Olympic Multihull Specification
From SA
We are shocked. We cannot believe it. The ISAF presented the rules for the Mixed-Multihull evaluation trials yesterday, and incredibly, they have excluded the Tornado Class from competing in the trial! The Tornado class is the forerunner in Mixed Multihull Sailing, is an amazing performer, and has a great Olympic History. None of this matters to the ISAF Technical Committees. Their rules for the trials:
20-Foot Container
ISAF restricted the length of the new multihull to be a max of 5.898m (the inner length of an 20 Foot container), but no one will travel with a 20-foot container. Anyone who ships boats around knows that a 20’ box is too small to be economically (or environmentally) friendly for long distance travel when shipping anything bigger than Lasers, and that 20-footers are frequently more expensive to move than 40 footers. If you want eco-friendly, economically efficient transport, the Tornado has been doing it for literally decades (10 Tornados plus coach boat plus all equipment in one container) with 40 footers. Why the unreasonable restriction?
2-Piece Mast Required
A two-piece mast is heavier than a one-piece mast. It’s more complicated and far more expensive to construct. It’s less reliable and more subject to breaking. It’s harder to make it watertight. Over time, the juncture can loosen up and change bend characteristics; you can even change mast bending just by playing with the joint. Two piece masts do only one thing well: Fit in 20-foot containers that won’t be used anyway.
120-140kg Crew Weights
Wow – another class like the 470, windsurfers, and 49ers goes the featherweight route! For 2016, an average man of 80 kg has no chance any more. With the Star and Eliot out for 2016 and the multihull going the waif route, only the thinnest and wiriest of athletes will be able to sail for a gold unless your name is Ainslie.
Many mixed-multihull teams, including some extremely successful ones, weigh well above 140 kg. And the new average weight of a mixed team should be 130kgs? This could disqualify 50% of all mixed sailing teams even with dieting.
What weight statistics ISAF used? If you watch real Olympic Athletes and normal average weight statistics, we end up above 140kgs. The 120-140kg team weights with an average of 130kg forces bulimia for Olympic Athletes. Check this.
National Sailing Federations - MNAs
They lost the Starboat. They lost the Elliots. Now they lose the Tornados, which are ready to sail on all continents today. Let’s ask the MNAs what they think about this. Every 4 years the MNAs have to buy new Olympic sailing equipment? Who should finance this?
Media
ISAF want have a small boat. The media will have less interest in it. Sailors get fewer sponsors because the boats are less impactful. This means: Downsize Olympic Multihull Sailing…so the media won’t pay attention…
ISAF Committees
If you looked carefully inside the technical committees of the ISAF, you see sailors with great commercial interest who create the rules the way it fits perfectly to their boats/products they sell. The Tornado Class is a real non-profit organization, but what about the commercial interests of some sailors on the inside? Is it possible that a few bad apples, with a say in the rules, weren’t happy enough to have kicked the Tornado out of the Olympics four years ago so they kicked it out again – but this time, even before reaching the starting line of the ISAF trials? It might just be.
ISAF must act now!
There is only one way to come out of this dilemma. Change the rules and allow the original “Tornado” to sail the ISAF evaluation trials! E-mail me if you think you can help!
Best regards,
Roland Gaebler, Tornado Class President
20-Foot Container
Media
ISAF Committees
ISAF must act now!
Best regards,
The Tornado is not ruled out, it just needs a new mast and a slice out of the bows, not really a big deal.
About the requirement to fit into a 20 ft container:
When you have enough boats you can ship twice the number of boats of a 20ft container in a 40 ft one with all the ecologic and economic benefits of it. However, If you have just a few boats, a 20 ft container will be viable and a lot less expensive. Makes sense to me.
I agree that the weight requirement favors a smaller boat. The committee is probably thinking 16 ft. Interestingly the three ISAF guys with whom I talked last week were all thinking F18. They are monohullers, never heard of the F16 and this can probably be credited to a slight but noticeable bias towards Argentina, the only place in S.America where there is an F18 class and an F18 builder.
I guess the requirement of a mast with the same characteristics Hobies have to use in the US is meant to allow Hobie to have a shot at it. Without this requirement they would be in obvious disadvantage vis-a-vis Nacra.
What about an F18 with a wing?
From what I understand it is good at depowering which is good for a light teams, has lower sheet loads for female crews, and is easy to take apart for shipping.
Pricing might be a little higher but you wont have to replace a sail every few months.
The AC guys have actually proposed a 20ft cat with a wing mast for the Olympics. While it does seem quite a leap from what we have currently, there are some very good reasons why it does make sense. They are saying the cost is something like 3,000 Euros (from memory - please don't take this as gospel) more than a soft sailed boat.
I too was pretty sceptical about the issue of damage during capsize, but if you have watched the videos from Plymouth you will see that the only issue is when a crew member falls into the wing - the same problem as if you fall into a soft sail. Compare this to when the guy fell into their carbon mast in Qingdao and broke it in two in the Extreme 40's.
