Mast theory
I'd like to understand the basic theory behind mast shape and settings - in particular, the effect of spreaders. For instance, if I have 1.5" of pre-bend, does it matter whether the spreaders are in their forward or backward position? As far as I can see, I'd need more diamond tension to achieve a given amount of pre-bend if the spreaders are in the forwards position rather than back, but does that affect sailing performance?
Let the debate ensue!
Sail makers cut a constant luff curve. In order to get your sail to flow well at top, middle, bottom, the mast must generally follow the luff curve of the sail. Lets say there is a amount of luff curve your sail maker has placed in your sail (X). In order to match X in your mast you can play with your spreaders and/or your diamond tension. You can place your spreaders forward and put huge amount of diamond tension and get to that magic number, X. The result of this would be a mast that would be very stiff down low and bend a lot up higher ( NOT a constant curve). Now lets put a lot of sweep in the spreaders and less diamond tension to get to X. The result will be a mast that bends more down low than up top (NOT a constant curve). If you play with both in relation with other you can come up with a curve that is more constant (even) and therefore better matches your sail. This will allow you to get your sail to flow at top, middle, bottom. That is a good thing.
Ken
I think what he is asking is if a given amount of pre-bend can be obtained with 1.5 inches of spreader rake and 500lbs of diamond wire tension and the same amount of rake can be obtained with 1 inch of spreader rake and 750lbs of diamond wire tension (for example!!!), is one setting preferable over the other?
The amount of spreader rake will affect some of the mast bend difference between fully loaded and lightly loaded. As the rig is loaded through wind pressure and righting moment (trapeze), the diamond wire(s) are in additional tension as the mast tries to bend away in the middle.
The amount of rake in the spreaders affects how much additional forward bending pressure is applied to the mast as it loads sideways from these dynamic loads. More spreader rake means that the load on the diamonds will translate more into a forward bending moment on the mast as the load increases and you will experience a greater difference in the flexing of the mast from 8 knots and sitting on the trampoline to full trapezing in 20. Less spreader rake translates into less forward bending moment on the mast yielding a smaller range in the flexing of the mast in the same situation.
Perhaps it makes sense for the dynamic mast bending characterics to be very similar between two teams of different weights. The lighter team would want more spreader rake because they dynamically load the diamonds a little less than the heavier team. To see the same dynamics, the heavier team would want less rake because their diamond wires are actually going to carry a little more load.
Lighter teams will probably want to see the mast flex through a wider range as the wind increases. Heavier teams typically want to see it flex less to accommodate the extra weight.
Thanks for the feedback. I can see the case for matching the shape of the sail's luff - this must be the 'best' position, but that would imply everyone would set their mast up in the same way. I have had advice from the designer / manufacturer to go to the
fat boy
setting, with minimum spreader rake, and maximum mast pre-bend. I am trying to understand the theoretical advantage this offers over the middle setting for each. I gather that with the spreaders raked less (putting them further forward), I will get a stiffer mast, at least in the lower section, and this will generate more power. And if I want even more power, I can ease off the diamond tension and get less mast pre-bend.
I am no expert, and could be VERY wrong,... but i thought pre-bend was mostly a result in spreader rake.. not diamond wire tension .
Everyone, please correct me if i am wrong
Pre-bend is a function of spreader rake and diamond tension. Less spreader rake and tension and the mast will be slower to react to gusts. More rake and tension and the mast will depower faster when you pull on downhaul or even when you go out on trapeeze. As always it is a compromise, but if you are racing it is critical to get a luff curve matching the bending characteristica of your mast. You can adjust it a bit with pre-bend, but getting the sweet spot where the mast do the work for you and depower in gusts is harder then.
I always have to remind myself that more power comes at the cost of more drag, it will not always be faster to have more power!
So to add to the confusion...when setting spreader rake, we typically measure by placing a straight edge (ie batten) across the two diamond cables at the spreader tips, then measure the distance from the straight edge to the mast track. When we're at the rake distance we want, then we crank on diamond tension (using a Loos guage). Typically, if we re-measure the rake setting as above, it does not change after diamond tensioning. So, to check pre-bend, you're suppose to stretch a line from mast top to mast foot and measure from the line to the mast track at the spreaders. This should change with differing tensions (the ends of the mast are flexing in the fore/aft direction with less/more tension, respectively).
