Need P18 port side rudder casting
Anyone have used Prindle parts? I have a cracked port side rudder casting. It hasn't come apart yet but I don't know how much stress it will take. Crack goes right through the rudder bolt hole...must be a weak point. Anyway it's an '82 P18. Has anyone had any luck welding cast aluminum?
Posted : June 5, 2006 12:21 pm
What is it with the port side, I broke mine a few weeks back, also the port side. It can be welded, I have had that done in the past. But it may break again right at the weld, so I would replace it if possible. Also look over at
www.thebeachcats.com. There is a P18 being parted out.
A P16 will also fit.
Good Luck.
Posted : June 6, 2006 9:08 am
Forum Information
- 2,245 Online
Our newest member: nacrainter18
Latest Post: NACRA Inter 17R / F17 Rigging help
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
