N20 Diamond Wire?
What is the new adjustable diamond wire setup for the N20? I know it was discussed here within the last month, but I couldn't find it.
I think I have the originals as two wires with one adjustment. I thought I read here that each wire now gets it own adjuster. I heard in the bar the other night that only one wire gets an adjustment.
Posted : January 22, 2008 10:56 am
Chris,
The new wires are set up just like your original ones, except that one wire now has a turn buckle adjustment on it. You still set the diamond tension using the main adjustment in the center, but you can even things up with the turn buckle on the single wire. I believe this solves a quality control issue if one diamond wire ended up being slightly longer than the other.
Alec
Posted : January 22, 2008 12:20 pm
Forum Information
- 1,758 Online
Our newest member: Ejustes
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
