Numbers for new Cat
Matt M
(@matt-m)
[#10203]
I know that this has been posted in the past, however, I am not finding it with the search engine. I am looking for the link to the site to calculate the Texel/provisional portsmouth number for catamarans.
Specifiaclly I am looking to find the provisional number for the new 3D-20 that Vectorworks Marine is building. The first boat is due to be launched this summer, depending on the delivery of the rig that randy Smyth is designing.
Any help finding this link would be appreciated,
Matt
Posted : July 2, 2002 11:44 am
(@sailwave)
Wouter has a Texel calculator on-line somewhere and ISAF have one for (ISAF SCHRS) at www.schrs.com.
Posted : July 3, 2002 6:34 am
(@wouter)
The calculators for both the Texel system (I made) and the ISAF small cat system are intended for small beach catamarans and I don't know how competable they are for the much bigger cat you talk about.
But the Calculators can be found here :
http://www.geocities.com/f16hpclass/F16HP_ratings.html
or
http://www.geocities.com/kustzeilen/ Under de header "home links"
Hope this helps;
Wouter
Posted : July 3, 2002 7:48 am
Matt M
(@matt-m)
Wouter and Colin
Thanks, but this brings up a few questions.
This boat is 20ft (6m) so it should fit within the guidlines of this rating system. I notice that there are no factors in the calculations for items such as beam, hull fineness ratio etc. I would assume that that this is because the designers would all create hull shapes within fairly close dimensional ratios, and that sail area would be increased proportionaly to the beam width on wider boats, and the sail area is a used factor. Do you guys have any knowlege on the background behind the formula.
Also, I remeber seeing Wouter tossing around some numbers to approximate a conversion between systems. Unfortunately the portsmouth system is used the most frequently around me. Any input would be appreciated.
We've finally got a Holiday weekend here in the States, and I'm very much looking forward to 4 days of some major big wind sailing in the sandhills.
Have a great one,
Matt
Posted : July 3, 2002 9:25 am
(@mauganh17)
Funny, when I get a holiday weekend, I look forward to the typical "hundred dollar weekend" [Linked Image]
Posted : July 3, 2002 9:47 am