And the skin material is extremely strong and quite inexpensive. $NZ67 worth of material to reskin an AC45, and it is a low skilled job to reglue a new skin.
Would be a kick in the pants, but just not sure if it is what we need in the Olympics.
I would be the first to put my hand up for a sail on one!
So PLEASE, everyone, have a good read of the spec. I didn't write it, but read the details. If a boat doesn't meet all the criteria, then it is NOT AUTOMATICALLY EXCLUDED. Manufacturers just have to come up with reasons why their boat is the best, and they may lose points if they don't fully meet all the requirements in the spec.
Wouter,
Correct, 49ers don't come with a 2 piece mast. They come as a three piece mast. <img src="<>/smile.gif" alt="smile" title="smile" height="15" width="15" />
http:/
I'm aware of that but the joining of the parts is rather permanent. It is not designed to be taken apart regulary for transport. Neither do you want to as you have to take everything off, the multiple diamond wires etc. You loose all trim settings and the bloody thing is stuck half the time because it is hardly ever taken apart or at least it was on the boat i sailed for awhile. We had to hammer it apart (HARD) till we found another way to run any lines through the mast after a mishap. Not something I like to do with a competitive mast.
Come to think of it. I dislike that 49er mast as it leaked like I don't know what, making righing the boat a pain as you always had to wait for the water to drain out through those tiny holes. Not an issue i would like to see repeated on the olympic cat. So other than divisible the cat mast joint better be watertight. To much effort or a feature no- one will use anyway, in my opinion.
But other then that you are right. The mast is a 3-piece section and can theoretically be taken apart. Or better put, it looks that way on paper and that is what counts these days.
Wouter
Wow. Just wow. I'm all for freedom of speech and everything, but wow...
Less than a fraction of ONE PERCENT of all of us on this forum have a remote chance (or let's face it, real interest) in actually sailing in an Oly trial, let alone qualifying for the games; no matter what cat design is specified or ultimately selected (on anything from H16 to Tornado to something new with a wing).
So, our interest can only be as spectators. Why are we spending so much energy spouting off about all the things that are wrong with the proposal, rather than helping get behind a boat that will meet the requirements and get selected?
Better than that, start helping some sailors train (or at least raise money) so that when the time comes, they can qualify and ultimately win the event?
After all, it's supposed to be about the sailors, not the boats, right?
And don't wind up about mixed crews anymore. It's not like you were on a two-man crew waiting in the wings to get called to Rio. God forbid you get to watch a girl sail on a catamaran...
Mike
Be sure to read the full text on the linked document. It is fairly clear the specs are an ideal and that boats will be rated on how close they meet them.
No boats are excluded from applying to the trials by anything in the specs. And since there is no one boat anyone can think of that meets all the listed specs, (does an H16 support both crew with both hulls fully flooded? [Heck, it barely does before flooding ;)] ) there are no shoe-in's for getting into the trials.
Mike
I definately look at the Olympics from the spectator side and that is important from a promotion of cat sailing perspective. How fast will the cats be going in 6 knots of wind on a 16ft cat with 140kg crew? The cats have to be exciting the whole Olympics not just the lucky windy day. Any decent skipper no matter what weight will keep a Tornado humming in light or heavy wind, they can wild thing in light and still go fast, don't tell me a Viper of Hobie 16 will still power on in the light. If its too windy for a light crew on the T with a full rig they can put a smaller sail on if they need to. As for limiting the weight to 140kg that puts this 15yo, 75kg girl, crewing on the Taipan 5.7 out of dreaming about the Olympics
As a matter of fact, it does. Unlike most
modern
boats, the H16 has a foam flotation block in the hulls that will prevent it from sinking, even if both hulls are compromised.
Mike
She'll drop 5kg in Olympic prep. I don't think the 140kg weight range is really that limiting (median for a mixed Olympic crew globally is 138kg per SA/google)
I do think keeping a hull airborne for the spectators is going to be needed no matter what conditions. Put a hull flying event in and that will keep the media appeal up.
Beat me to it, Matt. I've seen H16s float with a ridiculous about of damage, as well as (several) H17s and H18s with bows ripped completely off.
EDIT: I don't recall ever seeing a boat with both hulls ripped open, it's definitely possible (a boat
giving
the T-bone, as opposed to
receiving
the T-bone, might get both bows comprimised)...
Mike
Sad, but true.
Since dreaming is free and given the ISAF specs, a new 15 ft cat with a two part wing would be my personal favorite.
Why small? Because a small wing is a lot less trouble to build, handle and store, the boat would be cheaper, novices would be able to sail it and the fun is guaranteed for kids/teens, so it would have the potential to atract new sailors at their youth.
A modified Tornado or F18 will be too big/heavy for the weight range and are unlikely to atract young sailors.
The F16 is close to ideal, but with the addition of a wing, 16 ft may be too big for the specified weight range.
Yes.
Ben Hall's A Class wing split into two parts, lower and upper.
Easy. Just build an F18 as light as possible and then add 100 lb ballast to race in the F18 class.
- 781 Online
