Marstorm T so no small task. There is no hinge arrangement on the step... just a thumb-sized stub which the mast base sits on. So, when the mast goes past a certain angle, the foot lifts off the stub and the mast will go free fall unless there's someone applying bodyweight loads to the foot to counter the leverage. This would be near impossible to do on the water...maybe they rigged up some kind of gin pole where they could do the job while still aboard.
- 2,730 Online