I have never done the pre-bend measurement...since it can't be measured easily without tipping the boat on it's side and I'm too lazy 🙂
Well, I will repeat my question from the F16 forum about sail stalling here:
So far, I understood that I can adjust the twist of the main with pre-bend. But what is the best light wind twist? Should my main stall at the top of the mast/sail, in the middle or just above the boom? I am used that pin head sails always stall at the top first, however the square top sail which I have now stalls above the boom first. Do I still have to much twist?
Cheers,
Klaus
Klaus, you are the aeorodynaimist, you should be telling us <img src=
In my opinion the sail should stall over the whole at the same time when you have perfect trim. If your uni-rig stalls over the boom first, I would say you should try less twist. But, that would depend on conditions. In chop you probably want more twist. That is my opinion..
Hi Rolf,
Well, a theory without practical back up might be wrong, hence I ask.
That's what I think as well. But I see that you use subjunctive. Did you ever achieve this 'perfect trim' (I assume you use tell tales at the leech)?
Actually I have already a quite relaxed dimaond wire tension, maybe the leech is cut to long <img src=
Apart from confusing sail trim, my wife and I have had great time on the boat already. My wife did helm under spi for the first time and really pushed it to the limit and now she is really thrilled (she dived the bow up to beam, nothing happend, but a big shower for us).
You will be surprised, how sensitive these boats react on the smallest changes. I hope you get your boat on the water soon, so you can share this.
Cheers,
Klaus
Klaus,
Dependent on what you call light winds.
Stalling of the sail in light winds can also because by having too much draft in the sail; as in contrast to having a too large angle of attack. I think this could be the case here as the bottom part of the sail is widest and therefor the flow needs to have relatively alot of
internal energy
to overcome the
long
negative pressure gradient at the back of the sail.
In really light winds you'll want a flat sail with a considerable amount of twist. The flatness assures the sail won't stall due to negative pressure gradients that are too large and the (relatively) large twist on the leech compensates for the windshear.
However at some point in windspeed the wind itself transitions abruptly from laminair flow (with a significant windshear gradient) to a turbulant flow (with much less windshear) and then you'll need to bring the leech back in. When the wind increases more then the increase the draft; as the airflow is becoming more energized. You are now in medium wind conditions typically 6- 12 knots.
And only in high winds due to increase twist and decrease draft again.
In simple terms ; very light wind sailing has an almost identical sail profile as high wind sailing where the sail trim in the medium conditions is with a relatively full draft and tight leech.
Flat and rough water are influence factors as well. In flat water you can typically sail with a leech that is a little bit more tight and with a relatively unform draft profile. In rought water you sail with more twist and a draft that is located more in the lower part of the sail.
You use mainsheet, downhaul, diamond wire tension, spreader rake simultaniously to adjust the mainsail to these different conditions. Sadly it is not like one control only affects one adjustment. For example when you sheet the mainsheet tighter then you reduce twist and reduce draft in the top of the sail. Only be also using the downhaul at the same time can you increase twist again while flattening out the top even more. So if you only want to reduce draft in the top of the sail but keep the same twist profile then you have to adjust both settings simultaniously. This is sadly one of the more easy ones. Setting the draft profile properly also requires resetting the spreader rake and or the diamond wire tension together with the mainsheet, downhaul AND mast rotation.
As an aerodynamists you have more then enough learning and experimenting to do on your F16 !
But that is all part of the fun right.
Wouter
Hi Wouter,
That's one of the reasons way I changed from Dart 18.
Thanks for the details, so far they are clear for me. We have noticeable wind shear only a couple of days per year, hence 'my light wind', is what you call medium wind. My concern is, that (maybe) I have used already all trim to reduce twist and still the lower part stalls first, even with maximum outhaul (e. g. not to much draft). Or is it maybe not possible to close the top of a square head sail? So what is with your sail with maximum closed leech, stalls at the top or bottom?
