NEWBEE HELP
I just bought my first sailboat (Nacra 6.0) I have only sailed a dozen times but I am HOOKED! My son is fifteen and went to camp and experienced sailing on a Sun fisher I told him about Catamarans and this past summer we went out on a boat that we paid someone for each day. My question is I need a video that will give me instruction on how to raise my mast properly and sails and all the other little checks, Any help would be appreciated. Thanks Sailhawk
Welcome to the Dark Side! Congratulations on the Nacra 6.0, great boat and fast! You might be able to find a
Nacra Mast Raising
video on You Tube, but where are you located? If you can get to any local catamaran regatta with your boat, there will be lots of sailors there who can show you how to do it the easiest way.
That's a big, heavy stick, but it can be done alone if you know how, much easier with one helper to pin it while you hold it upright.
Are you in the USA or elsewhere?
Here's a You Tube video of an F18 mast raising: https:/
Do NOT do it this way! It should never take 6 people and a ladder to raise your mast!!
Here's one with only two people, but still they are using the trailer winch to pull it up.
https:/
Put it on the beach first, and then hook up the side stays. After you pin the base to the forward beam, put one guy on the tramp while the other gets back at the mast tip and just walks it up with his hands up over his head until he gets to the rear beam then the guy on the tramp can lift it to upright. Then the guy at the back runs around to the front and pins the forestay to the bridle.
I've done my Inter 20 mast alone many times, but I always put the boat pointing down a big hill in my back yard, so once the mast is up it will stay up by itself, while I pin the forestay.
Done. Takes maybe 3 minutes.
man, I would have kept that video to myself. That's a terrifying view of a lot of people who have no idea how to step a mast.
I had a 6.0NA for a while and it is indeed quite an awesome boat. The mast is definitely on the heavy side. I heaved mine up manually most of the time with the help of one other person as Tim describes but I did eventually switch to a winch on the trailer after a bout of back pain kept me out of a regatta or two.
But if we all did that, what would be the point of YouTube? <img src="<>/smile.gif" alt="smile" title="smile" height="15" width="15" />
between cat videos, the flying squirrel suit, and that halloween party
incident
at Hiram's Haul years back.... what's NOT to post on YouTube?
Couple more tips:
check for powerlines first.
tie a very long line to the fore stay and have the helper pull on that after the guy on the tramp gets the mast to his shoulders. The person pulling on the line can almost raise the mast with that kind of leverage if they stand out in front of the boat and the line is not too rough on the hands. The person on the tramp is just guiding it up.
Auto rotating is great, you just have to learn how to use it.
Got it
Yea that is terrible on so many levels
Having little kids pulling on guy lines, a yahoo on a movable staircase (who would surly get creamed if the mast fell), running the guy line through the mast yoke.... wow
Got it
They just needed a few more people <img src="<>/grin.gif" alt="grin" title="grin" height="15" width="15" />
It may be a little easier if they plant the tip of the mast in the ground. Then all use ladders to swivel the catamaran 31' in the air. and then use a crane to revert it back to the normal position (hulls down)....
Got it
Hey sorry if this is in wrong place
I have brought a nacra inter 17 from around the 2000-2005 model and it came with 2 x jibs ive been sailing it a lot with the small on witch works really well but for our club races some times there is very little wind and im trying to see how to use the other jib ? can it be use with spinnaker on ? and how do you attach the beam that goes closer to bow to put forestay to to hold bigger jib ? it must be missing some parts ? any photos or help will be grate cheer joel
- 2,174 Online