Next week-end I will try to relax the dimaond wires even more (spreader rake is not adjustable on my boat <img src=
BTW: Are you a soccer fan? Excellent play of the orange team, maybe we will see another great match between Geramy and the Netherlands <img src=
Cheers,
Klaus
...the sail should stall over the whole at the same time when you have perfect trim
Ok, to be more accurate: On a reach or downwind in light winds (not yet heeling up), I would like to stall all over the sail at once, so I maximise lift. Upwind I would like to stall in the middle first. That is because I would like to have a good lift distribution over the mast height just before the stall to maximise drag/lift. That's my theory, not necessarily the truth.
Cheers,
Klaus
Large squaretop sails like a bit of twist along the leech. Pulling the leech tight on these sails with slow the boat down. The explanation given for this is often the unacceptable increase in drag because of having a large tip vortex.
On the French Sailing DVD Glenn Ashby says in an interview that his top is often around 300 mm twisting off, as taken from what would be a perfectly straight leech.
But you can feel it too. If the leech is to tight up top then the boats hangs up, it feels powerful but not fast. You heel easily but don't accellerate quickly in the gusts You don't get that nice
streaming
feeling that you would get with the right amount of twist.
Try it a few times, you will learn to feel it.
Wouter
Klaus,
if you are unable to get your top to stall first, it might be that you could benefit from having your sail recut. Usually I oversheet the squaretop by error in light winds and stall the top, not the other way around.
Do you know how much development have gone into that sail? Is it an old sail or a new one? Can the sail have stretched badly?
Thanks Rolf, that's exact the information I needed.
I can only guess, that they used an A-cat cut, but the mast is stiffer due to the reinforcement for the second trapez. Sometimes the leech between the top and second batten flutters a bit.
2004, pentex mylar from Petrucci, but not sailed much.
Could be, but I don't think so (6:1 mains sheet and sailed on lakes in the Alpes).
I will try to take some pictures next week end. (try = have the patience, not to be all the time on the water <img src=
Cheers,
Klaus
Wouter,
Do you have source for this DVD? Is it the one on Multihulls-world website? I can't seem to create an order there... <img src=
Mike.
Hmmm, what kind of battens do you have up there? Tapered and well tested? If the batten leech ends are too soft, you can get some flutter in the leech and more twist than you wanted in the top. Have the top inverted with full downhaul and strong wind?
If your mainsail goes slack in between battens in the leech in light winds, I would be tempted to speculate that there is too much luff round for your mast setup. Easiest and fastest way to test it is probably by putting the boat over on the hard and set mainsheet and downhaul, then adjust diamond tension. You could do the same on the water, but I like to get in the ballpark with the boat on its side and on the hard. Of course, that theory goes against your twist problem.. I would have put the boat over on its side and spent the time to find out what is really going on.
I think that is the same one, but give me a link to the multihulls-world order page and I'll check for you.
I seem to remember that Ricks online store featured these DVD's too !
Here is the link to the Rick White online store offer :
https:/
Wouter
Actually the battens are what I found in the sail, when I bought it.
No, never, but I think I never applied full downhaul, because I had already enough twist. Actually in strong winds, I am happy with the sail. However having some thoughts about the battens is never wrong.
Maybe I used the wrong wording in my previous posting: It does not go slack, it is tight, but the leech flutters. I think that the distance between the battens is just a bit to long. I do not really worry about that.
I lack the expirience to judge from the shape of the sail only. I need to go on the water and see the tell tales to understand what happens.
Rolf, thank you very much for the advices. Now, I know, that I should be able to stall the top. And that means that I have still to tweak on the settings. I will have a look at the batten(s) and try if I still can reduce the diamond tension before making them slack.
Cheers,
Klaus
Bingo!
I've placed my order.
Cheers!
https:/
Wouter
A couple of questions to help my education.
1. Rolf: Can you explain too much power/drag. I dont understand.
2. Wouter: I was led to believe the only factor that stalls a wing is angle of attack. I think I understand what you are saying (i.e. tweaking changes the foil shape and therefore changes the stall angle of attack). Or am I misunderstanding you?
David
- 5,591 Online
